New plm and remotelinc no longer seen
Replaced 2412s plm with 2413s. Restored modem (Link Management>Advanced Options>Automatic). So far everything except for RemoteLinc (2440) is working fine.
I have one triggerlinc which I restored after the modem restore and it works fine giving the proper status/program runs in ISY.
I ran Restore on the Remotelinc however the ISY doesn't see the status of any buttons. I tried deleting/re-adding to the ISY and still no luck.
I reverted back to the last good backup before the plm change, then ran Restore Modem again. Restored triggerlinc again, then tried restoring the remotelinc. Triggerlinc worked fine again but Remotelinc didn't.
The remotelinc address is 0A.27.23
The modem (2413s v98) address is 19.73.42
ISY IR PRo v3.1.13
Here is the viewer for the remotelinc restore:
Thu 12/01/2011 04:03:58 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:03:58 PM : [   A 27 23 1] Preparing Device 'Office RL 1 Ceil Lit' for Restore
Thu 12/01/2011 04:03:58 PM : [   A 27 23 1] Device 'Office RL 1 Ceil Lit' ready for Full Restore
Thu 12/01/2011 04:03:58 PM : [All         ] Writing 72 bytes to devices
Thu 12/01/2011 04:03:58 PM : [A 27 23 1   ] Link    9 : 0FB0 [0000000000000000] Writing [00..............]
Thu 12/01/2011 04:03:58 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:03:59 PM : [VAR  2   25 ]       0
Thu 12/01/2011 04:03:59 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:03:59 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:03:59 PM : [VAR  2   19 ]       0
Thu 12/01/2011 04:03:59 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B B0 06          PEEK   (B0)
Thu 12/01/2011 04:03:59 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:03:59 PM : [A 27 23 1   ] Link   10 : 0FA8 : Writing High Water Byte
Thu 12/01/2011 04:03:59 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:00 PM : [VAR  2   31 ]       0
Thu 12/01/2011 04:04:00 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:00 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:01 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:04:01 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B A8 06          PEEK   (A8)
Thu 12/01/2011 04:04:01 PM : [VAR  2   35 ]       0
Thu 12/01/2011 04:04:01 PM : [VAR  2   78 ]       185
Thu 12/01/2011 04:04:01 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:01 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:01 PM : [VAR  2   11 ]       1
Thu 12/01/2011 04:04:01 PM : [VAR  2   80 ]       122
Thu 12/01/2011 04:04:01 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:04:01 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:04:01 PM : [A 27 23 1   ] Link    0 : 0FF8 [E201128F3A000001] Writing [E201128F3A000001]
Thu 12/01/2011 04:04:01 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:01 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:01 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F8 06          PEEK   (F8)
Thu 12/01/2011 04:04:01 PM : [VAR  2   35 ]       1
Thu 12/01/2011 04:04:01 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 02    PEEK   (02)
Thu 12/01/2011 04:04:02 PM : [VAR  2   31 ]       1
Thu 12/01/2011 04:04:02 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 29 E2 06          POKE   (E2)
Thu 12/01/2011 04:04:02 PM : [VAR  2    8 ]       1
Thu 12/01/2011 04:04:02 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 29 E2    POKE   (E2)
Thu 12/01/2011 04:04:02 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:02 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F9 06          PEEK   (F9)
Thu 12/01/2011 04:04:03 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 01    PEEK   (01)
Thu 12/01/2011 04:04:03 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:03 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:03 PM : [VAR  2   31 ]       0
Thu 12/01/2011 04:04:03 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:03 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B FA 06          PEEK   (FA)
Thu 12/01/2011 04:04:04 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 12    PEEK   (12)
Thu 12/01/2011 04:04:04 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:04 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:04 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:04 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B FB 06          PEEK   (FB)
Thu 12/01/2011 04:04:05 PM : [VAR  2  190 ]       1
Thu 12/01/2011 04:04:05 PM : [VAR  2   19 ]       1
Thu 12/01/2011 04:04:05 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 8F    PEEK   (8F)
Thu 12/01/2011 04:04:05 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:05 PM : [VAR  2   11 ]       0
Thu 12/01/2011 04:04:05 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:06 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:04:06 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:06 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:06 PM : [VAR  2   90 ]       73
Thu 12/01/2011 04:04:06 PM : [VAR  2   80 ]       120
Thu 12/01/2011 04:04:06 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B FC 06          PEEK   (FC)
Thu 12/01/2011 04:04:06 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:04:06 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 3A    PEEK   (3A)
Thu 12/01/2011 04:04:06 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:07 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B FD 06          PEEK   (FD)
Thu 12/01/2011 04:04:07 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:07 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:07 PM : [VAR  2   35 ]       0
Thu 12/01/2011 04:04:07 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:07 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:08 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B FE 06          PEEK   (FE)
Thu 12/01/2011 04:04:08 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:08 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:08 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:08 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:09 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B FF 06          PEEK   (FF)
Thu 12/01/2011 04:04:09 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 01    PEEK   (01)
Thu 12/01/2011 04:04:09 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:09 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:04:09 PM : [A 27 23 1   ] Link    1 : 0FF0 [E201197342000001] Writing [E201197342000001]
Thu 12/01/2011 04:04:09 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:09 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:10 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F0 06          PEEK   (F0)
Thu 12/01/2011 04:04:10 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 02    PEEK   (02)
Thu 12/01/2011 04:04:10 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:10 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 29 E2 06          POKE   (E2)
Thu 12/01/2011 04:04:11 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:04:11 PM : [VAR  2   90 ]       72
Thu 12/01/2011 04:04:11 PM : [VAR  2  190 ]       -1
Thu 12/01/2011 04:04:11 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 29 E2    POKE   (E2)
Thu 12/01/2011 04:04:11 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:11 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F1 06          PEEK   (F1)
Thu 12/01/2011 04:04:11 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:04:11 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 01    PEEK   (01)
Thu 12/01/2011 04:04:11 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:12 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:12 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:12 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F2 06          PEEK   (F2)
Thu 12/01/2011 04:04:12 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 19    PEEK   (19)
Thu 12/01/2011 04:04:12 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:13 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:13 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:13 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F3 06          PEEK   (F3)
Thu 12/01/2011 04:04:13 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 73    PEEK   (73)
Thu 12/01/2011 04:04:13 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:14 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:14 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:14 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F4 06          PEEK   (F4)
Thu 12/01/2011 04:04:14 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 42    PEEK   (42)
Thu 12/01/2011 04:04:14 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:15 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:15 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:15 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F5 06          PEEK   (F5)
Thu 12/01/2011 04:04:15 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:15 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:16 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:16 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:16 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:04:16 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F6 06          PEEK   (F6)
Thu 12/01/2011 04:04:16 PM : [VAR  2   80 ]       122
Thu 12/01/2011 04:04:16 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:16 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:17 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:04:17 PM : [VAR  2    8 ]       -1
Thu 12/01/2011 04:04:17 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:17 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:17 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B F7 06          PEEK   (F7)
Thu 12/01/2011 04:04:17 PM : [VAR  2  190 ]       1
Thu 12/01/2011 04:04:18 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 27 2B 01    PEEK   (01)
Thu 12/01/2011 04:04:18 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 12/01/2011 04:04:18 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 0A 27 23 00 05 00 06
Thu 12/01/2011 04:04:18 PM : [PLM         ] Group   1 : Writing Responder Link matching [A 27 23 1   ] Link    1 : 0FF0 [E201197342000001]
Thu 12/01/2011 04:04:18 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:04:18 PM : [A 27 23 1   ] Link    2 : 0FE8 [E2021292FB000002] Writing [E2021292FB000002]
Thu 12/01/2011 04:04:18 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:19 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:19 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:19 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E8 06          PEEK   (E8)
Thu 12/01/2011 04:04:19 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B E2    PEEK   (E2)
Thu 12/01/2011 04:04:19 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:20 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:20 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:20 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E9 06          PEEK   (E9)
Thu 12/01/2011 04:04:20 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 02    PEEK   (02)
Thu 12/01/2011 04:04:20 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:21 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:21 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:21 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B EA 06          PEEK   (EA)
Thu 12/01/2011 04:04:21 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 12    PEEK   (12)
Thu 12/01/2011 04:04:21 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:04:21 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:21 PM : [VAR  2   80 ]       120
Thu 12/01/2011 04:04:22 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:22 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:22 PM : [VAR  2   35 ]       1
Thu 12/01/2011 04:04:22 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B EB 06          PEEK   (EB)
Thu 12/01/2011 04:04:22 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:04:22 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 92    PEEK   (92)
Thu 12/01/2011 04:04:22 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:23 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:23 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:23 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B EC 06          PEEK   (EC)
Thu 12/01/2011 04:04:23 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B FB    PEEK   (FB)
Thu 12/01/2011 04:04:23 PM : [VAR  2   26 ]       0
Thu 12/01/2011 04:04:23 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:23 PM : [VAR  2   19 ]       0
Thu 12/01/2011 04:04:24 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:24 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:24 PM : [VAR  2  190 ]       -1
Thu 12/01/2011 04:04:24 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B ED 06          PEEK   (ED)
Thu 12/01/2011 04:04:24 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:24 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:25 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:25 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:25 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B EE 06          PEEK   (EE)
Thu 12/01/2011 04:04:25 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:25 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:26 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:26 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:26 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B EF 06          PEEK   (EF)
Thu 12/01/2011 04:04:26 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 02    PEEK   (02)
Thu 12/01/2011 04:04:26 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:04:26 PM : [A 27 23 1   ] Link    3 : 0FE0 [E202197342000002] Writing [E202197342000002]
Thu 12/01/2011 04:04:26 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:27 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:27 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:27 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:04:27 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E0 06          PEEK   (E0)
Thu 12/01/2011 04:04:27 PM : [VAR  2   78 ]       184
Thu 12/01/2011 04:04:27 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B E2    PEEK   (E2)
Thu 12/01/2011 04:04:27 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:04:30 PM : [VAR  2  190 ]       1
Thu 12/01/2011 04:04:32 PM : [VAR  2    8 ]       1
Thu 12/01/2011 04:04:32 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:04:32 PM : [VAR  2   90 ]       73
Thu 12/01/2011 04:04:33 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:04:33 PM : [VAR  2   25 ]       1
Thu 12/01/2011 04:04:36 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:37 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:37 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:37 PM : [VAR  2  190 ]       -1
Thu 12/01/2011 04:04:37 PM : [VAR  2   25 ]       0
Thu 12/01/2011 04:04:37 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E1 06          PEEK   (E1)
Thu 12/01/2011 04:04:37 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 02    PEEK   (02)
Thu 12/01/2011 04:04:38 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:04:38 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:38 PM : [VAR  2   25 ]       1
Thu 12/01/2011 04:04:38 PM : [VAR  2   80 ]       121
Thu 12/01/2011 04:04:38 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:38 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:38 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E2 06          PEEK   (E2)
Thu 12/01/2011 04:04:38 PM : [VAR  2   35 ]       0
Thu 12/01/2011 04:04:38 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 19    PEEK   (19)
Thu 12/01/2011 04:04:38 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:04:39 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:39 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:39 PM : [VAR  2   25 ]       0
Thu 12/01/2011 04:04:39 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E3 06          PEEK   (E3)
Thu 12/01/2011 04:04:39 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 73    PEEK   (73)
Thu 12/01/2011 04:04:39 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:40 PM : [VAR  2   25 ]       1
Thu 12/01/2011 04:04:40 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:40 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:40 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E4 06          PEEK   (E4)
Thu 12/01/2011 04:04:40 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 42    PEEK   (42)
Thu 12/01/2011 04:04:40 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:41 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:41 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:41 PM : [        Time] 16:04:41 0(0)
Thu 12/01/2011 04:04:41 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E5 06          PEEK   (E5)
Thu 12/01/2011 04:04:41 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:41 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:42 PM : [VAR  2   35 ]       1
Thu 12/01/2011 04:04:42 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:42 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:42 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E6 06          PEEK   (E6)
Thu 12/01/2011 04:04:42 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:42 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:43 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:43 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:43 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:04:43 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B E7 06          PEEK   (E7)
Thu 12/01/2011 04:04:43 PM : [VAR  2  190 ]       1
Thu 12/01/2011 04:04:43 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 02    PEEK   (02)
Thu 12/01/2011 04:04:44 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:04:44 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 0A 27 23 00 05 00 06
Thu 12/01/2011 04:04:44 PM : [PLM         ] Group   2 : Writing Responder Link matching [A 27 23 1   ] Link    3 : 0FE0 [E202197342000002]
Thu 12/01/2011 04:04:44 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:04:44 PM : [A 27 23 1   ] Link    4 : 0FD8 [E203145408000003] Writing [E203145408000003]
Thu 12/01/2011 04:04:44 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:44 PM : [VAR  2   25 ]       0
Thu 12/01/2011 04:04:44 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:44 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:44 PM : [VAR  2   25 ]       1
Thu 12/01/2011 04:04:44 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D8 06          PEEK   (D8)
Thu 12/01/2011 04:04:45 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B E2    PEEK   (E2)
Thu 12/01/2011 04:04:45 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:45 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:45 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:45 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D9 06          PEEK   (D9)
Thu 12/01/2011 04:04:45 PM : [        Time] 16:04:45 0(0)
Thu 12/01/2011 04:04:46 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 03    PEEK   (03)
Thu 12/01/2011 04:04:46 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:46 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:46 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:46 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B DA 06          PEEK   (DA)
Thu 12/01/2011 04:04:47 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 14    PEEK   (14)
Thu 12/01/2011 04:04:47 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:47 PM : [VAR  2    8 ]       -1
Thu 12/01/2011 04:04:47 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:47 PM : [VAR  2   35 ]       0
Thu 12/01/2011 04:04:47 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:47 PM : [VAR  2   35 ]       1
Thu 12/01/2011 04:04:47 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B DB 06          PEEK   (DB)
Thu 12/01/2011 04:04:48 PM : [VAR  2   25 ]       0
Thu 12/01/2011 04:04:48 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 54    PEEK   (54)
Thu 12/01/2011 04:04:48 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:48 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:48 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:04:48 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:48 PM : [VAR  2   78 ]       185
Thu 12/01/2011 04:04:48 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B DC 06          PEEK   (DC)
Thu 12/01/2011 04:04:49 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 08    PEEK   (08)
Thu 12/01/2011 04:04:49 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:49 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:49 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:04:49 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:49 PM : [VAR  2   19 ]       1
Thu 12/01/2011 04:04:49 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B DD 06          PEEK   (DD)
Thu 12/01/2011 04:04:49 PM : [VAR  2  190 ]       -1
Thu 12/01/2011 04:04:50 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:50 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:50 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:50 PM : [VAR  2   42 ]       1
Thu 12/01/2011 04:04:50 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:50 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B DE 06          PEEK   (DE)
Thu 12/01/2011 04:04:51 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:51 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:51 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:51 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:51 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B DF 06          PEEK   (DF)
Thu 12/01/2011 04:04:51 PM : [VAR  2   35 ]       0
Thu 12/01/2011 04:04:52 PM : [VAR  2   42 ]       0
Thu 12/01/2011 04:04:52 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 03    PEEK   (03)
Thu 12/01/2011 04:04:52 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:52 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:04:52 PM : [A 27 23 1   ] Link    5 : 0FD0 [E203197342000003] Writing [E203197342000003]
Thu 12/01/2011 04:04:52 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:52 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:52 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D0 06          PEEK   (D0)
Thu 12/01/2011 04:04:53 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B E2    PEEK   (E2)
Thu 12/01/2011 04:04:53 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:53 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:53 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:53 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D1 06          PEEK   (D1)
Thu 12/01/2011 04:04:54 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:04:54 PM : [VAR  2   42 ]       1
Thu 12/01/2011 04:04:54 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 03    PEEK   (03)
Thu 12/01/2011 04:04:54 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:54 PM : [VAR  2   80 ]       120
Thu 12/01/2011 04:04:54 PM : [VAR  2   26 ]       1
Thu 12/01/2011 04:04:54 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:54 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:54 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D2 06          PEEK   (D2)
Thu 12/01/2011 04:04:55 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:04:55 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 19    PEEK   (19)
Thu 12/01/2011 04:04:55 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:55 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:55 PM : [VAR  2   42 ]       0
Thu 12/01/2011 04:04:55 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:55 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D3 06          PEEK   (D3)
Thu 12/01/2011 04:04:56 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 73    PEEK   (73)
Thu 12/01/2011 04:04:56 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:56 PM : [VAR  2  190 ]       1
Thu 12/01/2011 04:04:56 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:56 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:56 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D4 06          PEEK   (D4)
Thu 12/01/2011 04:04:57 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 42    PEEK   (42)
Thu 12/01/2011 04:04:57 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:57 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:57 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:57 PM : [VAR  2   26 ]       0
Thu 12/01/2011 04:04:57 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D5 06          PEEK   (D5)
Thu 12/01/2011 04:04:58 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:58 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:58 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:04:58 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:04:58 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D6 06          PEEK   (D6)
Thu 12/01/2011 04:04:59 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:04:59 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:04:59 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:04:59 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:00 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:00 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:00 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B D7 06          PEEK   (D7)
Thu 12/01/2011 04:05:00 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:05:00 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 03    PEEK   (03)
Thu 12/01/2011 04:05:00 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 0A 27 23 00 05 00 06
Thu 12/01/2011 04:05:00 PM : [PLM         ] Group   3 : Writing Responder Link matching [A 27 23 1   ] Link    5 : 0FD0 [E203197342000003]
Thu 12/01/2011 04:05:00 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:05:00 PM : [A 27 23 1   ] Link    6 : 0FC8 [E204197342000004] Writing [E204197342000004]
Thu 12/01/2011 04:05:01 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:01 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:01 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:01 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C8 06          PEEK   (C8)
Thu 12/01/2011 04:05:01 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B E2    PEEK   (E2)
Thu 12/01/2011 04:05:02 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:02 PM : [VAR  2    8 ]       1
Thu 12/01/2011 04:05:02 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:02 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:02 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C9 06          PEEK   (C9)
Thu 12/01/2011 04:05:02 PM : [VAR  2  190 ]       -1
Thu 12/01/2011 04:05:02 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 04    PEEK   (04)
Thu 12/01/2011 04:05:03 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:03 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:03 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:03 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B CA 06          PEEK   (CA)
Thu 12/01/2011 04:05:03 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 19    PEEK   (19)
Thu 12/01/2011 04:05:04 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:04 PM : [VAR  2   26 ]       1
Thu 12/01/2011 04:05:05 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:05:05 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:05 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:05 PM : [VAR  2   84 ]       68
Thu 12/01/2011 04:05:05 PM : [VAR  2   78 ]       184
Thu 12/01/2011 04:05:05 PM : [VAR  2   80 ]       122
Thu 12/01/2011 04:05:05 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B CB 06          PEEK   (CB)
Thu 12/01/2011 04:05:05 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 73    PEEK   (73)
Thu 12/01/2011 04:05:05 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:05 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:05:06 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B CC 06          PEEK   (CC)
Thu 12/01/2011 04:05:06 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 42    PEEK   (42)
Thu 12/01/2011 04:05:06 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:06 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:06 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:07 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B CD 06          PEEK   (CD)
Thu 12/01/2011 04:05:07 PM : [iNST-SRX    ] 02 50 12.8C.C2 00.00.01 CB 11 00    LTONRR (00)
Thu 12/01/2011 04:05:07 PM : [standard-Group][12.8C.C2-->Group=1] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:07 PM : [  12 8C C2 1]      DON   0
Thu 12/01/2011 04:05:07 PM : [  12 8C C2 1]       ST 255
Thu 12/01/2011 04:05:07 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:05:07 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:07 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:07 PM : [iNST-SRX    ] 02 50 12.8C.C2 19.73.42 4B 11 01    LTONRR (01)
Thu 12/01/2011 04:05:07 PM : [standard-Cleanup][12.8C.C2-->ISY/PLM Group=1] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:08 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:08 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:08 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B CE 06          PEEK   (CE)
Thu 12/01/2011 04:05:08 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:05:08 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:09 PM : [VAR  2  190 ]       1
Thu 12/01/2011 04:05:09 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:09 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:09 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B CF 06          PEEK   (CF)
Thu 12/01/2011 04:05:09 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 04    PEEK   (04)
Thu 12/01/2011 04:05:09 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:05:10 PM : [VAR  2   84 ]       69
Thu 12/01/2011 04:05:10 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 0A 27 23 00 05 00 06
Thu 12/01/2011 04:05:10 PM : [PLM         ] Group   4 : Writing Responder Link matching [A 27 23 1   ] Link    6 : 0FC8 [E204197342000004]
Thu 12/01/2011 04:05:10 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:05:10 PM : [A 27 23 1   ] Link    7 : 0FC0 [E205197342000005] Writing [E205197342000005]
Thu 12/01/2011 04:05:10 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:10 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:10 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:10 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C0 06          PEEK   (C0)
Thu 12/01/2011 04:05:11 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:05:11 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B E2    PEEK   (E2)
Thu 12/01/2011 04:05:11 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:11 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:11 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:12 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C1 06          PEEK   (C1)
Thu 12/01/2011 04:05:12 PM : [VAR  2   26 ]       0
Thu 12/01/2011 04:05:12 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 27 2B 05    PEEK   (05)
Thu 12/01/2011 04:05:12 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Thu 12/01/2011 04:05:12 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:12 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:12 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:13 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C2 06          PEEK   (C2)
Thu 12/01/2011 04:05:13 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 19    PEEK   (19)
Thu 12/01/2011 04:05:13 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:13 PM : [VAR  2   26 ]       1
Thu 12/01/2011 04:05:13 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 00 00 06                 (00)
Thu 12/01/2011 04:05:13 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 00 00           (00)
Thu 12/01/2011 04:05:15 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:05:15 PM : [VAR  2  190 ]       -1
Thu 12/01/2011 04:05:16 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:05:17 PM : [VAR  2    8 ]       -1
Thu 12/01/2011 04:05:20 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:05:20 PM : [VAR  2   80 ]       121
Thu 12/01/2011 04:05:22 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:05:22 PM : [VAR  2  190 ]       1
Thu 12/01/2011 04:05:22 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:23 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:23 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:23 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C3 06          PEEK   (C3)
Thu 12/01/2011 04:05:23 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 73    PEEK   (73)
Thu 12/01/2011 04:05:23 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:24 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:24 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:24 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C4 06          PEEK   (C4)
Thu 12/01/2011 04:05:24 PM : [VAR  2   26 ]       0
Thu 12/01/2011 04:05:25 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 42    PEEK   (42)
Thu 12/01/2011 04:05:25 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:25 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:25 PM : [VAR  2   19 ]       0
Thu 12/01/2011 04:05:25 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:25 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C5 06          PEEK   (C5)
Thu 12/01/2011 04:05:26 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:05:26 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:05:26 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:26 PM : [VAR  2   80 ]       120
Thu 12/01/2011 04:05:26 PM : [VAR  2   35 ]       1
Thu 12/01/2011 04:05:26 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:26 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:26 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C6 06          PEEK   (C6)
Thu 12/01/2011 04:05:27 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:05:27 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:27 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:27 PM : [VAR  2  269 ]       -1
Thu 12/01/2011 04:05:27 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:27 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B C7 06          PEEK   (C7)
Thu 12/01/2011 04:05:28 PM : [VAR  2  190 ]       -1
Thu 12/01/2011 04:05:28 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 05    PEEK   (05)
Thu 12/01/2011 04:05:28 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:28 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 0A 27 23 00 05 00 06
Thu 12/01/2011 04:05:28 PM : [PLM         ] Group   5 : Writing Responder Link matching [A 27 23 1   ] Link    7 : 0FC0 [E205197342000005]
Thu 12/01/2011 04:05:28 PM : [A 27 23 1   ] Using engine version i1 for 'Office RL 1 Ceil Lite'
Thu 12/01/2011 04:05:28 PM : [A 27 23 1   ] Link    8 : 0FB8 [E206197342000006] Writing [E206197342000006]
Thu 12/01/2011 04:05:29 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:29 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:29 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:29 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B B8 06          PEEK   (B8)
Thu 12/01/2011 04:05:29 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B E2    PEEK   (E2)
Thu 12/01/2011 04:05:30 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:30 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:30 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:30 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B B9 06          PEEK   (B9)
Thu 12/01/2011 04:05:30 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 06    PEEK   (06)
Thu 12/01/2011 04:05:31 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:31 PM : [VAR  2  114 ]       1
Thu 12/01/2011 04:05:31 PM : [VAR  2   84 ]       68
Thu 12/01/2011 04:05:31 PM : [VAR  2   78 ]       185
Thu 12/01/2011 04:05:31 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:31 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:31 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B BA 06          PEEK   (BA)
Thu 12/01/2011 04:05:32 PM : [VAR  2    8 ]       1
Thu 12/01/2011 04:05:32 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 19    PEEK   (19)
Thu 12/01/2011 04:05:32 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:32 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:32 PM : [VAR  2   25 ]       1
Thu 12/01/2011 04:05:32 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:32 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B BB 06          PEEK   (BB)
Thu 12/01/2011 04:05:33 PM : [VAR  2  269 ]       1
Thu 12/01/2011 04:05:33 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 73    PEEK   (73)
Thu 12/01/2011 04:05:33 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:33 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:33 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:33 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B BC 06          PEEK   (BC)
Thu 12/01/2011 04:05:34 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 42    PEEK   (42)
Thu 12/01/2011 04:05:34 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:34 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:34 PM : [VAR  2   25 ]       0
Thu 12/01/2011 04:05:34 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:35 PM : [VAR  2   25 ]       1
Thu 12/01/2011 04:05:35 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B BD 06          PEEK   (BD)
Thu 12/01/2011 04:05:35 PM : [VAR  2  190 ]       1
Thu 12/01/2011 04:05:35 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:05:35 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:35 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:35 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:35 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B BE 06          PEEK   (BE)
Thu 12/01/2011 04:05:36 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 00    PEEK   (00)
Thu 12/01/2011 04:05:36 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:36 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 28 0F 06          SET-MSB(0F)
Thu 12/01/2011 04:05:37 PM : [VAR  2  114 ]       -1
Thu 12/01/2011 04:05:37 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 28 0F    SET-MSB(0F)
Thu 12/01/2011 04:05:37 PM : [standard-Direct Ack][0A.27.23-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Thu 12/01/2011 04:05:37 PM : [VAR  2   84 ]       69
Thu 12/01/2011 04:05:37 PM : [VAR  2   25 ]       0
Thu 12/01/2011 04:05:37 PM : [VAR  2   78 ]       184
Thu 12/01/2011 04:05:37 PM : [VAR  2   80 ]       121
Thu 12/01/2011 04:05:37 PM : [iNST-ACK    ] 02 62 0A.27.23 0F 2B BF 06          PEEK   (BF)
Thu 12/01/2011 04:05:37 PM : [iNST-SRX    ] 02 50 0A.27.23 19.73.42 2B 2B 06    PEEK   (06)
Thu 12/01/2011 04:05:38 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 0A 27 23 00 05 00 06
Thu 12/01/2011 04:05:38 PM : [PLM         ] Group   6 : Writing Responder Link matching [A 27 23 1   ] Link    8 : 0FB8 [E206197342000006]
Any help is greatly appreciated.
Tim
Hi Tim,
What is the reported firmware version of your RL2? This has been reported by others as well. But, we just cannot reproduce it here.
Please note that RL2 buttons might not match the UI .. so, please use the Event Viewer to see if there is any traffic when you do actual button presses.
I believe that is a RemoteLinc, not a RemoteLinc2. The trace is showing I1 Peek/Poke to setup the RemoteLinc which is fine but would not work on a RemoteLinc2.
Hi LeeG,
Thanks so very much. The main issue is that we are getting increasing number of reports with RL/RL2 (and some KPLs) not reporting their status using dual band PLM. We did send a detailed report to SmartHome describing the situation which seems to be corrupted PLM database (addresses are filled with 00s).
Have not been using the v98 long enough to establish long term reliability. I switched to the v98 a few days ago when a different OP reported not being able to link a RemoteLinc2 which works fine with my v98.
Also I just added a RemoteLinc using the v98 and do not see the problem Tim is having with what I think is his RemoteLinc (not RL2).
Of course not everyone saw the tstat dongle problems even though several clearly existed.
Lee
Hi Guys, thanks for the input.
Lee, sorry yes it is an older RL not RL2 as you deduced.
I did some more checking this morning. The link tables for the devices linked to the RL match the ISY link tables. The Link tables for the RL match the ISY Link tables.
I could not find the RL address in the link table for the plm however. Mind you, I scanned thru the link table a couple of times looking for the address of the RL, but I didn’t analyze line by line so it could be in there and just missed it.
I deleted the RL this morning then re-added it got the same results. I linked it (thru the admin console)to a couple of devices just to test and it controlled the devices just fine. Interestingly (or maybe not) is that the device statuses, when turned on or off with the RL didn’t update in the ISY. The ISY didn’t see the scene being activated by the RL so it didn’t update the device status.
The light on the plm does not flash when the rl is operated either.
If there is any other info I can provide please let me know.
Based on Michel’s statement would there be a possibility the problem could be fixed by an ISY update or would it require sending the plm back for re-flashing? So at this point I am wondering if I should try and factory reset the plm then restore the plm, then re-link rl or just save myself from the agony and put the old 2412s back in until there is a fix for the 2413? The old one worked fine, thought I would just step into the 21st century.
What do you guys think?
Smarthome does not reflash devices. I added a RemoteLinc to my ISY this morning and see all the status updates as each button is pressed so I don't think 3.1.13 has an issue. There is nothing to lose by doing a factory reset of the PLM ONLY. I suspect the link records are not in the PLM. That is why no state changes are noted.
Now that I am under post I cannot see the beginning of the topic. Were there other devices added to the ISY that are not RF devices such that the I1 Peek/Poke would have been used for those.
TJF1960
There is another post with a similar RemoteLinc problem. Not sure about the PLM firmware level yet. Although the New INSTEON Device ran with no errors the link records were not present or not functional in the PLM. Required a PLM factory reset before the RemoteLinc would work. For whatever it may be worth.
Lee
Thanks Lee. I had been following that thread and decided to try your suggestion about factory resetting the plm and restore again. Same thing, everything but the RL updates the ISY status fields. Also noted that while the RL will still control scenes when a button is pressed the LED on the Remotelinc flashes indicating it didn’t receive the ack from the plm ( I am assuming, batteries are new btw).
So then I delete the RL from ISY, factory reset it and the plm. After the ISY rebooted and before I restored the plm I added the RL to the ISY. It worked fine! Status updated properly. I then created a couple of test scenes which also worked perfectly. Then I restored the plm. It all went to heck at that point. Everything but the RL updated status in the ISY.
As a last resort I deleted the RL, factory reset it and the plm again. After reboot I restored plm. Then added the RL. Still not go. Same as before.
So it would seem for some reason something happens to the RL address in the plm after restoring. Hopefully SH will get back to Michel with some news soon.
If you can think of anything else I can try please let me know.
Tim
TJF1960
The other RL problem was with a PLM that is very aged. Turns out it had nothing to do with a 2413 and associated firmware level. Have you counted the PLM links lately. Since it worked when the RL was the only thing defined the basic parts are working. I'm wondering if there is not a set of link records in the PLM that represented the RL at one time but got corrupted somehow and are not being erased when the RL is deleted.
If you can send me the file produced from a Save of the Show PLM Link Database and the address of the RL I'll see if I can find anything that looks odd. That file is very hard to analyze as all the information is in decimal. Made it easy for the programmer who implemented it but it sure makes it very difficult to use as a diagnostic tool!
I sent you my email address in a PM.
Lee
Thanks for the offer Lee. I just restored an earlier backup from before the new plm was added. As soon as the restore plm is finished I will copy the plm data and send it over to you.
Tim
Lee I sent the plm dump to you.
An update. Still using new dual band plm. I just installed 5 new devices. 2 new Icon SL, 1 older Icon dimmer and 2 new lamplinc dimmer dualband.
After linking all five to the ISY their status updates were not seen in the admin console. After restoring plm all but the 2 new Icon SL Relays updated status. Of course the RL still doesn't either.
Hi LeeG,
Hi Michel, LeeG
Have you heard anything from SmartLabs regarding this issue with the 2413s? I was not able to add a RL (not RL2) nor a couple of brand new from SH Icon SL Relays. I was able to add a couple of older Icon SL Dimmers though.
I have since put the old 2412s back with the ISY to run things but I am not sure whether to send the 2413s back because it is defective or quite what to do with it at this point.
As always,
Tim
Hi Tim,
Yes, there seems to be an issue with the PLM hanging intermittently in two cases:
1. RF devices
2. Larger installations (i.e. the number of links in the PLM is 300 and above) ... at least that's what we have observed
SmartHome is working on a solution and we are awaiting a resolution.
  • 3 weeks later...
1. RF devices
Hi Michel,
By chance, any updates from SmartLabs on this 2413s issue...
Tim
Thanks for the redirection to this post TJF1960,
It certainly appears that there is an issue with the V98 firmware given that Smarthome has released a V99 already.
This is very upsetting to me. The fact that Smarthome can release what appears to be a buggy firmware version and we have to be fortunate enough to read a post like this one to know we puchased a bad release?
In my case I have already disassembled that particular V98 PLM and made a slight modification anticipating making another test device using it. Looks like I am stuck with this turd.
May still make an ok tester but hopes to use it as a backup for my system PLM seem to have just gone down the drain.
