October 14, 201016 yr I recently saw a error in my Error Log that I have not seen before. /LOG/A.LOG Anything I should be concerned about? Tue 2010/10/12 06:55:53 AM System -5 Start Tue 2010/10/12 06:55:58 AM System -110022 /LOG/A.LOG Tue 2010/10/12 06:55:58 AM System -100002 /LOG/A.LOG Tue 2010/10/12 11:25:58 AM System -140005 CLI-WBug Tue 2010/10/12 03:20:11 PM System -110022 /LOG/A.LOG Tue 2010/10/12 03:20:11 PM System -100002 /LOG/A.LOG Tue 2010/10/12 06:17:32 PM System -110022 /LOG/A.LOG Tue 2010/10/12 06:17:32 PM System -100002 /LOG/A.LOG Wed 2010/10/13 03:35:49 AM System -140002 CLI-WBug Wed 2010/10/13 11:55:50 AM System -140005 CLI-WBug Wed 2010/10/13 07:55:45 PM System -140008 CLI-WBug:503 Thu 2010/10/14 12:55:47 AM System -140002 CLI-WBug The weather bug ones I know are occasional missed updates and I don't worry about them.
October 14, 201016 yr Author Hi Brian H, Apologies for a tardy reply. The errors you are seeing are related to the first fix (file system access) and should be completey fixed in the latest 2.8.4 drop. If you have not upgraded your 2.8.4 to the latest (yesterday), may I humbly suggest that you do so? With kind regards, Michel
October 15, 201016 yr I just finished setting up 2 2420m motion sensors. I noticed the LED was not flashing when motion was detected. Jumper 2 is off and the default 100 is the setting for the brightness. I am on 2.8.4 and the ms are v2.0 I factory reset the motion (without restoring in ISY) and the LED flashes with every detection. I then selected options for the ms in ISY. The ISY reported all the original default settings for the ms. I didn't change any, just hit save. After that no LED on motion detection. Its almost like the ISY is turning off the LED option instead of setting the level. Can anyone else confirm? This occured for both ms I set up this morning. Both motions are v2 and purchased about 3 months ago. One of the ms has the address sticker in the usual location in the battery location, the other ms has the sticker on the back, visible without removing the battery lid, which I thought was interesting. Thanks, Tim
October 15, 201016 yr Hi Tim, What happens if you change the level? Set the level to say 85. Rand I just finished setting up 2 2420m motion sensors. I noticed the LED was not flashing when motion was detected. Jumper 2 is off and the default 100 is the setting for the brightness. I am on 2.8.4 and the ms are v2.0 I factory reset the motion (without restoring in ISY) and the LED flashes with every detection. I then selected options for the ms in ISY. The ISY reported all the original default settings for the ms. I didn't change any, just hit save. After that no LED on motion detection. Its almost like the ISY is turning off the LED option instead of setting the level. Can anyone else confirm? This occured for both ms I set up this morning. Both motions are v2 and purchased about 3 months ago. One of the ms has the address sticker in the usual location in the battery location, the other ms has the sticker on the back, visible without removing the battery lid, which I thought was interesting. Thanks, Tim
October 15, 201016 yr Hi Rand, I tried setting to 50 and 255 (I didn't remember it going that hi before, thought 100 was the upper limit) and still no LED on trip. Thanks, Tim
October 15, 201016 yr I have confirmed the LED does not light under ISY and does light under HL2. Using the following setup with ISY and (HL2) ... (Occupancy) Sense - Checked (On) On Only - Checked (On & Off commands) Night Only - Unchecked (Night Only) Timeout - 1 minute (1 minute) LED Brightness - 125 (49%) Dark Sensitivity - 74 (29%) low storage ISY - 50100134 127D014A low storage HL2 - 50100134 1A7D014A Byte 4, which I think is a flag byte, is the only difference between when the LED lights and does not light. HL2 is using the Extended Set 2E to set the LED Bright level so there could be other differences beyond storage locations 0-7. The actual LED Bright level value of 7D is the same for both.
October 15, 201016 yr One more thing I should mention. Setting the brightness of the LED did work in previous ISY versions although I cannot say which version it stopped working in since it has been at least 5 months since I last adjusted a ms. It could very well be this last version since a lot of work probably had been done to add more settings. Thanks, Tim
October 16, 201016 yr Im not sure if this is related to this build, I upgraded to 2.83 the other day, and finally got around to making programs for my motion sensors, one command I want to use is after sunset, before sunrise. I tried many times to set befor option and each time I look its set to after. Yes i do update changes and save them. I tried flipping the option to before sunset and after sunrise, still when I go back and check both commands are set to after, thus my program will not run. Thanks for any help
October 16, 201016 yr I upgraded to 2.84 and still same problem, posted line code , maybe I made a mistake in the programming
October 16, 201016 yr I just checked (running 2.8.4 also) and I am able to select before and after and when saved the ISY saves. If From Sunrise - 1 minute To Sunset + 1 minute (same day) And Time is Sunrise - 1 minute And Time is Sunrise + 1 minute And Time is Sunset + 1 minute And Time is Sunset - 1 minute Then - No Actions - (To add one, press 'Action') Else - No Actions - (To add one, press 'Action') But that may not mean much, some people were having problems with 2.8.3 / 2.8.4 and some weren't. Hopefully others will also check and report. Tim
October 16, 201016 yr Thanks TFJ for trying maybe its a fluke hopefully this is isolated to just me so micheal does not have to got through the whole code again lol TFJ how did you post that code so i could compare, because my code does not look anythin like yours
October 16, 201016 yr Yes, hopefully it is simple. Right click on the program in the left pane, select copy to clipboard. Then paste here, then highlight what was just pasted and select the Code button above. Tim
October 16, 201016 yr Tim i tried you method but neverthelless this is what i came up with If Status 'Frt Ent Motion sens' is On And Time is Sunset And Time is Sunrise Then Set 'EKP Front door' Fast On Wait 2 minutes Else Set 'EKP Front door' Fast Off still the same result, but thanks never was in it enough to pay attention to the clipboard option, usually the isy works flawlessly, so I have rarely a need to be on forums. Kudos to Micheal
October 16, 201016 yr Hi robandcathy, I think you want From/To and not Time is. Select the Time is drop-down and choose From. Another scheduler will open which begins with To. Rand
October 16, 201016 yr I tried you method and still have same effect Rand, each time I hit update it changes the befor sunrise to after. hummm, or is this normal, I would think if you set it to before it would stay in that state. I remember setting this up a long while back, but now seems options have increased. here is the new setup via Rands instructions.
October 16, 201016 yr Hi robandcathy, This is probably a stupid question but I have to ask, are you adjusting the before/after time setting before hitting update? In other words setting 2 minutes >After>Sunset etc. Thanks, Tim
October 16, 201016 yr I adjust before hitting update, and i do not want a specific time for sunset, or sunrise i will let the isy figure it out. No question is stupid lol. I make the adjustments and wehn i hit update it reverts back to after insted od staying on before.
October 16, 201016 yr If you don't enter any time in the Before/After it will revert to After. Rand I adjust before hitting update, and i do not want a specific time for sunset, or sunrise i will let the isy figure it out. No question is stupid lol. I make the adjustments and wehn i hit update it reverts back to after insted od staying on before.
October 17, 201016 yr Author Hi Guys, Just wanted to let you know that, as always, LeeG has helped us with the Motion Sensor light issue. We are going to fix it and put a patch out soon. LeeG, thanks so very much! With kind regards, Michel
October 17, 201016 yr I have it sorted , I had a old program I set up where it was just sunrise to sunset, somewhere in the updates it was added to be abel to give you more control by assigning times before and after, you were correct, you must assign a time or it will revert back. So i just used 1 min, and she works, Thanks to everyone who helped, this is whats makes this forum a first class act, it's members.
October 20, 201016 yr Hi Team, I've experienced a loss of network connectivity twice since installing firmware 2.8.4. The ISY continues to run programs but cannot be accessed via http or telnet. Here is an error log excerpt. Immediately preceding this, a program that sends an email notification ran: Time User Code Message Tue 2010/10/19 01:53:06 PM System -5012 n/a Tue 2010/10/19 01:53:06 PM System -5012 n/a Tue 2010/10/19 01:53:07 PM System -5012 n/a Tue 2010/10/19 01:53:22 PM System -5012 n/a Tue 2010/10/19 01:53:27 PM System -5012 n/a Tue 2010/10/19 01:53:27 PM System -5012 n/a Tue 2010/10/19 01:53:49 PM System -5012 n/a Tue 2010/10/19 01:53:49 PM System -5012 n/a Tue 2010/10/19 01:53:49 PM System -5012 n/a Tue 2010/10/19 01:54:33 PM System -5012 n/a Tue 2010/10/19 01:54:33 PM System -5012 n/a Tue 2010/10/19 01:54:34 PM System -5012 n/a Tue 2010/10/19 01:54:48 PM System -5012 n/a Tue 2010/10/19 01:54:49 PM System -5012 n/a Tue 2010/10/19 01:54:52 PM System -5012 n/a Tue 2010/10/19 01:55:58 PM System -5012 n/a Tue 2010/10/19 01:55:58 PM System -5012 n/a Tue 2010/10/19 01:55:58 PM System -5012 n/a Tue 2010/10/19 02:40:33 PM System -140005 CLI-WBug Tue 2010/10/19 04:43:28 PM System -140002 CLI-WBug Tue 2010/10/19 04:45:28 PM System -140008 CLI-WBug:503 Tue 2010/10/19 04:55:27 PM System -5012 n/a Tue 2010/10/19 04:55:27 PM System -5012 n/a Tue 2010/10/19 04:55:27 PM System -5012 n/a Tue 2010/10/19 06:03:56 PM System -5012 n/a Tue 2010/10/19 06:03:57 PM System -5012 n/a Tue 2010/10/19 06:03:57 PM System -5012 n/a Tue 2010/10/19 06:04:32 PM System -140005 CLI-WBug Tue 2010/10/19 07:19:27 PM System -140008 CLI-WBug:503 Tue 2010/10/19 08:04:58 PM System -140002 MOD-EM-BRULTECH Tue 2010/10/19 08:05:30 PM System -140000 datafeed.weatherbug.com Tue 2010/10/19 08:05:32 PM System -140002 MOD-EM-BRULTECH Tue 2010/10/19 08:05:58 PM System -140002 MOD-EM-BRULTECH Tue 2010/10/19 08:06:01 PM System -100 [DHCP] Router N/A Tue 2010/10/19 08:06:01 PM System -100 [Network] No Gateway. Stopping I haven't seen anything like this happen with any prior firmware versions. Cheers, -Jim
October 20, 201016 yr I upgraded to 2.8.4 and since X10 is not working. Has anyone else had issues with X10 and 2.8.4 ? My previous issues with the 2420 motion detector have been fixed - so that is working properly now. Thanks,
October 21, 201016 yr Author Hello RatRanch! Apologies for the inconvenience. When did you update the firmware? If it's more than 3 days ago, please re-download and re-install the firmware. There were some issues with the initial releases which are fixed now. Hello Candide, I have 2.8.4 running here in the lab and I have a program that sends an X10 off command every minute. It has been working fine thus far. With kind regards, Michel
October 21, 201016 yr It doesn't do X10 at all or are there some X10 functions that don't work? I send an X10 A4 On every morning to a chime module and my X10 power line messages show up in the log also. Using 2.8.4
