Hello all,
Thanks so very much for all your help in this beta cycle. If no serious bugs are found, 2.8.11 shall become our official release.
Please do be kind enough to :
1. Test Network Resource delays
2. Retrieving logs
3. iMeter Solo Beep
4. Importing Network Resources does not overwrite IDs
For a list of changes, please take a look at this post:
http://forum.universal-devices.com/view ... =6475#6475
Notes:
1. ISY-26 is no longer included in the firmware builds
2. Due to the sensitive nature of supporting MorningLinc, users now must agree to terms and conditions upon Admin Console start up otherwise the dialog keeps popping up every time the Admin Console is started
Instructions:
1. Please backup your ISY (File | Backup ISY)
ISY 99i Series: http://www.universal-devices.com/update ... 2.8.11.zip
OR 992i Series: http://www.universal-devices.com/update ... 2.8.11.zip
OR 994i Series: http://www.universal-devices.com/update ... 2.8.11.zip
3. Important
Due to invalid Java certificate chain in releases 2.8.5 and above, please make sure to remove all Universal Devices certificates from Java:
a. Close all browser sessions
b. Open Java Control Panel (Java Preferences on MAC)
c. Click on the Security tab. Remove all Universal Devices certificates (on MAC, click on the '-' button at the bottom)
e. Clear your Java Cache ( http://www.universal-devices.com/mwiki/ ... Java_Cache
f. Go to http://www.universal-devices.com/99i/2.8.11/admin.jnlp
4. Login to the Admin Console and choose Help | Manually Upgrade [the name of your system]
5. Choose the file saved in step 2
MAC users: if upgrade fails, please add https://your.isy.ip.address to ISY Finder (see 3f above)
6. After the upgrade, ISY reboots. Please do ensure to clear your Java Cache:
7. IMPORTANT Once upgrade is completed and ISY reboots, use any of the following methods to access your ISY's Admin Console:
a. http://isy/admin - applet (Windows only)
b. http://isy/admin.jnlp - Java application (Windows only)
c. http://your.isy.ip.address/admin - applet
d. http://your.isy.ip.address/admin.jnlp - Java application
e. http://www.universal-devices.com/99i/2.8.11 - applet
f. http://www.universal-devices.com/99i/2.8.11/admin.jnlp - Java application
8. IMPORTANT If you have already installed a self signed certificate and your current firmware is 2.7.10 and below, you must reinstall a new one:
http://www.universal-devices.com/mwiki/ ... rtificates
Thanks and with kind regards,
i upgrade from 2.8.10rc6 to 2.8.11 and the about screen still says 2.8.10.
I upgraded from a W7 64-bit client and cleared java cache after upgrade.
UPDATE: I upgraded a second time and now the about screen says 2.8.11. Seems like the same thing happended to me with several betas of 2.8.10
I followed the new upgrade instructions (as posted at the beginning of this thread) exactly and everything worked properly the first time.
Thanks for the great support and a great product!
Greg
I also just upgraded from v2.8.10 rc5 to v2.8.11 and my About Screen is still showing v2.8.10 (see below). I removed all Universal Devices certificates from Java and I cleared the Java Cache. Any ideas?
Exactly the same outcome on a Mac; I had to apply the update twice.
That is strange, Michel can you advise? BTW I used a Windows 7 machine to apply the update.
For those that do not show 2.8.10 after update, after clearing the Java cache, did you invoke the 2.8.11 Admin Console from the UDI web site to do the actual manual update?
I did this, backup my ISY, and install v2.8.11, then close out of all browsers and clear your java.
Reload your isy from your internet browser, and click administrative console.
Version 2.8.10 showed in the about screen.
I guess it's a bug with the update..
As reported, did this one more time and it published the correct version.
Joe Double U
Lee - I used the following link to access the Admin Console:
and on the About Form the version is still saying v.2.8.10
For those who cannot upgrade: please NOTE that you will have to use http://www.universal-devices.com/99i/2.8.10/ or http://www.universal-devices.com/99i/2.8.10/admin.jnlp (or 2.8.11). You CAN NOT use your current version coming from ISY.
For future versions, this should not be a problem.
Polexian, no, this is not a bug. We did verify that we are sending the correct message/command. The LED brightness works ONLY on SWLs with BEEP. It does not work on others.
The new 2477DH 1000w Duel band switch will program. But will not show when you go to another switch and replace with, it doesn’t show. Tried with three different switches. Had to program each scene into the new switch and then delete old switch.
For some reason the UDI Web Console does not work for me - I just see a "blank" console screen and never get a logon prompt.
I upgraded and saw 2.8.10. I ended the program, re-cleared the java cache, removed the certificate and re- upgraded (running locally).
When accessing the console I was prompted for the new certificate and the version now shows correctly as 2.8.11 .
So far so good, I'll update any issues if/when they happen.
Thanks...
That did the trick, thanks Michel!
some of the weatherbug notification variables don't seem to match up - specifically:
Light Level
Rain Today
This is my alert:
Weather Summary for ${sys.date} at ${sys.time12}
Temperature: ${mod.weather.temp.current}
Temperature High: ${mod.weather.temp.high}
Temperature Low: ${mod.weather.temp.low}
Feels Like: ${mod.weather.temp.feelslike}
Temp Rate: ${mod.weather.temp.rate}
Humidity: ${mod.weather.humidity}
Humidity Rate: ${mod.weather.humidity.rate}
Pressure: ${mod.weather.pressure}
Pressure Rate: ${mod.weather.pressure.rate}
Dewpoint: ${mod.weather.dewpoint}
Wind Speed: ${mod.weather.wind.speed}
Wind Speed Average: ${mod.weather.wind.speedavg}
Wind Direction: ${mod.weather.wind.direction}
Wind Direction Average: ${mod.weather.wind.directionavg}
Gust Speed: ${mod.weather.gust.speed}
Gust Direction: ${mod.weather.gust.direction}
Light Level: ${mod.weather.light.level}
Light Rate: ${mod.weather.light.rate}
Rain Today: ${mod.weather.rain.today}
Rain Rate: ${mod.weather.rain.rate}
Rain Rate Max: ${mod.weather.rain.ratemax}
Thank you!
and this is what the email showed:
Weather Summary for 2011/01/25 at  4:50:35 PM
Temperature: 17.1 °F
Temperature High: 20 °F
Temperature Low: 15 °F
Feels Like: 11 °F
Temp Rate: -0.2 °F
Humidity: 81 %
Humidity Rate: 2 %/h
Pressure: 29.96 mbar
Pressure Rate: 0 mbar/h
Dewpoint: 12 °F
Wind Speed: 4 mph
Wind Speed Average: 4 mph
Wind Direction: WSW
Wind Direction Average: WSW
Gust Speed: 16 mph
Gust Direction: SSE
Light Level: 0 inches
Light Rate: 2.9 %/h
Rain Today: -2.6 %/h
Rain Rate: 0 inches/h
Rain Rate Max:
Thank you!
and this is what the climate module shows:
Temperature: 17.1 F
High Temperature: 20 F
Low Temperature: 15 F
Feels Like: 11 F
Temperature Rate: -0.2 F
Humidity: 81 %
Dew Point: 12 F
Wind Speed: 4 mph
Average Wind Speed: 4 mph
Wind Direction: WSW
Average Wind Direction: WSW
Gust Speed: 16 mph Gust Direction: SSE
Rain Today: 0 inches
Light: 2.9 %/h
Light Rate: -2.6 %/h
WeatherBugâ„¢ RSS
Try turning off any firewalls or antivirus on the UDI web console issue. I had the same issue and this fixed the problem.
Thanks for the suggestion, I suspended web, firewall, intrusion and more on my Norton Internet Security, but that did not help.
I always clear the Java cache, but when running the Web console (the first link) I see the 'blank' console - but there is no "manually upgrade" option under the Help menu item.
If I run the JNLP I get Error: Not found. When it prompts me to enter the URL it tries to find it then simply says Not found.
      379.9k
