Program Not Working as Expected
When I execute the program below, the program runs and the program summary start/stop times are identical. The scene is turned on however it never waits 2 minutes and is never turned off. The scene contains only a Bath Master switch (2476D SwitchLinc Dimmer W/Beeper v.38). This occurs with other identical scenes that have different on level percents. I discovered that when I remove the "Status 'Bath Master' is Off" statement from the If statement, the stop time is 2 minutes after the start time. Why does this program work this way? I don't want this scene to operate if the switch was turned on manually and was checking for that in the IF statement. Thanks, Steve
   And Control '4 Bath-Sensor' is switched On
       Set Scene 'sf Bath Master / sc Bath Master 40%' On
       Wait  2 minutes
       Set Scene 'sf Bath Master / sc Bath Master 40%' Off
Is Bath Master part of the sf Bath Master scene? If so then the If is re-evaluating when the scene is turned on. Any change to Bath Master (since you are using the Status of that device) will cause the program to re-evaluate during the wait and run the program False.
TJF1960 - Yes the switch is part of all the scenes. Is there a better technique to check the status of the switch while having multiple scenes for the same switch? Basically I want to not have the scenes controlled by a motion sensor override manually controlled scenes. For example, if the switch is turned on manually, I don't want to walk into the bathroom and have a program initiated by a motion sensor override the switch's control. I couldn't readily find an example in the forum. Thanks for your help. Steve
There are a couple of examples on the wiki. There have been many threads on this, but sometimes they are hard to sort through.
Try:
http://www.universal-devices.com/mwiki/index.php?title=ISY-99i/ISY-26_INSTEON:Using_Motion_Sensors_in_Bathrooms
I don't know that this will do what you want, but try breaking your program into two:
       run next program (then path)
Next program:
if
then
       Wait  2 minutes
else
