"program active" testable in IF statements
oskrypuch
From the Program Summary page, programs can be listed as Enabled (on/off), Activity (idle/running 'xxx') and Status (true/false)
In an IF statement you can test for the Status like so:
   Program 'DoSomething' is True
I don't see any way to directly test for the Activity of a program, IOW whether it is currently idle or running Then or Else, etc.
You could handle it with a separate Program "variable", but that is a bit clumsy.
A feature request.
* Orest
Hello Orest,
In cases of programs that do not have Wait/Repeat statements, the additional overhead for checking activity (the duration of which might be between milliseconds to few seconds in case of communications errors) is a bit too much.
Do you have any specific use cases in mind for which this is needed?
It is exactly that application, to check a program that is in a WAIT loop. Something like this:
Program CheckStatus
if Program 'DoStuff_wait_DoMore Stuff' is not active
Then ...
Program DoStuff_wait_DoMore Stuff
if
wait xx
MoreStuff
I can also accomplish this with Program pseudo-variables, basically setting a semaphore to allow for a testable condition, when the second program is running its Then statement.
* Orest
      37.4k
      374.5k
