No Lighting state in Java console
Hello,
I am using another PC now and it seems that I can't get lighting states in the Java console, it also see a 9 mins ramp rate for each light. When I go back to the laptop, everything is OK in the java console... any idea what could be causing this ?
This computer is running Vista 64-bit, I updated Java to latest and cleared the temp files, but none of that helped.
jsp
There was a time when both 32 and 64 bit Java install was required. Don't know if it still applies.
Also does the Vista PC have the same trust level at the router the laptop does.
no restrictions at the router, both the Vista and laptop are on the same subnet as the ISY
I installed the 64-bit Java, seems like I only had 32-bit and it still has the same behavior.
Disabled Kaspersky AV and it works now.
Thanks for your help.
