EZFlora V.28 fails to link
mink
I purchased a newer EZFlora (v.28) to be able to use it with scenes.
ISY is at 3.1.9
PLM is v.92
I had it partially working when I added it with "New Insteon Device), entering its address (01.DB.DF) and letting the ISY auto-discover in that it would get added. Then if I added one of the stations to a scene, I would an error "failed writing device link", then "Cannot communicate with Please check communications"
and red ! would be next to the EZFlora entries. See first snippet of event viewer
One attempt resulted being able to get rid of the red ! by clicking one of the stations on and everything looked good, but turning on the scenes would not turn on the station valves. I could turn them on by clicking their device entries directly.
Using New Insteon Device and selecting the 04.. EZFlora .. entry would not allow any link at all. see second log snippet
I have two older EZFlora that are working
Trouble shooting steps:
Moved the new one to the same outlet as the PLM
Factory reset the EZFlora several times
Exited the admin screen and browser.
Powered off/on both the PLM and the ISY
I relinked one of the older EZFlora's as a test in the same outlet (third log snippet) and as before, it links up quickly, allows being added to scenes (but the scenes won't control it)
Does this mean I have a bad New EZFLora V.28 or is the 3.1.9beta version of the ISY firmware not able to work with the newest EZFLora firmware?
Adding V.28 EZFlora with "New Insteon Device, entering its address (01.DB.DF) and letting the ISY auto-discover, then adding station 1 to a scene (FrntIrr.v1.On):
Tue 10/18/2011 02:31:40 AM : [   1 DB DF 1] Removing all links
Tue 10/18/2011 02:31:41 AM : [          IR]     016A Press
Tue 10/18/2011 02:31:43 AM : [          IR]     0152 Press
Tue 10/18/2011 02:31:44 AM : [          IR]     0155 Press
Tue 10/18/2011 02:31:45 AM : [          IR]     015A Press
Tue 10/18/2011 02:31:46 AM : [          IR]     012A Press
Tue 10/18/2011 02:31:47 AM : [          IR]     016A Press
Tue 10/18/2011 02:31:51 AM : [          IR]     0295 Press
Tue 10/18/2011 02:31:52 AM : [          IR]     02AA Press
Tue 10/18/2011 02:31:54 AM : [          IR]     0156 Press
Tue 10/18/2011 02:31:58 AM : [          IR]     0155 Press
Tue 10/18/2011 02:32:04 AM : [1 DB DF 1   ] i2 data transfer commands do not work. Reverting to i1
Tue 10/18/2011 02:32:05 AM : [   1 DB DF 1] Adding device to ISY
Tue 10/18/2011 02:32:05 AM : [ezfloraDF] Start : Adding device to ISY
Tue 10/18/2011 02:32:05 AM : [ezfloraDF] Finish : Adding device to ISY was Successful
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 2] Start : Adding device to ISY
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 2] Finish : Adding device to ISY was Successful
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 3] Start : Adding device to ISY
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 3] Finish : Adding device to ISY was Successful
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 4] Start : Adding device to ISY
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 4] Finish : Adding device to ISY was Successful
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 5] Start : Adding device to ISY
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 5] Finish : Adding device to ISY was Successful
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 6] Start : Adding device to ISY
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 6] Finish : Adding device to ISY was Successful
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 7] Start : Adding device to ISY
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 7] Finish : Adding device to ISY was Successful
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 8] Start : Adding device to ISY
Tue 10/18/2011 02:32:07 AM : [ezfloraDF - 8] Finish : Adding device to ISY was Successful
Tue 10/18/2011 02:32:07 AM : [   1 DB DF 1]       ST   0
Tue 10/18/2011 02:32:07 AM : [          IR]     012A Press
Tue 10/18/2011 02:32:08 AM : [   1 DB DF 1] Device added to ISY
Tue 10/18/2011 02:32:09 AM : ---- All Remaining Device Added ----
Tue 10/18/2011 02:32:09 AM : [   1 DB DF 1]       ST   0
Tue 10/18/2011 02:32:09 AM : [   1 DB DF 2]       ST   0
Tue 10/18/2011 02:32:09 AM : [   1 DB DF 3]       ST   0
Tue 10/18/2011 02:32:09 AM : [   1 DB DF 4]       ST   0
Tue 10/18/2011 02:32:09 AM : [   1 DB DF 5]       ST   0
Tue 10/18/2011 02:32:09 AM : [   1 DB DF 6]       ST   0
Tue 10/18/2011 02:32:09 AM : [   1 DB DF 7]       ST   0
Tue 10/18/2011 02:32:09 AM : [   1 DB DF 8]       ST   0
Tue 10/18/2011 02:32:15 AM : [          IR]     012A Press
Tue 10/18/2011 02:32:21 AM : [          IR]     014A Press
Tue 10/18/2011 02:32:25 AM : [          IR]     014A Press
Tue 10/18/2011 02:32:26 AM : [          IR]     02B5 Press
Tue 10/18/2011 02:32:28 AM : [          IR]     012A Press
Tue 10/18/2011 02:32:29 AM : [          IR]     00AA Press
Tue 10/18/2011 02:32:31 AM : [          IR]     0155 Press
Tue 10/18/2011 02:32:34 AM : [          IR]     016A Press
Tue 10/18/2011 02:32:34 AM : [          IR]     0154 Press
Tue 10/18/2011 02:32:39 AM : [          IR]     012A Press
Tue 10/18/2011 02:32:41 AM : [          IR]     012A Press
Tue 10/18/2011 02:32:46 AM : [          IR]     0155 Press
Tue 10/18/2011 02:32:47 AM : [          IR]     02AA Press
Tue 10/18/2011 02:32:50 AM : [          IR]     016A Press
Tue 10/18/2011 02:32:52 AM : [          IR]     02AA Press
Tue 10/18/2011 02:33:00 AM : [          IR]     0155 Press
Tue 10/18/2011 02:33:08 AM : [ezfloraDF - 1] Start : Adding to scene 'FrntIrr.v1.On'
Tue 10/18/2011 02:33:08 AM : [ezfloraDF - 1] Making 'FrntIrr.v1.On' a Controller
Tue 10/18/2011 02:33:08 AM : [ezfloraDF - 1] Finish : Adding to scene 'FrntIrr.v1.On' was Successful
Tue 10/18/2011 02:33:11 AM : [          IR]     02AA Press
Tue 10/18/2011 02:33:12 AM : [          IR]     02AA Press
Tue 10/18/2011 02:33:19 AM : [          IR]     0155 Press
Tue 10/18/2011 02:33:23 AM : [          IR]     0155 Press
Tue 10/18/2011 02:33:23 AM : [          IR]     012A Press
Tue 10/18/2011 02:33:25 AM : [          IR]     016A Press
Tue 10/18/2011 02:33:27 AM : [          IR]     0295 Press
Tue 10/18/2011 02:33:30 AM : [          IR]     0155 Press
Tue 10/18/2011 02:33:34 AM : [          IR]     014A Press
Tue 10/18/2011 02:33:36 AM : [          IR]     012A Press
Tue 10/18/2011 02:33:39 AM : [          IR]     014A Press
Tue 10/18/2011 02:33:44 AM : [          IR]     01AA Press
Tue 10/18/2011 02:33:46 AM : [          IR]     012A Press
Tue 10/18/2011 02:33:49 AM : [          IR]     016A Press
Tue 10/18/2011 02:33:50 AM : [          IR]     0155 Press
Tue 10/18/2011 02:33:52 AM : [          IR]     02AA Press
Tue 10/18/2011 02:33:54 AM : [          IR]     016A Press
Tue 10/18/2011 02:33:56 AM : [          IR]     016A Double Press
Tue 10/18/2011 02:34:00 AM : [          IR]     016A Press
Tue 10/18/2011 02:34:01 AM : [          IR]     016A Press
Tue 10/18/2011 02:34:03 AM : [          IR]     0155 Press
Tue 10/18/2011 02:34:05 AM : [          IR]     014A Press
Tue 10/18/2011 02:34:07 AM : [          IR]     02AA Press
Tue 10/18/2011 02:34:07 AM : [          IR]     01AA Press
Tue 10/18/2011 02:34:10 AM : [          IR]     0154 Press
Tue 10/18/2011 02:34:25 AM : [All         ] Writing 136 bytes to devices
Tue 10/18/2011 02:34:25 AM : [1 DB DF 1   ] Link    0 : 0FF8 [A216131F73000000] Writing [A216131F73000000]
Tue 10/18/2011 02:34:27 AM : [          IR]     0155 Press
Tue 10/18/2011 02:34:30 AM : [          IR]     014A Press
Tue 10/18/2011 02:34:32 AM : [          IR]     0155 Press
Tue 10/18/2011 02:34:34 AM : [          IR]     016A Press
Tue 10/18/2011 02:34:34 AM : [          IR]     012A Press
Tue 10/18/2011 02:34:40 AM : [          IR]     016A Press
Tue 10/18/2011 02:34:42 AM : [          IR]     016A Press
Tue 10/18/2011 02:34:44 AM : [          IR]     02AA Press
Tue 10/18/2011 02:34:47 AM : [          IR]     02AA Press
Tue 10/18/2011 02:34:48 AM : [1 DB DF 2   ] Link    0 : 0FF8 [A216131F73000000] Writing [A216131F73000000]
Tue 10/18/2011 02:34:50 AM : [          IR]     016A Press
Tue 10/18/2011 02:34:53 AM : [          IR]     016A Press
Tue 10/18/2011 02:34:54 AM : [          IR]     015A Press
Tue 10/18/2011 02:34:57 AM : [          IR]     014A Press
Tue 10/18/2011 02:35:00 AM : [          IR]     02AA Press
Tue 10/18/2011 02:35:02 AM : [          IR]     0295 Press
Tue 10/18/2011 02:35:03 AM : [          IR]     012A Press
Tue 10/18/2011 02:35:04 AM : [          IR]     02AA Press
Tue 10/18/2011 02:35:06 AM : [          IR]     02AA Press
Tue 10/18/2011 02:35:07 AM : [          IR]     012A Press
Tue 10/18/2011 02:35:14 AM : [          IR]     0155 Press
Tue 10/18/2011 02:35:17 AM : [          IR]     014A Press
Tue 10/18/2011 02:35:18 AM : [          IR]     0155 Press
Tue 10/18/2011 02:35:20 AM : [MOD  2  2  1  1] 580000.000000  Weather - Temperature = 58 °F
Tue 10/18/2011 02:35:20 AM : [MOD  2  2  1  5] -10000.000000  Weather - Temperature Rate = -1 °F/h
Tue 10/18/2011 02:35:21 AM : [          IR]     012A Press
Tue 10/18/2011 02:35:24 AM : [          IR]     0155 Press
Tue 10/18/2011 02:35:29 AM : [          IR]     0155 Press
Tue 10/18/2011 02:35:30 AM : [          IR]     0155 Press
Tue 10/18/2011 02:35:39 AM : [          IR]     012A Press
Tue 10/18/2011 02:35:41 AM : [   1 DB DF 1]       ST 255
Tue 10/18/2011 02:35:41 AM : [          IR]     012A Press
Tue 10/18/2011 02:35:41 AM : [          IR]     0155 Press
Tue 10/18/2011 02:35:42 AM : [          IR]     012A Press
Tue 10/18/2011 02:35:45 AM : [   1 DB DF 1]       ST   0
Tue 10/18/2011 02:35:53 AM : [          IR]     014A Press
Tue 10/18/2011 02:35:53 AM : [          IR]     0155 Press
Tue 10/18/2011 02:35:54 AM : [          IR]     016A Press
Tue 10/18/2011 02:35:54 AM : [          IR]     0156 Press
Tue 10/18/2011 02:35:56 AM : [All         ] Writing 136 bytes to devices
Tue 10/18/2011 02:35:56 AM : [1 DB DF 1   ] Link    0 : 0FF8 [A216131F73000000] Writing [A216131F73000000]
Tue 10/18/2011 02:35:57 AM : [          IR]     014A Press
Tue 10/18/2011 02:35:59 AM : [          IR]     012A Press
Tue 10/18/2011 02:36:02 AM : [          IR]     016A Press
Tue 10/18/2011 02:36:03 AM : [          IR]     016A Press
Tue 10/18/2011 02:36:06 AM : [          IR]     00AA Press
Tue 10/18/2011 02:36:07 AM : [          IR]     012A Press
Tue 10/18/2011 02:36:09 AM : [          IR]     0155 Press
Tue 10/18/2011 02:36:09 AM : [          IR]     012A Press
Tue 10/18/2011 02:36:15 AM : [          IR]     02AA Press
Tue 10/18/2011 02:36:16 AM : [          IR]     02AA Press
Tue 10/18/2011 02:36:19 AM : [1 DB DF 2   ] Link    0 : 0FF8 [A216131F73000000] Writing [A216131F73000000]
Tue 10/18/2011 02:36:20 AM : [          IR]     02AA Press
Tue 10/18/2011 02:36:21 AM : [          IR]     014A Press
Tue 10/18/2011 02:36:26 AM : [          IR]     0155 Press
Tue 10/18/2011 02:36:27 AM : [          IR]     012A Press
Tue 10/18/2011 02:36:29 AM : [          IR]     0155 Press
Tue 10/18/2011 02:36:30 AM : [          IR]     012A Press
Tue 10/18/2011 02:36:32 AM : [          IR]     02AA Press
Tue 10/18/2011 02:36:33 AM : [          IR]     02AA Press
Tue 10/18/2011 02:36:35 AM : [          IR]     0155 Press
Tue 10/18/2011 02:36:37 AM : [          IR]     0155 Press
Tue 10/18/2011 02:36:41 AM : [          IR]     0295 Press
Tue 10/18/2011 02:36:42 AM : [          IR]     012A Press
Tue 10/18/2011 02:36:45 AM : [          IR]     016A Press
Tue 10/18/2011 02:36:50 AM : [          IR]     02AA Press
Tue 10/18/2011 02:36:51 AM : [          IR]     016A Press
Tue 10/18/2011 02:36:52 AM : [          IR]     0155 Press
Tue 10/18/2011 02:36:59 AM : [          IR]     015A Press
Tue 10/18/2011 02:37:01 AM : [          IR]     0155 Press
Tue 10/18/2011 02:37:02 AM : [          IR]     0154 Press
Tue 10/18/2011 02:37:03 AM : [          IR]     012A Press
Tue 10/18/2011 02:37:07 AM : [          IR]     0295 Press
Tue 10/18/2011 02:37:14 AM : [          IR]     0155 Press
Tue 10/18/2011 02:37:16 AM : [          IR]     0155 Press
Tue 10/18/2011 02:37:18 AM : [          IR]     012A Press
Tue 10/18/2011 02:37:19 AM : [          IR]     02D5 Press
Tue 10/18/2011 02:37:19 AM : [MOD  2  2  1  1] 581000.000000  Weather - Temperature = 58.1 °F
Tue 10/18/2011 02:37:19 AM : [MOD  2  2  1  5] -9000.000000  Weather - Temperature Rate = -0.9 °F/h
Tue 10/18/2011 02:37:20 AM : [          IR]     0154 Press
Tue 10/18/2011 02:37:26 AM : [          IR]     014A Press
Tue 10/18/2011 02:37:29 AM : [          IR]     0155 Press
Tue 10/18/2011 02:37:31 AM : [          IR]     016A Press
Tue 10/18/2011 02:37:32 AM : [          IR]     016A Press
Tue 10/18/2011 02:37:34 AM : [          IR]     0155 Press
Tue 10/18/2011 02:37:37 AM : [          IR]     0154 Press
Tue 10/18/2011 02:37:39 AM : [          IR]     0155 Press
Tue 10/18/2011 02:37:44 AM : [          IR]     0155 Press
Tue 10/18/2011 02:37:46 AM : [   1 DB DF 1]       ST 255
Tue 10/18/2011 02:37:48 AM : [   1 DB DF 1]       ST   0
Added V.28 EZFlora using New Insteon Device and selecting the 04.. EZFlora .. entry
Tue 10/18/2011 01:46:29 AM : [   1 DB DF 1] Removing all links
Tue 10/18/2011 01:46:29 AM : [          IR]     0155 Press
Tue 10/18/2011 01:46:31 AM : [          IR]     02AA Press
Tue 10/18/2011 01:46:36 AM : [          IR]     02AA Press
Tue 10/18/2011 01:46:44 AM : [          IR]     0155 Press
Tue 10/18/2011 01:46:46 AM : [          IR]     016A Press
Tue 10/18/2011 01:46:50 AM : [          IR]     012A Press
Tue 10/18/2011 01:46:53 AM : [1 DB DF 1   ] i2 data transfer commands do not work. Reverting to i1
Tue 10/18/2011 01:46:54 AM : [          IR]     015A Press
Tue 10/18/2011 01:47:02 AM : [          IR]     014A Press
Tue 10/18/2011 01:47:04 AM : [          IR]     0155 Press
Tue 10/18/2011 01:47:09 AM : [          IR]     0155 Press
Tue 10/18/2011 01:47:13 AM : [          IR]     012A Press
Tue 10/18/2011 01:47:13 AM : [          IR]     0155 Press
Tue 10/18/2011 01:47:16 AM : [   1 DB DF 1] ** Not added ** Remove Device Links failed
Events for adding older EZFlora (19 AD 9C )
Tue 10/18/2011 01:51:39 AM : ---- Add remaining devices ----
Tue 10/18/2011 01:51:39 AM : [  19 AD 9C 1] Removing all links
Tue 10/18/2011 01:51:42 AM : [          IR]     012A Press
Tue 10/18/2011 01:51:42 AM : [          IR]     02AA Press
Tue 10/18/2011 01:51:43 AM : [  19 AD 9C 1] Adding device to ISY t=04.00.0000
Tue 10/18/2011 01:51:44 AM : [FrntIrrCtr9C.] Start : Adding device to ISY
Tue 10/18/2011 01:51:44 AM : [FrntIrrCtr9C.] Finish : Adding device to ISY was Successful
Tue 10/18/2011 01:51:44 AM : [          IR]     02AA Press
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 2] Start : Adding device to ISY
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 2] Finish : Adding device to ISY was Successful
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 3] Start : Adding device to ISY
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 3] Finish : Adding device to ISY was Successful
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 4] Start : Adding device to ISY
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 4] Finish : Adding device to ISY was Successful
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 5] Start : Adding device to ISY
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 5] Finish : Adding device to ISY was Successful
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 6] Start : Adding device to ISY
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 6] Finish : Adding device to ISY was Successful
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 7] Start : Adding device to ISY
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 7] Finish : Adding device to ISY was Successful
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 8] Start : Adding device to ISY
Tue 10/18/2011 01:51:45 AM : [FrntIrrCtr9C. - 8] Finish : Adding device to ISY was Successful
Tue 10/18/2011 01:51:45 AM : [  19 AD 9C 1]       ST   0
Tue 10/18/2011 01:51:46 AM : [  19 AD 9C 1] Device added to ISY
Tue 10/18/2011 01:51:47 AM : ---- All Remaining Device Added ----
Thanks and sorry about the long post, but I don't know how to read these logs that well yet.
The Simplehomenet devices cannot be Auto Discovered. Delete the EZFlora and add it back using New INSTEON Device selecting EZFlora from the Device Type pulldown. Use the latest EZFlora with the v28 level firmware.
EDIT: The trace is showing many IR commands. Was there IR activity going on at the time the EZFLora was being added? Also note the Event Trace should be set to “Device communications events†when tracing a SHN device add. The default level shows the final conclusion but not why that conclusion was reached.
Thank you, but my second trace was from having done just that. the EZFlora did not link properly. I will try again with the trace set at the level you suggest and post results.
I don't believe so. I wondered what all the entries were and if they could be overloading the system. How can I figure out where they are coming from? Could the compact flourescents be sending out IR noise? Can I turn off IR responses in the ISY or PLM?
Opaque tape over the IR sensor on the front of the ISY ...
Yes, I thought of that, seems crude, but effective . Will do so just to simplify things.
I again factory reset the new EZFlora, deleted it from the ISY and readded using its address (1 DB DF)
and selecting "EZFlora...." from the device list. Linking failed as before:
Tue 10/18/2011 08:47:29 PM : ---- Initializing the linked devices ----
Tue 10/18/2011 08:47:29 PM : ---- All Linked Devices are now initialized ----
Tue 10/18/2011 08:47:29 PM : ---- Add remaining devices ----
Tue 10/18/2011 08:47:29 PM : [   1 DB DF 1] Removing all links
Tue 10/18/2011 08:47:53 PM : [1 DB DF 1   ] i2 data transfer commands do not work. Reverting to i1
<... removed lines concerning weather module feed...>
Tue 10/18/2011 08:48:17 PM : [   1 DB DF 1] ** Not added ** Remove Device Links failed
Tue 10/18/2011 08:48:17 PM : ---- All Remaining Device Added ----
Tue 10/18/2011 08:48:17 PM : [All         ] Writing 0 bytes to devices
Tue 10/18/2011 08:48:43 PM : [          IR]     0155 Press
Tue 10/18/2011 08:48:49 PM : [          IR]     016A Press
Tue 10/18/2011 08:49:02 PM : [  19 AD 9C 1]       ST 255
Tue 10/18/2011 08:49:15 PM : [  19 AD 9C 1]       ST   0
Tue 10/18/2011 08:49:19 PM : [  19 AD 9C 3]       ST 255
Tue 10/18/2011 08:49:26 PM : [  19 AD 9C 3]       ST   0
<... removed lines from weather module...>
Tue 10/18/2011 08:49:31 PM : [  19 AD 9C 4]       ST 255
Tue 10/18/2011 08:49:33 PM : [          IR]     014A Press
Tue 10/18/2011 08:49:41 PM : [          IR]     0154 Press
Tue 10/18/2011 08:49:43 PM : [          IR]     016A Press
Tue 10/18/2011 08:49:51 PM : [  19 AD 9C 4]       ST   0
Tue 10/18/2011 08:50:08 PM : [          IR]     0155 Press
Tue 10/18/2011 08:50:30 PM : [          IR]     016A Press
Tue 10/18/2011 08:50:50 PM : [          IR]     02D5 Press
Tue 10/18/2011 08:50:52 PM : [          IR]     0155 Press
Tue 10/18/2011 08:51:10 PM : [          IR]     014A Press
Tue 10/18/2011 08:51:10 PM : ---- Initializing the linked devices ----
Tue 10/18/2011 08:51:10 PM : ---- All Linked Devices are now initialized ----
Tue 10/18/2011 08:51:10 PM : ---- Add remaining devices ----
Tue 10/18/2011 08:51:10 PM : [   1 DB DF 1] Reading all links
Tue 10/18/2011 08:51:14 PM : [          IR]     0155 Press
Tue 10/18/2011 08:51:17 PM : [          IR]     02AA Press
Tue 10/18/2011 08:51:27 PM : [          IR]     012A Press
Tue 10/18/2011 08:51:29 PM : [          IR]     016A Press
Tue 10/18/2011 08:51:35 PM : [          IR]     016A Press
Tue 10/18/2011 08:51:35 PM : [1 DB DF 1   ] i2 data transfer commands do not work. Reverting to i1
Tue 10/18/2011 08:51:39 PM : [          IR]     02AA Press
Tue 10/18/2011 08:51:45 PM : [          IR]     012A Press
Tue 10/18/2011 08:51:58 PM : [   1 DB DF 1] ** Not added ** Read device links failed
Tue 10/18/2011 08:51:58 PM : ---- All Remaining Device Added ----
Tue 10/18/2011 08:51:58 PM : ---- Start: Generate Scenes from links ----
Tue 10/18/2011 08:51:59 PM : ---- End:   Generate Scenes from links ----
Tue 10/18/2011 08:51:59 PM : [All         ] Writing 0 bytes to devices
BTW, 19 AD 9C is the address of the older, working EZFlora V.00(but it is not controllable via scenes)
This message is terminal.
The only thing a v28 EZFlora supports are I2 commands. The Event Trace was not run with Device communications events so there is no more information in this trace than the one before. Suggest moving the EZFlora to the same circuit as the ISY PLM and add it again with the Event Viewer set to Device communications events so actual commands and responses can be seen,
There are still IR messages being generated. Suggest sending an email to UDI support with the last event viewer trace attached that had the IR sensor covered. Explain that the IR sensor was covered and still seeing IR events.
OK, taped over IR port and Ir commands seem gone.
PLM and The EZFlora are on same outlet.
Here is trace set to Comm events (which I guess I did not do last time).
looks like the EZFlora is not responding to i2 commands, so I guess it is defective.
Tue 10/18/2011 10:16:43 PM : ---- Initializing the linked devices ----
Tue 10/18/2011 10:16:43 PM : ---- All Linked Devices are now initialized ----
Tue 10/18/2011 10:16:43 PM : ---- Add remaining devices ----
Tue 10/18/2011 10:16:43 PM : [] Calculating EZRain Address Offset
Tue 10/18/2011 10:16:43 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 0F 00 06          PING   (00)
Tue 10/18/2011 10:16:43 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 0F 3F    PING   (3F)
Tue 10/18/2011 10:16:43 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:16:43 PM : [] EZRain Offset at 3F
Tue 10/18/2011 10:16:43 PM : [   1 DB DF 1] Removing all links
Tue 10/18/2011 10:16:43 PM : [1 DB DF 1   ] Querying engine version
Tue 10/18/2011 10:16:43 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 0D 00 06                 (00)
Tue 10/18/2011 10:16:43 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 0D 01           (01)
Tue 10/18/2011 10:16:43 PM : [1 DB DF 1   ] Retrieved engine version is i2
Tue 10/18/2011 10:16:43 PM : [1 DB DF 1   ] Calibrating engine version ensuring support for i2
Tue 10/18/2011 10:16:43 PM : [] EZxx start address at 3FFF
Tue 10/18/2011 10:16:44 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:16:44 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:16:44 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:16:53 PM : [] EZxx start address at 3FFF
Tue 10/18/2011 10:16:53 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:16:54 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:16:54 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:17:03 PM : [] EZxx start address at 3FFF
Tue 10/18/2011 10:17:03 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:17:03 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:17:03 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:17:07 PM : [1 DB DF 1   ] i2 data transfer commands do not work. Reverting to i1
Tue 10/18/2011 10:17:07 PM : [1 DB DF 1   ] Using engine version i2
Tue 10/18/2011 10:17:07 PM : [] EZxx start address at 3FFF
Tue 10/18/2011 10:17:07 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:17:08 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 23 2F 00           (00)
Tue 10/18/2011 10:17:08 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Tue 10/18/2011 10:17:17 PM : [] EZxx start address at 3FFF
Tue 10/18/2011 10:17:17 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:17:17 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:17:17 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:17:26 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Tue 10/18/2011 10:17:26 PM : [] EZxx start address at 3FFF
Tue 10/18/2011 10:17:26 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:17:27 PM : CLI-WBug: Successfully Processed WBug Response
Tue 10/18/2011 10:17:27 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:17:27 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:17:31 PM : [   1 DB DF 1] ** Not added ** Remove Device Links failed
Tue 10/18/2011 10:17:31 PM : ---- All Remaining Device Added ----
Tue 10/18/2011 10:17:31 PM : [All         ] Writing 0 bytes to devices
The EZFlora internal PLM is not responding with an Extended message. Was this an older EZFlora device that was upgraded with the latest v28 firmware and internal PLM update?
The following is a trace of a v28 EZFlora device add under 3.1.10. Note the 0251 Extended message that is missing in your trace.
Wed 10/19/2011 01:48:53 AM : [iNST-ACK ] 02 62 05.92.9E 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Wed 10/19/2011 01:48:54 AM : [iNST-SRX ] 02 50 05.92.9E 12.9F.E4 2B 2F 00 (00)
Wed 10/19/2011 01:48:54 AM : [standard-Direct Ack][05.92.9E-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 10/19/2011 01:48:54 AM : [iNST-ERX ] 02 51 05 92 9E 12 9F E4 1B 2F 00 00 01 3F FF 01 A2 44 12 9F E4 00 00 04 00
Thank you Lee, This was a refurbished unit bought Oct 11 as a backup so I could send in my other two older ones for upgrade to V.28
When I try adding it with 'auto discovery', it gets added and shows as an
EZRAIN/EZFLORA IRRIGATION CONTROLLER V.28
It responds to direct commands (turning on valves), but not in scenes.
In this trace,
- it adds with auto discovery,
- I send on / off commands to two of the zones,
- add it to a scene (which fails and red ! appear next to the device entry in the scene),
- then if I send an on command to the device entry in the scene, the red ! disappear and the normal blue drop symbols appear.
- I turn on the scene for zone 1 (FrntIrr.v1.On)
- the scene shows the zone on
- a Querry on the zone device entry returns that it is actually off
So perhaps this was an upgraded device that was not completely upgraded?
Tue 10/18/2011 10:45:30 PM : ---- Initializing the linked devices ----
Tue 10/18/2011 10:45:30 PM : ---- All Linked Devices are now initialized ----
Tue 10/18/2011 10:45:30 PM : ---- Add remaining devices ----
Tue 10/18/2011 10:45:30 PM : [   1 DB DF 1] Removing all links
Tue 10/18/2011 10:45:30 PM : [1 DB DF 1   ] Querying engine version
Tue 10/18/2011 10:45:30 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 0D 00 06                 (00)
Tue 10/18/2011 10:45:30 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 0D 01           (01)
Tue 10/18/2011 10:45:30 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:30 PM : [1 DB DF 1   ] Retrieved engine version is i2
Tue 10/18/2011 10:45:30 PM : [1 DB DF 1   ] Calibrating engine version ensuring support for i2
Tue 10/18/2011 10:45:31 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:45:31 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:45:31 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:40 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:45:41 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:45:41 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:50 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:45:50 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:45:50 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:54 PM : [1 DB DF 1   ] i2 data transfer commands do not work. Reverting to i1
Tue 10/18/2011 10:45:54 PM : [1 DB DF 1   ] Using engine version i1
Tue 10/18/2011 10:45:54 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 28 0F 06          SET-MSB(0F)
Tue 10/18/2011 10:45:54 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 28 0F    SET-MSB(0F)
Tue 10/18/2011 10:45:54 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:55 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 2B F8 06          PEEK   (F8)
Tue 10/18/2011 10:45:55 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2B 00    PEEK   (00)
Tue 10/18/2011 10:45:55 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:55 PM : [   1 DB DF 1] Adding device to ISY
Tue 10/18/2011 10:45:55 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 10 00 06          ID-REQ (00)
Tue 10/18/2011 10:45:55 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 10 00    ID-REQ (00)
Tue 10/18/2011 10:45:56 PM : [iNST-SRX    ] 02 50 01.DB.DF 04.00.28 8B 01 00           (00)
Tue 10/18/2011 10:45:56 PM : [standard-Broadcast][01.DB.DF-->04.00.28] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:56 PM : [ez] Start : Adding device to ISY
Tue 10/18/2011 10:45:56 PM : [ez] Finish : Adding device to ISY was Successful
Tue 10/18/2011 10:45:56 PM : [ez] Calculating EZRain Address Offset
Tue 10/18/2011 10:45:56 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 0F 00 06          PING   (00)
Tue 10/18/2011 10:45:56 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 0F 3F    PING   (3F)
Tue 10/18/2011 10:45:56 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:56 PM : [ez] EZRain Offset at 3F
Tue 10/18/2011 10:45:56 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 44 09 06                 (09)
Tue 10/18/2011 10:45:56 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 44 00           (00)
Tue 10/18/2011 10:45:57 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 44 02 06                 (02)
Tue 10/18/2011 10:45:57 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 44 00           (00)
Tue 10/18/2011 10:45:57 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:57 PM : [ez - 2] Start : Adding device to ISY
Tue 10/18/2011 10:45:57 PM : [ez - 2] Finish : Adding device to ISY was Successful
Tue 10/18/2011 10:45:57 PM : [ez - 2] Calculating EZRain Address Offset
Tue 10/18/2011 10:45:57 PM : [ez - 3] Start : Adding device to ISY
Tue 10/18/2011 10:45:57 PM : [ez - 3] Finish : Adding device to ISY was Successful
Tue 10/18/2011 10:45:57 PM : [ez - 3] Calculating EZRain Address Offset
Tue 10/18/2011 10:45:57 PM : [ez - 4] Start : Adding device to ISY
Tue 10/18/2011 10:45:57 PM : [ez - 4] Finish : Adding device to ISY was Successful
Tue 10/18/2011 10:45:57 PM : [ez - 4] Calculating EZRain Address Offset
Tue 10/18/2011 10:45:57 PM : [ez - 5] Start : Adding device to ISY
Tue 10/18/2011 10:45:57 PM : [ez - 5] Finish : Adding device to ISY was Successful
Tue 10/18/2011 10:45:57 PM : [ez - 5] Calculating EZRain Address Offset
Tue 10/18/2011 10:45:57 PM : [ez - 6] Start : Adding device to ISY
Tue 10/18/2011 10:45:57 PM : [ez - 6] Finish : Adding device to ISY was Successful
Tue 10/18/2011 10:45:57 PM : [ez - 6] Calculating EZRain Address Offset
Tue 10/18/2011 10:45:57 PM : [ez - 7] Start : Adding device to ISY
Tue 10/18/2011 10:45:57 PM : [ez - 7] Finish : Adding device to ISY was Successful
Tue 10/18/2011 10:45:57 PM : [ez - 7] Calculating EZRain Address Offset
Tue 10/18/2011 10:45:57 PM : [ez - 8] Start : Adding device to ISY
Tue 10/18/2011 10:45:57 PM : [ez - 8] Finish : Adding device to ISY was Successful
Tue 10/18/2011 10:45:57 PM : [ez - 8] Calculating EZRain Address Offset
Tue 10/18/2011 10:45:57 PM : [   1 DB DF 1]       ST   0
Tue 10/18/2011 10:45:58 PM : [   1 DB DF 1] Device added to ISY
Tue 10/18/2011 10:45:59 PM : ---- All Remaining Device Added ----
Tue 10/18/2011 10:45:59 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 44 02 06                 (02)
Tue 10/18/2011 10:45:59 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 44 00           (00)
Tue 10/18/2011 10:45:59 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:45:59 PM : [All         ] Writing 72 bytes to devices
Tue 10/18/2011 10:45:59 PM : [   1 DB DF 1]       ST   0
Tue 10/18/2011 10:45:59 PM : [   1 DB DF 2]       ST   0
Tue 10/18/2011 10:45:59 PM : [   1 DB DF 3]       ST   0
Tue 10/18/2011 10:45:59 PM : [   1 DB DF 4]       ST   0
Tue 10/18/2011 10:45:59 PM : [   1 DB DF 5]       ST   0
Tue 10/18/2011 10:45:59 PM : [   1 DB DF 6]       ST   0
Tue 10/18/2011 10:45:59 PM : [   1 DB DF 7]       ST   0
Tue 10/18/2011 10:45:59 PM : [   1 DB DF 8]       ST   0
Tue 10/18/2011 10:48:35 PM : [iNST-SRX    ] 02 50 16.62.30 00.00.01 C7 11 00    LTONRR (00)
Tue 10/18/2011 10:48:35 PM : [standard-Group][16.62.30-->Group=1] Max Hops=3, Hops Left=1
Tue 10/18/2011 10:48:35 PM : [  16 62 30 1]      DON   0
Tue 10/18/2011 10:48:35 PM : [  16 62 30 1]       ST 255
Tue 10/18/2011 10:48:35 PM : [  15 F0 43 1]       ST 255
Tue 10/18/2011 10:48:35 PM : [  17 A4 2A 1]       ST 255
Tue 10/18/2011 10:48:35 PM : [  17 A4 2A 2]       ST 255
Tue 10/18/2011 10:48:36 PM : [iNST-SRX    ] 02 50 16.62.30 13.1F.73 41 11 01    LTONRR (01)
Tue 10/18/2011 10:48:36 PM : [standard-Cleanup][16.62.30-->ISY/PLM Group=1] Max Hops=1, Hops Left=0
Tue 10/18/2011 10:48:36 PM : [iNST-SRX    ] 02 50 16.62.30 13.1F.73 42 11 01    LTONRR (01)
Tue 10/18/2011 10:48:36 PM : [standard-Cleanup][16.62.30-->ISY/PLM Group=1] Max Hops=2, Hops Left=0
Tue 10/18/2011 10:48:36 PM : [  16 62 30 1]      DON   1
Tue 10/18/2011 10:49:18 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 40 01 06                 (01)
Tue 10/18/2011 10:49:18 PM : [   1 DB DF 2]       ST 255
Tue 10/18/2011 10:49:18 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 40 81           (81)
Tue 10/18/2011 10:49:18 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:49:33 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 41 01 06                 (01)
Tue 10/18/2011 10:49:33 PM : [   1 DB DF 2]       ST   0
Tue 10/18/2011 10:49:33 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 41 01           (01)
Tue 10/18/2011 10:49:33 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:49:46 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 40 00 06                 (00)
Tue 10/18/2011 10:49:46 PM : [   1 DB DF 1]       ST 255
Tue 10/18/2011 10:49:46 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 40 80           (80)
Tue 10/18/2011 10:49:46 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:49:54 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 41 00 06                 (00)
Tue 10/18/2011 10:49:54 PM : [   1 DB DF 1]       ST   0
Tue 10/18/2011 10:49:54 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 41 00           (00)
Tue 10/18/2011 10:49:54 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:50:20 PM : [ez] Start : Adding to scene 'FrntIrr.v1.On'
Tue 10/18/2011 10:50:20 PM : [ez] Making 'FrntIrr.v1.On' a Controller
Tue 10/18/2011 10:50:20 PM : [MNG-LNK-RSP ] 02 6F 40 E2 16 01 DB DF 04 00 28 06
Tue 10/18/2011 10:50:20 PM : [1 DB DF 1   ] Link    0 : 0FF8 [A216131F73000000] Saving  [A216131F73000000]
Tue 10/18/2011 10:50:20 PM : [ez] Finish : Adding to scene 'FrntIrr.v1.On' was Successful
Tue 10/18/2011 10:50:20 PM : [All         ] Writing 72 bytes to devices
Tue 10/18/2011 10:50:20 PM : [1 DB DF 1   ] Using engine version i2 for 'ez'
Tue 10/18/2011 10:50:20 PM : [1 DB DF 1   ] Link    0 : 0FF8 [A216131F73000000] Writing [A216131F73000000]
Tue 10/18/2011 10:50:20 PM : [ez] EZxx start address at 3FFF
Tue 10/18/2011 10:50:20 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:50:21 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:50:21 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:50:30 PM : [ez] EZxx start address at 3FFF
Tue 10/18/2011 10:50:30 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:50:30 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:50:30 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:50:39 PM : [ez] EZxx start address at 3FFF
Tue 10/18/2011 10:50:39 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:50:40 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:50:40 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:50:44 PM : [1 DB DF 1   ] Link    0 : 0FF8 [A216131F73000000] *Failed Writing [A216131F73000000]
Tue 10/18/2011 10:50:44 PM : [1 DB DF 2   ] Using engine version i2 for 'ez - 2'
Tue 10/18/2011 10:50:44 PM : [1 DB DF 2   ] Link    0 : 0FF8 [A216131F73000000] Writing [A216131F73000000]
Tue 10/18/2011 10:50:44 PM : [ez] EZxx start address at 3FFF
Tue 10/18/2011 10:50:44 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:50:44 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:50:44 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:50:53 PM : [ez] EZxx start address at 3FFF
Tue 10/18/2011 10:50:53 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:50:54 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:50:54 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:51:03 PM : [ez] EZxx start address at 3FFF
Tue 10/18/2011 10:51:03 PM : [iNST-ACK    ] 02 62 01.DB.DF 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Tue 10/18/2011 10:51:03 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 2F 00           (00)
Tue 10/18/2011 10:51:03 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:51:07 PM : [1 DB DF 2   ] Link    0 : 0FF8 [A216131F73000000] *Failed Writing [A216131F73000000]
Tue 10/18/2011 10:51:26 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 40 00 06                 (00)
Tue 10/18/2011 10:51:26 PM : [   1 DB DF 1]       ST 255
Tue 10/18/2011 10:51:26 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 40 80           (80)
Tue 10/18/2011 10:51:26 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:51:29 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 41 00 06                 (00)
Tue 10/18/2011 10:51:29 PM : [   1 DB DF 1]       ST   0
Tue 10/18/2011 10:51:30 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 41 00           (00)
Tue 10/18/2011 10:51:30 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:51:58 PM : [iNST-ACK    ] 02 62 00.00.16 CF 11 00 06          LTONRR (00)
Tue 10/18/2011 10:51:58 PM : [  17 A5 92 6]       ST 255
Tue 10/18/2011 10:51:58 PM : [   1 DB DF 1]       ST 255
Tue 10/18/2011 10:52:20 PM : [iNST-ACK    ] 02 62 01.DB.DF 0F 44 02 06                 (02)
Tue 10/18/2011 10:52:20 PM : [iNST-SRX    ] 02 50 01.DB.DF 13.1F.73 2B 44 00           (00)
Tue 10/18/2011 10:52:20 PM : [standard-Direct Ack][01.DB.DF-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 10/18/2011 10:52:20 PM : [   1 DB DF 1]       ST   0
Cannot use Auto Discover. I deleted and added my v28 using Auto Discover and the link records are written in the wrong location. Note the 0FFF address is used. It should be 3FFF. The link records are not written in the correct location unless the Device Type is actually specified. Direct commands work because they are not dependent on link records. Scenes will not work because they are dependent on link records written in the wrong location when the Device Type is not specified as an SHN device.
Thanks Lee, I only tried adding it in auto discovery to test if it was responding to direct commands. Am I correct in thinking that this unit is not fully upgraded to v.28 or is something wrong with its hardware?
I've emailed SHN about sending it back for a replacement with my older units for upgrading.
cheers
I suspect the EZFlora firmware has been updated to v28 but the internal PLM does not support I2 commands. Likely works fine where links are being established with the Set button. A new EZFlora comes with v28 firmware and a PLM that supports I2 commands.
      37.1k
      371.5k
