Using scene status in programs
bsobel
I realize there is not a direct way to use scene status in programs since the status of scene members can change after a scene is activated. What I'd like however is the ability to use a scene NAME in an IF statement and then (internally) have the ISY explode that into a series of AND or a series of OR statements. E.g. I'd like to say:
if status AND INDICATOR_LIGHTS_SCENE is ON then
that would automatically translate to
if status scene member 1 is ON
and status scene member 2 is ON
etc
Same idea with 'or'. I don't like the current fact the that a scene is a quasi container, but I still must manage the container (in scenes) and not sue that container in programs where I need to remember what items the scene contains.
Make sense to anyone else besides me? :)
Bill
Some of the questions that come up whenever this feature is suggested is what does ON mean.
Scenes often have different values for responders.
Responder A= 20%
Responder B = 50%
Responder C = 100%
Responder D = Off
What should the If Scene be checking for?
Also, since whatever the checks, they can be done today it has not had a high priority.
How about this?
Allow a program to be a member of a scene as a responder. Following the same rules as a device would follow for activating a scene on/off.
It would function as a "control" statement rather than a "status" statement. You could do it already if you had an unused kpl button that you put as a responder to the scene, and then had the program follow that kpl button. But who wants to waste a kpl button?
  • 1 month later...
Responder A= 20%
Responder B = 50%
Responder C = 100%
Responder D = Off
Lee, I would say that it would check whatever the IF condition is set to. E.g. if the statement is SCENE_X ON then any of those devices in ON state would trigger. The idea here is to better couple scenes/programs as today if I add/remove an item from a scene I need to possibly go update a program as well.
The other suggestion given of letting a program be a responder to a scene is interesting as well, but the program would need a way of receiving 'why' it was run (on, off, etc). Given the current design I suspect the logical exploding of a group into a series of in and/ors is more inline.
And while I realize this can be done in other ways, I'd really respectfully ask that you do consider easy of programming/ease of use when considering features.
Best,
Bill
I'm not trying to dismiss the idea. Only to define the requirement. In the example
SCENE_X
Responder A= 20%
Responder B = 50%
Responder C = 100%
Responder D = Off
"E.g. if the statement is SCENE_X ON then any of those devices in ON state would trigger."
this seems to have no relation to the Scene except a way of listing the devices in the Scene. ON means the device is 100%. For If SCENE_X is ON to trigger True then any of the 4 devices that is turned On to 100% would trigger the Program (Ored) or all 4 device are turned On 100% (Anded). Either way I do not see result having any relationship to the Scene definition in the above example.
If Status Responder A is On
or Status Responder B is On
or Status Responder C is On
or Status Responder D is On
is this the functional suggestion being asked for?
Is it correct to state the requirement is simply an alternative method of listing a set of devices. That is, the objective of using a Scene name in an IF is an alternate way of listing a set of device names and the original Scene Responder values, % On or On/Off, is not relevant.
  • 1 month later...
Yes, just simplifying the listing of devices so if scene membership changes programs don't need to be updated.
