November 23, 201114 yr Hello I have a quick question.Is there a way to refresh ISY beside closing it and restarting? Thanks Tim
November 23, 201114 yr Refresh? What is not happening that needs a refresh? Are you running any Anti virus or Firewall software? If you are. What program and revision. We know that the latest Avast Free causes problems with the ISY99i displaying things and have fixes for it. Zone Alarm also needs a entry in the Trusted Zone for the IP address being used.
November 23, 201114 yr I know what he is talking about. Sometimes the java console just looses it's connection. It only happens when the java console has been running for a long time, like a day or two. As far as I know, no, when it looses it's comm, you just have to shut it down and re-open. If you are loosing comm often, then you should look into the cause of that, not how to refresh out of it. I have also noticed that sometimes the java consolue starts eating up processor. Again, only if it is up for a long time. Perhaps it has some endless loop running away. If I notice that my fan has kicked into high gear, I will check the task manager and see that java is running the processor at 50% or more. I shut it down and re-open fixing the issue.
