Lights on at Sunset off 30 Minutes later
So I tried this, what am I doing wrong as it is not working.
If: From Sunset
For 30 Minutes
Set 'Outside - Family Room Door' On
Am I missing something?
Thanks for my newbie questions.
I'm not an expert here but here is what will work if you want the lights to go on at sunset then off after 30 minues
If time is sunset
then
Set 'whatever you want' on
wait 30 minutes
Set 'whatever you want' off
else
this should work if I understand what you are trying to do
There are no experts here :) We are all new to this ISY. Maybe some more experienced :roll:
AnthemAVM, I believe what you are thinking is
       From    Sunset
       For      30 minutes
       Set 'Backyard' On
       Set 'Backyard' Off
Which would work, but it will be turning off the Backyard any time you are outside of the 30 minute window. We don't want that, do we?
If you know you will only ever want it on for 30 minutes at a time the Wait example from gfrnd is the way to go.
For lights I would use two programs.
Backyard On
       Time is Sunset
       Set 'Backyard' On
Backyard Off
       Time is Sunset  + 30 minutes
       Set 'Backyard' Off
Then if you need to modify either the On or Off time it will not affect the other.
Rand
Hey Rand -
That's what I had thought too, but it's not the case.
I run the following code for my front door lights:
       From    Sunset  + 20 minutes
       To       9:30:00PM (same day)
       Set Scene 'FrontDoor' On
       Set Scene 'FrontDoor' Off
I can turn them on any time of the day, and they will stay on.
I believe the conditions are evaluated only twice (at the start time, and at the end time) - not continuously.
MikeB,
You are absolutely right, when entering a time range that time range becomes True, when leaving a time range it becomes False. Entering and leaving a time range are events that cause the program to run (either Then or Else path depending on all the If conditions).
Check out this post if you want to keep something on (or off) during a time range:
http://forum.universal-devices.com/viewtopic.php?t=394
