January 22, 200818 yr Michel or Chris, could you provide some information on the reading and interpretation of the results of the SM command in the ISY Shell? My current output is: http:///>SM Only displaying memory locations with at least on block used Cur Cur High Prev Diff Size Tot Free Used Used Used Used 24: 5328 3452 1876 1884 ( 1362) +514 32: 756 497 259 272 ( 259) 38: 65 51 14 14 ( 14) 66: 140 134 6 35 ( 16) -10 136: 300 299 1 189 ( 1) 170: 266 228 38 38 ( 30) +8 202: 4 2 2 2 ( 2) 1024: 26 25 1 9 ( 1) 1112: 13 0 13 13 ( 13) http:///>XS
January 24, 200818 yr This displays the current usage of some of the memory used by ISY. Its primarily intended as a development tool for us to help in debugging problems.
January 24, 200818 yr Hi JAJ, It would be very difficult to explain these numbers with the object using those memory blocks. In short, the first column is the size of memory block used (in bytes) and the rest is self explanatory. With kind regards, Michel Michel or Chris, could you provide some information on the reading and interpretation of the results of the SM command in the ISY Shell? My current output is: http:///>SM Only displaying memory locations with at least on block used Cur Cur High Prev Diff Size Tot Free Used Used Used Used 24: 5328 3452 1876 1884 ( 1362) +514 32: 756 497 259 272 ( 259) 38: 65 51 14 14 ( 14) 66: 140 134 6 35 ( 16) -10 136: 300 299 1 189 ( 1) 170: 266 228 38 38 ( 30) +8 202: 4 2 2 2 ( 2) 1024: 26 25 1 9 ( 1) 1112: 13 0 13 13 ( 13) http:///>XS
January 24, 200818 yr Author Thanks for the replies. Without giving much detail about each one, does this report give a good representation of the percentage of memory used within ISY? Ie. can it be used by the user to judge memory usage? For example, in the report above, it looks like roughly 50% is used.
January 24, 200818 yr Hi JAJ, Yes. For instance, you have used 228 nodes (170 byte blocks) and, as far as memory is concerned, you can support more programs. The rest are objects that are dynamically allocated and deallocated and are there only for debugging purposes. With kind regards, Michel Thanks for the replies. Without giving much detail about each one, does this report give a good representation of the percentage of memory used within ISY? Ie. can it be used by the user to judge memory usage? For example, in the report above, it looks like roughly 50% is used.
January 24, 200818 yr Author Excellent! So the 170-byte block line is the one the user is interested in, to keep an eye on memory usage. Thanks! Hi JAJ, Yes. For instance, you have used 228 nodes (170 byte blocks) and, as far as memory is concerned, you can support more programs. The rest are objects that are dynamically allocated and deallocated and are there only for debugging purposes. With kind regards, Michel Thanks for the replies. Without giving much detail about each one, does this report give a good representation of the percentage of memory used within ISY? Ie. can it be used by the user to judge memory usage? For example, in the report above, it looks like roughly 50% is used.
