e-mails/notification no longer works after firmware upgrade
Hello,
I just updated my firmware to the new 3.1.14 v and everything works fine with the exception of my e-mails/notifications function. When I go to tht tab on the Admin Console and perform a test I now get "Mail Server Failed" from timed out. It worked fine before I did the firmware update. I see there is a button on the bottom of that page that says "Reload", should I do that.
Thanks so much for everyone that has helped me solve problems with my ISY99 on this forum. I have received very good help and advise since I am a newbie.
Thanks Again,
Jim
Hi Michel,
Thanks for your response. Yes..I mean firmware 3.1.17. I am not sure what you mean by leaving the from field "blank" This is what I have on the emails/notifications tab under configurations.
Groups
Name Receipents ID
JimCellphone 6147960926@txt.att.net 1
JimEmail jimblackston@yahoo.com 2
Under SMTP Settings the default is checked and the timeouts is 1,000ms
Jim Blackston
Hi Michel,
I tried the test again and it still failed but I also got a message from the ISY99 saying "SSL Authenication failed" . I also got the same message as before "Mail server failure" from timed out.
Jim Blackston
Michel,
Thanks for getting back to me. I do not have my own mail server. I have aT&T Uverse and have several .sbcglobal.net accounts and one yahoo account but I do not believe they belong to me.
Would you please help me set one up using gmail.
Jim Blackston
Michel,
I unchecked the use default box and manually configured my gmail SMTP Server. That solved the problem. For some reason the default worked before the firmware update but now that I took your advise, everything works fine now.
Thanks again for all your help.
Jim Blackston
