Is there a tutorial for setting up custom notifications?
Greetings,
After several failed attempts to set up custom email messages on the ISY admin console I realize I need some pointers - there must be something I am missing. Would someone be so kind as to point me to the instructions? Thanks again,
Hello mjtyson,
Still working on the documentation!
1. Make sure you have recipient groups under Configuration | Emails & Notifications | Settings/Groups
2. Go to the Customized Content tab, create a new record by clicking the Add button
3. Click on the second column called Customized Content
4. For the subject and body, you have three choices
-- a. Choose from the options in Alert drop down and Common drop down. Alert has variables pertaining to the email when it is initiated by Programs such as the device that triggered the event. Common has system wide veriables
-- b. Type in the text you want in the subject and the body
-- c. Combination of above
5. In your programs, choose Notify then choose the recipient and then the content
Please note that if subject and body are blank, no notifications are sent.
Miche
So far I have set up a recipient under groups that sends a notice to the intended address when I hit test. The problem I am having is when I go to the customizations tab that although I am able to Add a row with the prerequisite "Name" "Customized Content" and "ID" I am only able to edit the "Name" field. When I select/double-click on the other two fields there is no response. Is there a "switch" I need to enable in order for this to work? Thanks again,
This may or may not be important - but when I initially select Customizations I get a
"Request Failed" error. Once I press OK the page opens with no entries. If I press add a new row appears - of which only the "name" field is editable.
Enjoy,
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.device.model.lists.UDManagedContentList.getContentListEntry(Unknown Source)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationContentGrid.getEntry(Unknown Source)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationsContentPanel.getNotificationContentDialog(Unknown Source)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationsContentPanel.mouseClicked(Unknown Source)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:253)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.processMouseEvent(Component.java:6355)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.processEvent(Component.java:6117)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.processEvent(Container.java:2085)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.dispatchEventImpl(Component.java:4714)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.dispatchEventImpl(Container.java:2143)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.dispatchEvent(Component.java:4544)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4621)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4291)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4212)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.dispatchEventImpl(Container.java:2129)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Window.dispatchEventImpl(Window.java:2478)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventQueue.dispatchEvent(EventQueue.java:635)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
10-12-18 12:21:44 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.device.model.lists.UDManagedContentList.getContentListEntry(Unknown Source)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationContentGrid.getEntry(Unknown Source)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationsContentPanel.getNotificationContentDialog(Unknown Source)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationsContentPanel.mouseClicked(Unknown Source)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:253)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.processMouseEvent(Component.java:6355)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.processEvent(Component.java:6117)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.processEvent(Container.java:2085)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.dispatchEventImpl(Component.java:4714)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.dispatchEventImpl(Container.java:2143)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.dispatchEvent(Component.java:4544)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4621)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4291)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4212)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.dispatchEventImpl(Container.java:2129)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Window.dispatchEventImpl(Window.java:2478)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventQueue.dispatchEvent(EventQueue.java:635)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
10-12-18 12:22:02 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.device.model.lists.UDManagedContentList.getContentListEntry(Unknown Source)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationContentGrid.getEntry(Unknown Source)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationsContentPanel.getNotificationContentDialog(Unknown Source)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationsContentPanel.mouseClicked(Unknown Source)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:253)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.processMouseEvent(Component.java:6355)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.processEvent(Component.java:6117)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.processEvent(Container.java:2085)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.dispatchEventImpl(Component.java:4714)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.dispatchEventImpl(Container.java:2143)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.dispatchEvent(Component.java:4544)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4621)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4291)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4212)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.dispatchEventImpl(Container.java:2129)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Window.dispatchEventImpl(Window.java:2478)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventQueue.dispatchEvent(EventQueue.java:635)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
10-12-18 12:22:03 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.device.model.lists.UDContentMultiFileRepository.saveContent(Unknown Source)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.device.model.lists.UDManagedContentList.saveContentList(Unknown Source)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationsContentPanel.save(Unknown Source)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at com.universaldevices.ui.sysconfig.notifications.NotificationsContentPanel$3.actionPerformed(Unknown Source)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2028)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2351)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.processMouseEvent(Component.java:6352)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.processEvent(Component.java:6117)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.processEvent(Container.java:2085)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.dispatchEventImpl(Component.java:4714)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.dispatchEventImpl(Container.java:2143)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Component.dispatchEvent(Component.java:4544)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4621)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4282)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4212)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Container.dispatchEventImpl(Container.java:2129)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.Window.dispatchEventImpl(Window.java:2478)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventQueue.dispatchEvent(EventQueue.java:635)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
10-12-18 12:22:09 AM [0x0-0x37037].com.apple.jnlp-http___www.universal-devices.com_99i_2.8.7_admin.jnlp[362] at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Thank-you for the clue. After viewing your post I confirmed that I was running firmware 2.8.8 in "about" so I figured if it wasn't a firmware issue it could be some kind of conflict with the console. I removed the shortcut from my desktop and taskbar and downloaded a new java console file from the 2.8.8 release documentation. After installing this everything works fine. One thing that could be confusing the issue is that the java files all have the same file name no matter which version you download - so one could think they have a duplicate file when in actuality they are two distinct files with the same name.
Thanks again for your support
Sort of related but different problem.
I can't get notifications to send me emails from programs. It sends text messages fine and I can send emails using the "test" button on the configuration page. But executing emails from programs, well, it just doesn't happen.
I am using your default email server.
Michel,
I was testing the program by using the "run then" command. I used the same program and changed the "to" section from an email address to a text message address. I left everything else the same. The texts come through but the emails do not. ISY is not indicating any errors. Again, when I test email from the configuration page I do get the test email.
And yes, there is content in both body and subject and it does come through to the text message address. The email gets nothing, and I did check junk folder.
Lou
Michel,
It is working now on gmail but they (the real messages) are going to junk folder. Why the "test" messages don't go to the junk folder but the actual ones do is a mystery to me.
And the real messages from the default mail server still are not showing up anywhere. The test messages do go through fine to the regular mail folder.
Lou
Hello mjtyson,
Miche
How's the tutorial comin' along? :D
Jon
Hi Jon,
To be quite honest, it's not coming along at all: too many things to little time!
It is however in the list of things to do before our official release (hopefully by the end of the week).
Even workin' Sundays eh?
Guess that's what makes you guys so good :wink:
Jon
Michel,
I just upgraded to v2.8.10 (RC-5) and I am impressed! Just one minor item involving teh new CUstom Notification Feature, when creating a new notification it would be nice if this form behaved similiar to the manner in which Outlook behaves specifically when you are in the Subject Field and press the tab key the cursor should be moved to the body field.
Thanks! I love the changes especially being able to "run" the program from the program details tab. Keep up the great work!
