Lights turning on by theirselves
jsp
I was playing with a new scene I have setup in my bathroom and was trying to see if the status updated on my virtual 3-way. The scene is controlled by a KPL button, I did not include the non-load 3-way switch so it did not update. I turned the scene on and off a few times and the 3-way on and off a few times then 15 seconds later the light opened by itself.
I believe I read somewhere that the ISY is always a controller on any scenes created on it. Would that behavior occur because the ISY isn't getting confirmation of the light turned on and replaying the command a few seconds later ?
Hello jsp,
No, ISY would not turn things on/off on its own. To rule out ISY/programs, please disable all your programs:
1. My Programs
2. Click on If
3. Click on Schedule
4. Uncheck All
5. Save Changes
Once this is done, retry your test please and let us know what you find.
  • 3 weeks later...
Hello,
Programs were not the culprit, since I only had one to Turn on and off outside lights based on time.
Now, I repeated the problem and reviewing the LOGS on the ISY shows ELK as being responsible ?!
At the time I didn't have any lighting info imported into my ELK.
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:14 System Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:14 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:14 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:14 System Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:16 System Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:16 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:17 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:17 System Log
Stairs - Bottom Off 0 Sun 2011/08/07 16:44:21 ELK Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:22 System Log
Stairs - Top Off 0 Sun 2011/08/07 16:44:23 ELK Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:23 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:26 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:26 System Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:26 System Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:26 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:27 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:27 System Log
Stairs - Bottom Off 0 Sun 2011/08/07 16:44:33 ELK Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:34 System Log
Stairs - Top Off 0 Sun 2011/08/07 16:44:35 ELK Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:35 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:38 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:38 System Log
Stairs - Top Off 0 Sun 2011/08/07 16:44:41 ELK Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:41 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:50:09 System Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:50:13 System Log
Stairs - Top Status 0% Sun 2011/08/07 16:50:13 System Log
But no lighting data was configured on the ELK, but maybe this is the problem.
Anyway, I uploaded the ELK Export from ISY this weekend, so I shouldn't see my lights doing this anymore if it was the issue.
I will play with the lights tonight and report back with my findings.
Just out of curiosity, how did this caused lights to turn on and off like this?
Hi jsp,
There's an option flag in ELK which lets it know what to do with received data (from ISY). Without the option - and in some cases, ELK simply returns it back to ISY as a command and thus you will see lights intermittently turn on/off.
Ok, so when the M1XEP is configured in ISY, the ISY will send lighting status information to the ELK?
