Adding MoeningLinc
I am unable to add MorningLinc to isy. I am running 2.84. I believe when I loaded 2.84, I got the agreement form and clicked accept and a message that it was not accepted. It doesn't matter if I hold the MorningLinc button down the whole time or reset as instructions for reset. I do get a message" -200000 Node not added-failed restoring device". Any suggestions?
Thanks:wacvmd
Hello wacvmd,
Two conditions must be met before ML is added to ISY:
1. ML should be very close to an Access Point or the dual band PLM when linking
2. You have to use the 3rd option when linking ML
It seems that the signals are not reaching your ML and therefore I must suspect that the ML is not close to an Access Point or the dual band PLM.
Does it mater if I use the 2412S or a new dual band plm?
Thank You: I was trying to add it be adding new device, when I used the linking menu no problem. Thanks again.
