if (any unit in scene) possible using admin console?
Hi, just picked up a 994 and I like it. I have started playing with the admin console programs. I would like to set a variable "allOn" to 1 when any units in my scene "allOn" are on. What is the best method to do this?
Insteon has no Scene status. The Status of each device in the Scene has to be checked for not Off.
Status 'ICON Dimmer 1' is not Off
Or Status 'SwitchLinc Dimmer' is not Off
Or Status 'ICON Relay 1' is not Off
Thanks for the reply. I was hoping the ISY would track that. For example, you can see individual unit status when you look at a scene using the admin console.
Hi robinasu,
Yes, you can. All you have to do is to click on that specific scene and you will see a table with the status of all responders in that scene.
