Venstar 1800 thermostat question
I have just installed the venstar 1800 and have a question and a little problem. When I go into the isy and set it the mode I set it for program/heat right now. My problem is that after a day or so it goes into the off mode and I have to go in and start it again. What could be causing this. I have the fan set to run to circulate air for 10 minutes from 10-10 every day. Could that be it. I don't have it programmed in the isy to do anything yet, just in the thermostat itself. Is there some other setting that I may have done that is causing this? Thanks.
