ISY-26 Problem
My ISY-26 has been working OK for some time, but now it's developed some issues:
1.) Everything under "Devices" works correctly and reports the correct status of devices.
2.) Under the Admin Console, the status of all devices is blank. All devices have ramp rate 9 min and on level 0%
3.) I can add and remove devices from scenes. Changing the on level, ramp rate has no effect.
4.) I have tried unplugging both ISY and the PLM.
5.) Enabling / Disabling programs takes many tries to see any effect.
6.) All programs, scenes, etc are working correctly.
Do you have a firewall or anti virus that recently updated?
I know that Avast 6.0.1289 made some problems for me and there are a few threads here on what fixes we found out.
Here is one of the threads.
viewtopic.php?f=3&t=6933
I am in fact running AVAST 6.0.1289. I'll research when I get more time tonight.
Unfortunately I tried all the recommended solutions and even disabling Avast web scanning temporarily and still no luck. I'm wondering if this is a Java issue? I seem to have 1.6.0
Hello mdcastle,
If your ISY's firmware version is at 2.7.15, then please try the following URL:
http://www.universal-devices.com/99i/admin.jnlp
Once loaded, click on the Add button on ISY Finder and then enter the HTTPS IP address for your isy (i.e https://your.isy.ip.address) and retry.
Also, what do you see when you to go Tools | Diagnostics | PLM Status/Info?
When I click on the link it loads the Admin Console and I don't see anything that looks like "ISY Finder".
PLM status is "9.39BD v52 / Connected"
Firmware is in fact 2.7.15
Regards, Monte
