How long?
How long should it take to internet into your ISY from on the road? Mine seems to have slowed a bit (could be outside factors) from the first time I used the remote feature. Mine takes about 30-40 seconds to get in on average. Of course it is almost instantanious from my local network. Is ther any way to speed it up?
Faster internet connection? Mine takes a few seconds longer than connecting locally, but not much.
I use internet connections all over the world and so far the time is the same. I'm wondering if its a local thing at the ISY DSL connection.
aLf
Could you possibly have a speed issue at home? Michel or Chris could tell us exactly what happens, but I'm assuming the remote PC simply downloads and runs a Java app when you connect to the ISY.
As a test, I just opened my ISY from a remote connection running on a 3Mbps/768Kbps DSL line. My home connection is a 6Mbps/768Kbps cable connection. The ISY has never been opened from this remote connection (so the Java app wasn't cached), but it only about 5 seconds before I got my logon screen.
I can't imagine anything wrong with the ISY would cause only remote connections to be slow.
Hi All,
If the Java cache is on, then it should take less time. In all cases though, it all depends on the ISP and upload speed (not download). Sometimes up to a minute if your upload speed is at 128K.
