Using my own certificate.
I have a wildcard certificate and I would like to use it with my ISY. I notice when I click on manage ssl certificates I get a new browser window that goes to:
https://universal-devices.com/ssl/insteon
Which in turn starts a new java applet. My question is how is this controlling my Isy? I want my Isy to be on it's own, and I do not not want anything to do with Universal Devices remote access portals. I found the Install Certification option but I am nervous about putting in my in wildcard certficiate as it seems to be sending it to Universal Devices.
Can anyone explain what is going on here?
I am still having trouble using my own wildcard certificate. After uploading it using the SSL Certificate Management -> Install SSL Certificate my device reboots but continues to use the old certificate.
Does my certificate need to be in a certain format? PKCS perhaps?
Also, when I start the tool and login I get the following error window:
After clicking ok I get the license agreement window:
After clicking Yes I get:
Hi simonsez,
I am not sure what "my own certificates" mean.
What you have to do:
1. Make sure you are local
2. Create a Certificate Signing Request (SSL Certificate Management | Generate Certificate Request to CA)
3. Send it to your CA
4. Once it's signed, then use SSL Certificate Management | Receive Certificate from CA and Install
Please note that max strength for ISY is 128 (1024) and not higher.
You can always use CACert.org to create free certificates.
Hi Michel,
I have already have a certificate I would like to use. It's a wild card certificate from Godaddy. It is in PEM format. How I can use this certificate with the Isy? When I select 'Install Exisiting SSL Certificate", what format is the ISY expecting?
Ryan
Hi simonsez,
