November 23, 201015 yr Author Hello IM, Thanks so very much for your kind words! The compare issue has been identified and fixed in the next drop. Since this is a UI only issue, we can always update the website and you can use the updated UI. If you are in a rush, please do let me know and we can do that quickly. Thanks again and with kind regards, Michel
November 23, 201015 yr Michel, The compare feature is absolutely not a rush item. With your new context menu I can easily bring up a device link table and the ISY table side by side. Not quite as convenient, but it will certainly do for now. Thank you for the offer, but please focus on the many other requests that we forum members are posing for the team.
November 23, 201015 yr LeeG, You were correct. When I replaced my garage door openner, one of wires grounding the analog inputs broke and it was floating. Thanks, keep up the updates
