December 22, 201113 yr I'm still on 3.1.14 and also experienced problems with incorrect Keypadlinc secondary button status. I'll be upgrading to 3.1.15 tonight to see if the upgrade also clears up the problem for me.
December 22, 201113 yr Author matapan, 3.1.15 will not fix that issue. 3.1.16 would. With kind regards, Michel
December 23, 201113 yr I don't know what has happened but my ISY has seriously just locked up and melted down. It will not let me restore from a back up. And pops up these Java error messages along with this one message I have never seen before. I do not have the ELK module or system. I do not have the MorningLinc etc. Teken . . . UPDATE: Well, it looks like something has given up the ghost. The ISY now says my login credentials are not authorized. I can not connect to the box what so ever . . . Right now its unplugged, along with the dual band PLM. Maybe it needs a good rest and a nap? Teken . . .
December 23, 201113 yr Author Hi Teken, I am so very sorry to hear. Please plug back in and observe the status of the lights on the front of the unit and report back. With kind regards, Michel
December 24, 201113 yr Ahhh, now my new dual-band InLine-Linc (2475SDB) works the way it should. Now I have to think what to do with programming I did (i.e. I had to use isy to control this inline directly - was not able to program it), since I like it Had to reboot (power off/on) ISY in order to make it behave properly.
December 25, 201113 yr Author Hello als223, Thanks so very much for the update! With kind regards, Michel
December 26, 201113 yr Ok since the update this program ran fine in version 3.1.12 the in version 3.1.13 became flaky and now in 3.1.15 run true then false then true the var alarmstate is set to 2 and the program still runs if i remove the main folder and place the program in the root of the tree it seems to work just fine. Just a fyi it seems if i have nested folders there seems to be a problem. Thank You Robert Folder Conditions for 'Sundown-11' Add conditions to limit when programs in this folder are allowed to run. If From Sunset To 11:00:00PM (same day) Then Allow the programs in this folder to run. If ( $AlarmState is 0 And $Bedroom_Chill is 0 ) And ( Status 'Masterbedroom / MasterBedroom:-Sensor' is On Or Control 'Masterbedroom / MasterBedroom:-Sensor' is switched On ) Then Set Scene 'Scene / Scene:MasterBed-Bright' On Set Scene 'Scene / Scene:KPL-Button-B' On Else - No Actions - (To add one, press 'Action')
December 27, 201113 yr Author Hi Robert, There are no conditions on the parent folder at all? With kind regards, Michel
December 27, 201113 yr From Sunset To 11:00:00PM (same day) I use time as the condition seems to have worked in the past just fine that is not where it fails it is the var that seems to be read wrong.. Thank you Robert
December 27, 201113 yr Author Hi Robert, Thank you. You had mentioned that when you move this program to the root folder, it starts working. So, I do not think the problem is the var but the condition on the folder. Can you please create another folder (without any conditions), move this program there, and see if it works? With kind regards, Michel
December 27, 201113 yr Hi there and Happy Holidays to you guys. As you can see in the attached file I have many nested programs like the one above and they work fine it is not the time function but the var that seems to have a problem when nested . Regards Robert
December 27, 201113 yr Author Hi Robert, Is the variable State or Integer? If integer, then the condition is not re-evaluated when the state of the variable changes. With kind regards, Michel
December 27, 201113 yr well it is not state but the prob is when the program is called and it is a int the test if it is false it reads it as true and runs the then anyway the change of the int is not what is triggering the program the program is called from another program. It seems if the int is nested it does not read correctly and then the then runs no matter what .... I have tried to find a pattern but it changes every so often i run it but if i reboot the isy it runs fine for a while and then it seems to mess up .. Not easy I know I have 15 int declared for the system .... Regards Robert
December 27, 201113 yr Author Hi Robert, Are you certain that: AlarmState = 0 Bedroom_Chill = 0 Also, you mentioned that you call this program. Is it called from another program? The main issue we have is that we cannot reproduce this behavior and need as much information as possible. I understand that it's quite intermittent and it may not happen all the time but the more information we have, the more the likelihood that we can perhaps figure out what's going on. With kind regards, Michel
December 27, 201113 yr Are you certain that: AlarmState = 0 Bedroom_Chill = 0 Yes.... Also, you mentioned that you call this program. Is it called from another program? I run this both ways another program calls it from a switch control is when on Or it runs just by the motion maybe the motion test should be first rather the var I will switch it and see (control then test) hmmm.... The main issue we have is that we cannot reproduce this behavior and need as much information as possible. I understand that it's quite intermittent and it may not happen all the time but the more information we have, the more the likelihood that we can perhaps figure out what's going on. Robert
December 27, 201113 yr Author Hi Robert, Thank you. I do not think moving the motion higher is going to help. I would try to eliminate variables. For instance, the first thing I would do is to disable the program that calls this program. Secondly, I would create the same exact program but instead with state variables. And, in the Then, instead of running thing, I would send notification. This way, we would know the status of each program and all the events associated with it. Again, this new program is the duplicate of the original so that both can run at the same time with two differences: state variable instead of integer and notifications instead of turning things on/off. With kind regards, Michel
December 28, 201113 yr I downloaded and updated to 3.1.15 -- My 2475SDB is not working correctly. It will respond to a scene where the scene sets the level to 0 (a scene can turn it off), but it will not respond when scene sets the level to 100% (a scene can't turn it on). I think someone else reported that it was working but only after the rebooted (cycled power). I tried that, it didn't correct the problem. About reports both firmware and client at 3.1.15.
December 28, 201113 yr Yes, it is the new InLineLinc, and deleting the scene and re-creating it worked. Thanks!
December 28, 201113 yr As an FYI to anyone else who encounters a similar problem with the new InLineLinc, the new device firmware has a new requirement for what is written in the Scene link records. It is necessary to have the Scene link records written by 3.1.15 or later.
December 28, 201113 yr BACKGROUND I have a few programs that use network resources to sent http get commands to an IR blaster to change the channel on my whole house video distribution set up. Unfortunately the ISY locked up trying to send those commands. The ISY would not respond to ping requests and the admin console would not come up. I have to power cycle the ISY. ERROR LOG Tue 2011/12/27 18:00:01 System -140005 Net Module Rule: 23 Tue 2011/12/27 18:00:01 System -140005 Net Module Rule: 23 Tue 2011/12/27 18:00:02 System -140005 Net Module Rule: 30 Wed 2011/12/28 00:00:00 System -140005 Net Module Rule: 25 Should have been followed with Rule: 28 Should have been followed with Rule: 30 Wed 2011/12/28 03:16:59 System -170001 UDQ:Queue Full: ELK Wed 2011/12/28 03:16:59 System -170001 UDQ: Queue(s) Full, message ignored Wed 2011/12/28 03:16:51 System -5 Start Wed 2011/12/28 03:16:53 System -170001 [Network] Established Wed 2011/12/28 03:19:10 System -170001 [uDSockets] RSub:31 error:6
December 28, 201113 yr Author Hello Elvis, I am so very sorry to hear. Is this problem reproducible and does it happen all the time? Are the times correct especially the one that happened right at midnight? With kind regards, Michel
December 28, 201113 yr Hello Elvis, I am so very sorry to hear. Is this problem reproducible and does it happen all the time? Are the times correct especially the one that happened right at midnight? With kind regards, Michel Michel, I have been unable to reproduce the problem, but I had been doing electrical work turing off various circuits while re-wiring some electrical boxes. All circuits were on during the time the ISY locked up and the times are correct.
December 28, 201113 yr I am trying to write a simple security program. I set an "away" button on and then if the door is opened and the "away" button is not pushed off then I get a text and some lights go on and off. For some reason the program does not run correctly. It just runs through (no wait) and the sate variable never gets set. $Away_Activated is set when the Away button is set fast on. That works fine. All of the lights get turned on, I get the text notification but the program just stops at that point, it doesn't wait 1 minute and the state variable $Door_Open_Away_On doesn't get set to 1.
December 28, 201113 yr When you close the front door the program turns false and cancels the wait. Break the program in two and have this program Run the second program which contains the wait and the variable. Tim
