Process for converting KPL from 6 button to 8 button
Hi,
What is the best way to convert a 6 button KPL to an 8 button KPL?
Is there a function within ISY to do this?
Or, do I manually hold the A and F [correction A and H] key down while pulling out the set tab on the KPL? And then, how do I instruct ISY that the KPL has changed? Relink?
Thank you.
I don't think there is any way the ISY can change the mode.
Isn't it the A & H buttons when you push the set button back in?
http://www.smarthome.com/manuals/2486d.pdf
I would:
Delete the KPL from the ISY.
Perform a Factory Reset on the KPL.
Change the KPL to 8 button mode.
Add the KPL back to the ISY. The ISY will read the mode.
Rand
Right, A and H key. And thanks for the info.
Regards.
Rand,
That is a good little tip about switching a KPL that already exists in the ISY. I am going to add it to the KPL how to in the wiki.
