Can the RF of a 2477D be verified?
I have four Venstar 1700's and the one in the master bedroom is constantly listed in the log with -1 errors meaning there is a com error. I have a 2477D less than 10 feet away. Does this mean the 2477D is defective? The thermostat works well and the programming I set up runs without any noticable problems but I don't like errors.
I hoping there's a way to verify the switch is defective. I want SM to swap it out (which they probably would do anyway), but I don't want to have my electrician swap out the switch and find the errors don't go away.
TIA,
Mitch
Michel, I have four of the 2477D's and all are v.38
The attached load is four CFL's so I'm sure that's where the issue is. I'll move the switch and try again.
Are the CFLs dimmable?
If not; they should not be used with a dimmer type switch.
Many times even if they are dimmable. They can make power line interference that can effect things.
The best thing is relay type modules and switches for CFLs.
