MorningLinc not Moving Deadbolt
I have the new MorningLinc and I have connected it to the lock. Pressing the button unlocks and locks the deadbolt.
I have v2.8.4 installed on myISY and I have linked the MorningLinc to my ISY. It shows up as xxx-On and xxx-Off. When I select the on or off it shows unlocked or locked but the deadbolt never moves.
I have tried to link it a couple of times and the ISY never communicates with the MorningLinc.
Help
While linking morninglinc to the ISY, I plugged it in near my computer, while linking I had to hold the set button down during the entire linking process
I followed your instructions (a few issues that I detail below) and I now have control. Thank you for your help.
The few issues are the factory reset did not work as detailed in the manual. The manual said to hold the set bottom on while plugging it in and the light would turn on it would remain lit and then it would flash and then go solid.
What happened was that I held the set button down while plugging it in and the light remained off. I then released the button. I then pushed the button holding it down until it flashed several times and then went solid.
One other question I have: The ISY 99i creates two entries, xxxx-On and xxx-Off. I cannot tell any difference between them. Both lock and unlock the same way. They seem redundant to each other. Is there any difference between the two ?
Mike
