How to enable / disable motion sensor on Insteon floods
I would like to know what the programming content should be to do the following...
Enable the Insteon motion sensor on the floods
Disable the Insteon motion sensor on the floods
Currently, I am using the following code but it doesn't seem to work...
== Code Begins ==
Control 'B1 - Porch / B8 - Floods Disable' is switched On
Set Scene '.Floods All' Fast Off
- No Actions
== Code Ends ==
The .Floods All Scene is comprised of 12 different floods and 5 different controls.
Thanks in advance.
wharris
Use the Admin Console and send a Fast Off command to a specific InLineLinc with Sense (not using a Scene). Does the specific InLineLinc with Sense react to the Fast Off and no longer turn On in response to motion?
Lee
