ISY - Controlling Network Event
Hi Guys,
I have this bit of code...
       Control 'Great Room / GR-TopOfStairs-KPL.1.1' is switched Bright
    Or Control 'Great Room / GR-TopOfStairs-KPL.1.1' is switched Fade Up
       Resource 'Living Room - Sonos Volume Up'
If you wait 5-10 seconds between keypress you can control the volume Shouldn't this be so that as you hod it, every once and a while it keeps sending the volume up????
Virtual Controllers...
Devon
Mitch
Can you give me an example oaf how the fade stop should work?
Is there someway for me to see what a button is throwing off as commands?
Devon
Using Tools | Diagnostics | Evevt Viewer Change Level 3 – the command codes indicate the type of button press
ON Command
Thu 11/04/2010 09:29:04 AM : [iNST-SRX ] 02 50 14.71.3C 00.00.01 CB 11 00 LTONRR (00)
OFF Command
Thu 11/04/2010 09:29:10 AM : [iNST-SRX ] 02 50 14.71.3C 00.00.01 CB 13 00 LTOFFRR(00)
Fast ON
Thu 11/04/2010 09:29:14 AM : [iNST-SRX ] 02 50 14.71.3C 12.9F.E4 41 12 01 LTON-F (01)
Fast OFF
Thu 11/04/2010 09:29:20 AM : [iNST-SRX ] 02 50 14.71.3C 12.9F.E4 41 14 01 LTOFF-F(01)
Start Dim UP
Thu 11/04/2010 09:29:29 AM : [iNST-SRX ] 02 50 14.71.3C 00.00.01 CB 17 01 LTMCON (UP)
Stop Dim
Thu 11/04/2010 09:29:34 AM : [iNST-SRX ] 02 50 14.71.3C 00.00.01 CB 18 00 LTMCOFF(00)
Start Dim DOWN
Thu 11/04/2010 09:29:44 AM : [iNST-SRX ] 02 50 14.71.3C 00.00.01 CB 17 00 LTMCON (DOWN)
Stop Dim
Thu 11/04/2010 09:29:48 AM : [iNST-SRX ] 02 50 14.71.3C 00.00.01 CB 18 00 LTMCOFF(00)
