sanders2222 Posted January 2, 2012 Posted January 2, 2012 I am in the process of wiring in a new ELK M1 to replace a 30 year old security system. Does anyone know if I can plug my PLM into the same wall outlet as the wall-wart power supply for my ELK? Would I need a wall-wart filter to do this? It would be nice to keep the PLM in the same closet as the ELK. I have my ISY located in a closet across the hallway but the outlet in there is on a different circuit and is not backed up with generator power. Maybe a better option would be to plug the ELK PS into the closet with the ISY and run a low voltage feed from there to the ELK panel in the other closet. Just curious what have others have done, what works and what doesn't?
Brian H Posted January 2, 2012 Posted January 2, 2012 If it is a type with a power transformer in it. It would probably be fine. If it is one of the new switching types it could be a problem, but not all of them are. My ISY99i is being run by the switching supply included in my older ISY26 kit.
Slalom Posted January 2, 2012 Posted January 2, 2012 I have my ELK plugged into the same circuit as my PLM with no ill effects. YMMV
sanders2222 Posted January 2, 2012 Author Posted January 2, 2012 Thanks, your responses are somewhat helpful. Maybe I needed to word it another way. From other posts, I've formed an opinion that the PLM needs to be away from any Insteon signal suckers. I also assume that wall-warts, being transformers or more, could be a signal sucker. So if I plug a wall-wart into the same wall duplex as my PLM, will I be creating line noise that will effect my system communication? I know the filters work and distance (from a signal sucker) helps. Where is the best place for the PLM? Closer to the breaker panel or more centrally located (like my closet). My house & garage is "L" shaped (where my garage is the L part) and my breaker panel is located on the wall furthest from the house. On the other hand, I have Insteon products in a pump house and shed located away from the house and I have not experienced any communication issues to those devices. (knock on wood)
