E net connection problem
I have been using an ISY-99i for some time. Now I can't access it by e net. The ISY is working fine. My modem is working fine. I have two PCs and the ISY connected to it.
The e net connection at the rear of the ISY shows one solid green light and one blinking green light. At the other end a green light goes on where the cable is connected to the modem. MEM and ERR are blinking. I ran www.universal-devices.com/991. It didn't find my ISY.
I rebooted my modem and the problem remains.
Where should I go from here?
Joe
I have checked my cables. And replaced the e net cable. The ISY cable connector shows a steady green light and a linking green light. The router connection shows a green light. So, I think the connections are OK.
The ISY is not on the router's DHCP client table. I have spent more than two hours with AT&T trying to solve this. So far, none of them has any idea how to add to the client list.
I'm beginning to think my problem is in the router.
Does the ISY continue o try to connect to the router? Or, do I have to do something to make that happen?
Is there any way to increase the font size or these messages?
Joe
My access problem was solved after I unplugged the PLM and replugged it. After the ISY booted up it was able to connect to the router. Now it works fine.
Joe
