Conductor for Android
Can't get the ISY WAN to work. I've used the settings in the admin console (https address and port number) but to no luck. The ISY LAN works fine. What could I be missing?
Greg Seigel
gregseigs@verizon.net
How did you enable the internet access? From the admin panel? I understand that this can not work at times.
You may need to enter your router settings an manually configure port forwarding rules. The best luck I had was after taking the time to do this.
