Venstar setpoint not in devices html display
I have model 2441V version V.91
The thermostat is a 2491T1 T1700 with the humidity sensor soldered out
I have noticed for a number of releases that the setpoint does not show up in the device HTML display. It does show up in the admin console. I have tried a query of the device and it does still does not appear. Also in the admin display, now and then, I do not see that the heat is on when it is running. A query on the device also does not correct the problem
I upgraded to 2.8.16 and still see the problem.
Has anyone any idea as to why?
The thermostat is in program mode.....and running currently heating
In the HTML page I see
Program Heat
Setpoint blank
Status 69 (correct as temp is 69)
H/C Fan off
Fan Auto
Humidity 2%
In the admin console I see
Current State 69
Setpoint 71
Humidity 2% ( Sensor soldered out so ok)
Thermostat Mode Program Heat
Fan State Auto
Heat/Cool State off ( even though it is running and I just did a query on it to refresh it)
It is odd that status of admin console and HTML page do not match for the setpoint.....
Below is the log info for the last couple hours....As I look at it quickly it seems...
From the log it appears that either the status is being sent and lost due to transmission issues ( though I am not having many of these issues lately )
as it lost the heat on that happened about 8:02 when I set the setpoint up
or the dongle is not responding correctly. Note the query done at 9:02.
I have posted another post in the the thread about dongles hanging. I need to power off mine every week or so to get it running again
I will let you look at the log and see what you think.
Thermostats / Thermostat Family Room - Main Heat/Cool State Heat On Mon 2011/02/21 06:01:59 AM System
Thermostats / Thermostat Family Room - Main Heat Setpoint 70░ Mon 2011/02/21 06:02:01 AM System
Thermostats / Thermostat Family Room - Main Status 62░ Mon 2011/02/21 06:12:50 AM System
Thermostats / Thermostat Family Room - Main Status 63░ Mon 2011/02/21 06:18:13 AM System
Thermostats / Thermostat Family Room - Main Status 64░ Mon 2011/02/21 06:26:47 AM System
Thermostats / Thermostat Family Room - Main Status 65░ Mon 2011/02/21 06:36:26 AM System
Thermostats / Thermostat Family Room - Main Status 66░ Mon 2011/02/21 06:49:17 AM System
Thermostats / Thermostat Family Room - Main Status 65░ Mon 2011/02/21 06:52:31 AM System
Thermostats / Thermostat Family Room - Main Status 66░ Mon 2011/02/21 06:53:38 AM System
Thermostats / Thermostat Family Room - Main Fan State Auto Mon 2011/02/21 07:01:51 AM Program
Thermostats / Thermostat Family Room - Main Status 67░ Mon 2011/02/21 07:20:31 AM System
Thermostats / Thermostat Family Room - Main Status 66░ Mon 2011/02/21 07:26:58 AM System
Thermostats / Thermostat Family Room - Main Status 67░ Mon 2011/02/21 07:29:08 AM System
Thermostats / Thermostat Family Room - Main Status 66░ Mon 2011/02/21 07:30:14 AM System
Thermostats / Thermostat Family Room - Main Status 67░ Mon 2011/02/21 07:39:53 AM System
Thermostats / Thermostat Family Room - Main Status 68░ Mon 2011/02/21 07:49:31 AM System
Thermostats / Thermostat Family Room - Main Status 67░ Mon 2011/02/21 07:50:38 AM System
Thermostats / Thermostat Family Room - Main Status 68░ Mon 2011/02/21 07:52:48 AM System
Thermostats / Thermostat Family Room - Main Status 67░ Mon 2011/02/21 07:54:58 AM System
Thermostats / Thermostat Family Room - Heat Status Off Mon 2011/02/21 08:01:58 AM System
Thermostats / Thermostat Family Room - Main Heat/Cool State Off Mon 2011/02/21 08:01:58 AM System
Thermostats / Thermostat Family Room - Main Heat Setpoint 65░ Mon 2011/02/21 08:02:00 AM System
Thermostats / Thermostat Family Room - Main Heat Setpoint 69░ Mon 2011/02/21 08:03:23 AM System
Thermostats / Thermostat Family Room - Main Heat Setpoint 71░ Mon 2011/02/21 08:03:27 AM System
Thermostats / Thermostat Family Room - Main Status 68░ Mon 2011/02/21 08:17:39 AM System
Thermostats / Thermostat Family Room - Main Status 69░ Mon 2011/02/21 08:53:57 AM System
Thermostats / Thermostat Family Room - Main Status Query░ Mon 2011/02/21 09:02:20 AM Web
Thermostats / Thermostat Family Room - Main Status 69░ Mon 2011/02/21 09:02:21 AM System
Thermostats / Thermostat Family Room - Main Thermostat Mode Program Heat Mon 2011/02/21 09:02:21 AM System
Thermostats / Thermostat Family Room - Main Heat Setpoint 71░ Mon 2011/02/21 09:02:22 AM System
Thermostats / Thermostat Family Room - Main Humidity 2% Mon 2011/02/21 09:02:22 AM System
I'm on .16 and I also get a blank space instead of Setpoint in Program Heat mode. The Setpoint reappears when I change to Heat mode.
