Can't Change Time
I just got a new ISY99/i and I can't change the time. It's running the latest version, i tired factory reset. When i manually adjust time time, it looks like it's doing it but when i look back it reset it to some random date and time. Suggestions?
No it's disabled. When i put it todays date it goes to 7/6/2005
Hello BoydG,
I do apologize for the inconvenience. Can you give me a sampling of the random times you get?
If you have cleared your Java cache, and if you are still having the same issue, would you be kind enough to contact our tech support team? You might have a defective hardware and we'll be able to ascertain if this is indeed the case.
Again, sincere apologies for the inconvenience.
Yes it does it when i press the set from PC as well
i've tried 3 other PC's and clearing out the java cache
It appears to change dates on it's own as well.
Right now it says 9/3/1946
Synchronize with computer produces 6/26/2005
When i'm in the date picker, as i pick the date, i see in the status bar the correct date and time, but when i click OK it reverts back to something random.
I clicked on a tab on top and now it's 2/22/2000
