AT&T to end email-to-text ×
Program using
bmercier
Hi,
I believe I found a bug in the triggering of programs using an Elk zone input.
When I test a zone for "Violated", the program gets triggered when the zone changes from "Violated" to "Normal", as opposed to "Normal" to "Violated".
Example:
       Elk Zone 'Entree' is Violated
The following program will run the "Then" only when the door gets closed (returning to Normal, or Closed).
When I look at the Elk tab, the zone gets violated when the door is opened, as it should be.
I'm using 3.1.13.
Benoit.
Hi Benoit,
If the status of that zone changes at all then then program will run either the then or else path depending on whether the if condition evaluates to true or false.
For example, when the zone goes to Violated, it will run the Then path, when it goes back to Normal (or any status other than Violated), it will run the else path.
Hi Chris,
I apologize, You are absolutely right. It works perfectly.
I should have done more testing. I had other conditions that messed it up.
Benoit.
