blueman2 Posted December 26, 2011 Posted December 26, 2011 I am a new user here. Just got my ISY 99i/IR yesterday and have been trying to set it up with a single device to learn how to use it. I have it connected to the 2413S using ethernet cable to port A. Power supplied to the ISY unit. ALso have a 2450 relay plugged in as a test unit. I was able to get the system to see the 2450 and control it (yea!). However, whenever I open up the Admin console, it goes into an infinite loop with a pop up box labeled "Linking" which says in the box "Please do not power off/unplug the system or make adjustments to the linked/attached devices". This box ran all night long and it still running, going from 0 to 100% again and again and again and again. Running the latest non-beta firmware (I think 3.1.15). Any guidance? I also did update to latest Java.
LeeG Posted December 26, 2011 Posted December 26, 2011 Did you clear the Java cache after upgrading? After successfully adding the 2450 I/O Linc and being able to control the I/O Linc Relay manually what else was done before the "linking" started? Is there an Icon (perhaps green) to the left of the I/O Linc nodes in the My Lighting tree? If so try a right click on the I/O Linc node and select Disable.
blueman2 Posted December 26, 2011 Author Posted December 26, 2011 Thanks for the reply. I think I solved the issue. I turns out my 99i was linking to the wrong gateway address. For some reason it chose a gateway address of one of my WAPs. I manually set the IP, mask and gateway addresses, and it now is working as it should. Thanks!
joeko18 Posted May 1, 2012 Posted May 1, 2012 I just got a ISY-994i. Sounds like I have the same problem. I am able to log-in to the admin console, but when I press "start linking" I get the same loop you describe. I don't understand your fix, can you post instructions. Thanks
Michel Kohanim Posted May 2, 2012 Posted May 2, 2012 Hello joeko18, Do you have any firewall software on your computer? If you are still having problems, it's more expedient to schedule a call with our tech support team (links below) and we'll be delighted to help. With kind regards, Michel
joeko18 Posted May 2, 2012 Posted May 2, 2012 Thanks! I uninstalled Avast and that solved the porblem
