MorningLinc+ISY-99i not controlling physical lock
clockwrkz
Hi,
I just installed a MorningIndustry deadbolt and MorningLinc controller.
The MorningLinc is paired with the door. If I press the set button on the MorningLinc it will lock or unlock the door.
With some searching I found out how to find the MorningLinc with the Admin Console for the ISY-99i (I`m using the latest version which was released earlier this week).
There are 2 devices which appear under `My Lighting` called `Front Lock-on` and `Front Lock-off`. (The names were the device id which is 16 84 82-on and 16 84 82-off)
When I press On or Off in the admin console the Current State changes from Locked to Unlocked in the admin console. Which is where the problem happens. The physical lock on the door is not receiving these commands and never moves. Therefore I`m assuming the MorningLinc is not receiving the commands. I know that communication is one way so I`m not surprized that the Current Status changes even though the lock doesn`t move.
Here is the information from the Event Viewer when I pressed On:
Wed 02/09/2011 07:01:05 PM : [iNST-ACK    ] 02 62 16.84.82 0F 11 FF 06          LTONRR (FF)
Wed 02/09/2011 07:01:05 PM : [iNST-ACK    ] 02 62 16.84.82 0F 11 FF 06          LTONRR (FF):  Process ACK: duplicate ignored
Wed 02/09/2011 07:01:05 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 11 FF    LTONRR (FF)
Wed 02/09/2011 07:01:05 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 07:01:05 PM : Duplicate: ignored
Wed 02/09/2011 07:01:05 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 11 FF    LTONRR (FF):  Process Message: failed
It looks like there are some clues in there but not sure where to go from here. `Process Message: failed` seems rather ominous for example.
Any help is greatly appreciated.
Link to comment
For what it's worth, I tried deleting the device from the admin console and readding it (to the same result). I've also power cycled everything.
Here is the communication log of removing then adding back in the MorningLinc:
Wed 02/09/2011 08:19:51 PM : [All         ] Writing 0 bytes to devices
Wed 02/09/2011 08:19:51 PM : [Front Lock-On] Start : Removing device from ISY
Wed 02/09/2011 08:19:51 PM : [  16 84 82 1] Removing all links
Wed 02/09/2011 08:19:51 PM : [16 84 82 1  ] Using engine version i1 for 'Front Lock-On'
Wed 02/09/2011 08:19:51 PM : [iNST-ACK    ] 02 62 16.84.82 0F 28 0F 06          SET-MSB(0F)
Wed 02/09/2011 08:19:51 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 28 FF    SET-MSB(FF)
Wed 02/09/2011 08:19:51 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:19:51 PM : [iNST-ACK    ] 02 62 16.84.82 0F 2B F8 06          PEEK   (F8)
Wed 02/09/2011 08:19:52 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 2B FF    PEEK   (FF)
Wed 02/09/2011 08:19:52 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:19:52 PM : [iNST-ACK    ] 02 62 16.84.82 0F 29 00 06          POKE   (00)
Wed 02/09/2011 08:19:52 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 29 FF    POKE   (FF)
Wed 02/09/2011 08:19:52 PM : [Front Lock-On] Finish : Removing from ISY was Successful
Wed 02/09/2011 08:19:52 PM : [All         ] Writing 0 bytes to devices
Wed 02/09/2011 08:19:58 PM : [LNK-BGN     ] 02 64 01 00 06
Wed 02/09/2011 08:20:19 PM : [LNK-STAT    ] 02 53 M(01) gid=00 16.84.82 0F06 3A
Wed 02/09/2011 08:20:19 PM : Linked: Linked 16.84.82.00 type=0F.06.3A
Wed 02/09/2011 08:20:19 PM : [iNST-ACK    ] 02 62 16.84.82 0F 28 0F 06          SET-MSB(0F)
Wed 02/09/2011 08:20:19 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 28 0F    SET-MSB(0F)
Wed 02/09/2011 08:20:19 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:20:19 PM : [iNST-ACK    ] 02 62 16.84.82 0F 2B F8 06          PEEK   (F8)
Wed 02/09/2011 08:20:20 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 2B A2    PEEK   (A2)
Wed 02/09/2011 08:20:20 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:20:20 PM : [16 84 82 1  ] MorningLinc database accessible.
Wed 02/09/2011 08:20:20 PM : [16.84.82-On] Start : Adding device to ISY
Wed 02/09/2011 08:20:20 PM : [16.84.82-On] Finish : Adding device to ISY was Successful
Wed 02/09/2011 08:20:20 PM : [16.84.82-Off] Start : Adding device to ISY
Wed 02/09/2011 08:20:20 PM : [16.84.82-Off] Finish : Adding device to ISY was Successful
Wed 02/09/2011 08:20:20 PM : [All         ] Writing 0 bytes to devices
Wed 02/09/2011 08:20:20 PM : [LNK-BGN     ] 02 64 01 00 06
Wed 02/09/2011 08:20:36 PM : ---- Initializing the linked devices ----
Wed 02/09/2011 08:20:36 PM : [  16 84 82 1] Removing all links
Wed 02/09/2011 08:20:36 PM : [16 84 82 1  ] Querying engine version
Wed 02/09/2011 08:20:36 PM : [LNK-END     ] 02 65 06
Wed 02/09/2011 08:20:36 PM : [standard Msg. Handler] Unexpected Ack imCmd=65 cmd1= 0x22
Wed 02/09/2011 08:20:36 PM : [iNST-ACK    ] 02 62 16.84.82 0F 0D 00 06                 (00)
Wed 02/09/2011 08:20:37 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 0D 01           (01)
Wed 02/09/2011 08:20:37 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:20:41 PM : [iNST-ACK    ] 02 62 16.84.82 0F 0D 00 06                 (00)
Wed 02/09/2011 08:20:41 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 0D 01           (01)
Wed 02/09/2011 08:20:41 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:20:41 PM : [16 84 82 1  ] Retrieved engine version is i2
Wed 02/09/2011 08:20:41 PM : [16 84 82 1  ] Calibrating engine version ensuring support for i2
Wed 02/09/2011 08:20:41 PM : [iNST-ACK    ] 02 62 16.84.82 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Wed 02/09/2011 08:20:42 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 2F 00           (00)
Wed 02/09/2011 08:20:42 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:20:42 PM : [iNST-ERX    ] 02 51 16 84 82 13 22 7C 11 2F 00 01 01 00 FF 01 A2 00 13 22 7C 00 00 00 00
Wed 02/09/2011 08:20:42 PM : [Extended-Direct][16.84.82-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Wed 02/09/2011 08:20:42 PM : [Ext. Msg. Handler] Duplicate response: ignored
Wed 02/09/2011 08:20:51 PM : [iNST-ACK    ] 02 62 16.84.82 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Wed 02/09/2011 08:20:52 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 2F 00           (00)
Wed 02/09/2011 08:20:52 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:20:52 PM : [iNST-ERX    ] 02 51 16 84 82 13 22 7C 11 2F 00 01 01 00 FF 01 A2 00 13 22 7C 00 00 00 00
Wed 02/09/2011 08:20:52 PM : [Extended-Direct][16.84.82-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Wed 02/09/2011 08:20:52 PM : [Ext. Msg. Handler] Duplicate response: ignored
Wed 02/09/2011 08:21:01 PM : [iNST-ACK    ] 02 62 16.84.82 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Wed 02/09/2011 08:21:01 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 2F 00           (00)
Wed 02/09/2011 08:21:01 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:21:01 PM : [iNST-ERX    ] 02 51 16 84 82 13 22 7C 11 2F 00 01 01 00 FF 01 A2 00 13 22 7C 00 00 00 00
Wed 02/09/2011 08:21:01 PM : [Extended-Direct][16.84.82-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Wed 02/09/2011 08:21:01 PM : [Ext. Msg. Handler] Duplicate response: ignored
Wed 02/09/2011 08:21:05 PM : [16 84 82 1  ] i2 data transfer commands do not work. Reverting to i1
Wed 02/09/2011 08:21:06 PM : [16 84 82 1  ] Using engine version i1 for '16.84.82-On'
Wed 02/09/2011 08:21:06 PM : [iNST-ACK    ] 02 62 16.84.82 0F 28 0F 06          SET-MSB(0F)
Wed 02/09/2011 08:21:06 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 28 0F    SET-MSB(0F)
Wed 02/09/2011 08:21:06 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:21:06 PM : [iNST-ACK    ] 02 62 16.84.82 0F 2B F8 06          PEEK   (F8)
Wed 02/09/2011 08:21:06 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 2B A2    PEEK   (A2)
Wed 02/09/2011 08:21:07 PM : [iNST-ACK    ] 02 62 16.84.82 0F 29 00 06          POKE   (00)
Wed 02/09/2011 08:21:07 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 29 00    POKE   (00)
Wed 02/09/2011 08:21:07 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:21:07 PM : [iNST-ACK    ] 02 62 16.84.82 0F 28 0F 06          SET-MSB(0F)
Wed 02/09/2011 08:21:07 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 28 FF    SET-MSB(FF)
Wed 02/09/2011 08:21:08 PM : [iNST-ACK    ] 02 62 16.84.82 0F 2B F0 06          PEEK   (F0)
Wed 02/09/2011 08:21:08 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 2B FF    PEEK   (FF)
Wed 02/09/2011 08:21:08 PM : [standard-Direct Ack][16.84.82-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/09/2011 08:21:08 PM : [iNST-ACK    ] 02 62 16.84.82 0F 29 00 06          POKE   (00)
Wed 02/09/2011 08:21:08 PM : [iNST-SRX    ] 02 50 16.84.82 13.22.7C 2B 29 FF    POKE   (FF)
Wed 02/09/2011 08:21:09 PM : ---- All Linked Devices are now initialized ----
Wed 02/09/2011 08:21:09 PM : [All         ] Writing 0 bytes to devices
Wed 02/09/2011 08:21:09 PM : ---- Initializing the linked devices ----
Link to comment
Hello clockwrkz,
I do think that the problem is with your MorningLinc; the reason is that ISY can communicate with it and MorningLinc is responding back to ISY. So, the communications are working properly. Somehow, these communications are not initiating a command to the door lock.
The next thing to try is to factory reset your MorningLinc and then restore it from ISY.
Link to comment
Hi Michel,
Thank you very much for your response and help.
Hello clockwrkz,
I tried the above mention idea. I removed the MorningLinc from the admin console, reset it to factory defaults, paired it with the lock again, confirmed it could unlock/lock the door, went to "Start Linking" in the admin console and linked it with the ISY-99i again.
I have the same results as before. I press "On" or "Off" for that device and it does not lock or unlock the door.
I have 3 MorningLincs here I am planning to install so I opened a second, new box and tried that one. I had the same results as above again.
Just in case it helps, here is the log of adding the brand new MorningLinc to the ISY-99i:
Thu 02/10/2011 08:09:49 AM : [LNK-BGN     ] 02 64 01 00 06
Thu 02/10/2011 08:10:06 AM : [LNK-STAT    ] 02 53 M(01) gid=00 16.84.0F 0F06 3A
Thu 02/10/2011 08:10:06 AM : Linked: Linked 16.84.0F.00 type=0F.06.3A
Thu 02/10/2011 08:10:06 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 28 0F 06          SET-MSB(0F)
Thu 02/10/2011 08:10:07 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 28 0F    SET-MSB(0F)
Thu 02/10/2011 08:10:07 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:07 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 2B F8 06          PEEK   (F8)
Thu 02/10/2011 08:10:07 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 2B A2    PEEK   (A2)
Thu 02/10/2011 08:10:07 AM : [16 84 F 1   ] MorningLinc database accessible.
Thu 02/10/2011 08:10:07 AM : [16.84.0F-On] Start : Adding device to ISY
Thu 02/10/2011 08:10:07 AM : [16.84.0F-On] Finish : Adding device to ISY was Successful
Thu 02/10/2011 08:10:07 AM : [16.84.0F-Off] Start : Adding device to ISY
Thu 02/10/2011 08:10:07 AM : [16.84.0F-Off] Finish : Adding device to ISY was Successful
Thu 02/10/2011 08:10:07 AM : [All         ] Writing 0 bytes to devices
Thu 02/10/2011 08:10:07 AM : [LNK-BGN     ] 02 64 01 00 06
Thu 02/10/2011 08:10:25 AM : ---- Initializing the linked devices ----
Thu 02/10/2011 08:10:25 AM : [   16 84 F 1] Removing all links
Thu 02/10/2011 08:10:25 AM : [16 84 F 1   ] Querying engine version
Thu 02/10/2011 08:10:25 AM : [LNK-END     ] 02 65 06
Thu 02/10/2011 08:10:25 AM : [standard Msg. Handler] Unexpected Ack imCmd=65 cmd1= 0x22
Thu 02/10/2011 08:10:25 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 0D 00 06                 (00)
Thu 02/10/2011 08:10:26 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 0D 01           (01)
Thu 02/10/2011 08:10:26 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:30 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 0D 00 06                 (00)
Thu 02/10/2011 08:10:30 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 0D 01           (01)
Thu 02/10/2011 08:10:30 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:30 AM : [16 84 F 1   ] Retrieved engine version is i2
Thu 02/10/2011 08:10:30 AM : [16 84 F 1   ] Calibrating engine version ensuring support for i2
Thu 02/10/2011 08:10:30 AM : [iNST-ACK    ] 02 62 16.84.0F 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Thu 02/10/2011 08:10:31 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 2F 00           (00)
Thu 02/10/2011 08:10:31 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:40 AM : [iNST-ACK    ] 02 62 16.84.0F 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Thu 02/10/2011 08:10:40 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 2F 00           (00)
Thu 02/10/2011 08:10:40 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:40 AM : [iNST-ERX    ] 02 51 16 84 0F 13 22 7C 11 2F 00 01 01 00 FF 01 A2 00 13 22 7C 00 00 00 00
Thu 02/10/2011 08:10:40 AM : [Extended-Direct][16.84.0F-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Thu 02/10/2011 08:10:40 AM : [Ext. Msg. Handler] Duplicate response: ignored
Thu 02/10/2011 08:10:49 AM : [iNST-ACK    ] 02 62 16.84.0F 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Thu 02/10/2011 08:10:50 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 2F 00           (00)
Thu 02/10/2011 08:10:50 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:50 AM : [iNST-ERX    ] 02 51 16 84 0F 13 22 7C 11 2F 00 01 01 00 FF 01 A2 00 13 22 7C 00 00 00 00
Thu 02/10/2011 08:10:50 AM : [Extended-Direct][16.84.0F-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Thu 02/10/2011 08:10:50 AM : [Ext. Msg. Handler] Duplicate response: ignored
Thu 02/10/2011 08:10:54 AM : [16 84 F 1   ] i2 data transfer commands do not work. Reverting to i1
Thu 02/10/2011 08:10:54 AM : [16 84 F 1   ] Using engine version i1 for '16.84.0F-On'
Thu 02/10/2011 08:10:54 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 28 0F 06          SET-MSB(0F)
Thu 02/10/2011 08:10:55 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 28 0F    SET-MSB(0F)
Thu 02/10/2011 08:10:55 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:55 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 2B F8 06          PEEK   (F8)
Thu 02/10/2011 08:10:55 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 2B A2    PEEK   (A2)
Thu 02/10/2011 08:10:55 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 29 00 06          POKE   (00)
Thu 02/10/2011 08:10:55 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 29 00    POKE   (00)
Thu 02/10/2011 08:10:56 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:56 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 28 0F 06          SET-MSB(0F)
Thu 02/10/2011 08:10:56 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 28 FF    SET-MSB(FF)
Thu 02/10/2011 08:10:56 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 2B F0 06          PEEK   (F0)
Thu 02/10/2011 08:10:56 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 2B FF    PEEK   (FF)
Thu 02/10/2011 08:10:57 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 29 00 06          POKE   (00)
Thu 02/10/2011 08:10:57 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 29 FF    POKE   (FF)
Thu 02/10/2011 08:10:57 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:10:57 AM : ---- All Linked Devices are now initialized ----
Thu 02/10/2011 08:10:57 AM : [All         ] Writing 0 bytes to devices
Thu 02/10/2011 08:10:57 AM : ---- Initializing the linked devices ----
And here is trying to communicate with the second, new MorningLinc:
Thu 02/10/2011 08:11:17 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 11 FF 06          LTONRR (FF)
Thu 02/10/2011 08:11:17 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 11 FF 06          LTONRR (FF):  Received an ACK for a different device
Thu 02/10/2011 08:11:17 AM : [   16 84 F 2]       ST 255
Thu 02/10/2011 08:11:17 AM : [   16 84 F 1]       ST 255
Thu 02/10/2011 08:11:17 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 11 FF    LTONRR (FF)
Thu 02/10/2011 08:11:17 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:11:22 AM : [   16 84 F 2]       ST   0
Thu 02/10/2011 08:11:22 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 11 00 06          LTONRR (00)
Thu 02/10/2011 08:11:22 AM : [   16 84 F 1]       ST   0
Thu 02/10/2011 08:11:22 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 11 FF    LTONRR (FF)
Thu 02/10/2011 08:11:22 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:11:22 AM : Duplicate: ignored
Thu 02/10/2011 08:11:22 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 11 FF    LTONRR (FF):  Process Message: failed
Thu 02/10/2011 08:11:27 AM : [   16 84 F 1]       ST 255
Thu 02/10/2011 08:11:27 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 11 FF 06          LTONRR (FF)
Thu 02/10/2011 08:11:27 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 11 FF 06          LTONRR (FF):  Received an ACK for a different device
Thu 02/10/2011 08:11:27 AM : [   16 84 F 2]       ST 255
Thu 02/10/2011 08:11:27 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 11 FF    LTONRR (FF)
Thu 02/10/2011 08:11:27 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:11:27 AM : Duplicate: ignored
Thu 02/10/2011 08:11:27 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 11 FF    LTONRR (FF):  Process Message: failed
Thu 02/10/2011 08:11:29 AM : [   16 84 F 1]       ST   0
Thu 02/10/2011 08:11:29 AM : [   16 84 F 2]       ST   0
Thu 02/10/2011 08:11:29 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 11 00 06          LTONRR (00)
Thu 02/10/2011 08:11:29 AM : [iNST-ACK    ] 02 62 16.84.0F 0F 11 00 06          LTONRR (00):  Received an ACK for a different device
Thu 02/10/2011 08:11:29 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 11 FF    LTONRR (FF)
Thu 02/10/2011 08:11:29 AM : [standard-Direct Ack][16.84.0F-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 02/10/2011 08:11:29 AM : Duplicate: ignored
Thu 02/10/2011 08:11:29 AM : [iNST-SRX    ] 02 50 16.84.0F 13.22.7C 2B 11 FF    LTONRR (FF):  Process Message: failed
Do you have any other ideas I can try?
Thank you very much for your help again.
Link to comment
  • 3 months later...
Hi clockwrkz,
I am glad it worked.
The reaso for two nodes is because that's how SmartLabs defined the on/off groups for ML. If you are not going to use them in scenes, then they are identical.
I'm having a similar issue. I had it detected in ISY-99ir no problem before but it wasn't working for me. Now the morninglinc module won't even get detected in ISY. I am using release 2.8.16. Should I be upgrading to a BETA release? The odd thing is that at least before the ISY was detecting the morninglinc but now it's not even seeing it. Even if I enter the info manually it won't find it. I've tried 2 morninglinc modules with the same result - doesn't show up in ISY.
Any assistance would be greatly appreciated. Thank you!
[update] - I just tried the latest firmware to no avail. I also factory reset the PLM as well as the ISY-99IR but for some reason none of my morninglincs are being found.
Link to comment
Hello ssingh1234,
Just to be certain, did you follow the instructions here:
http://www.universal-devices.com/mwiki/ ... orningLinc ?
It's very important that you choose the 3rd option otherwise everything will be removed.
Thanks Michel, yes I did follow the instructions. Although I have to say that I had the morninglinc detected when I first started with ISY and I did not select the 3rd option. Then I reset the ISY. After that I couldn't get it detected.
Then, I tried a 2nd morninglinc (fresh new) and I couldn't get that detected.
Any ideas?
Link to comment
Hello ssingh1234,
Unfortunately I am out of ideas except:
1. Please factory reset the one that used to work when you used option 1
2. Make sure you are within a range of an access point
3. The actual door lock is close to ML
I didn't do anything today and just happened to try and re-link the morninglinc this morning before heading into work and it miraculously found it. Odd - thanks for all your help.
Link to comment
      37k
      371k
