Watchguard Firebox Edge
bocaray
Does anyone have any information on how to get external internet access to the ISY-99 thru a Watchguard Firebox Edge?
I'd like to control the ISY-99 using the internet when I am not home.
Information is very sparse and incomplete.
Thanks. It still seems a little above my network knowledge but I'll give it a shot.
Finally got it to work but am concerned. Maybe I shouldn't be. I was able to allow TCP port 443 to be open and can now access my ISY-99i using
"https://xxx.xxx.xxx.xxx/admin" Since this uses 443 port does this make me very open to hacking? I can't seem to find a method to forward say port 60000 to port 443 and make it a little safer. Should this be a concern or am I being too cautious? Opinion welcome.
Hello bocaray,
Personally, I would use a different public port. I have not yet seen a router that does not allow different public-to-private port mapping. Are you certain it cannot be done on your router?
Alternatively, you can change the HTTPS port on ISY to some other port (say 8443) and then do 8443 to 8443 (this can be done on Configuration | System | Network section of Admin Console). Once you do that, then your URL would be https://your.remote.ip.address:8443 (or some other port).
Kind of coincidence, I would have thought all suported this as well but I just bought a new Netgear yesterday and it does not.
The router feature you're looking for is called Virtual Server or its real name is PAT (Port Address Translation).
In order to get it on my Netgear, I had to hack it with the 3rd party DD-WRT firmware.
Ok. Changed to port 8443. As for routers that don't forward Public-to-private, you might want to check out the Watchguard Firebox x Edge. Seems getting any info is like pulling teeth.
It may have this feature, but I can't find it or any info on "how to".
Anyway, thanks for the help. It's now at https://xxx.xxx.xxx.xxx:8443/admin and works fine.
      379.9k
