Zigbee/Upgrade Questions
Hello,
I hope someone can answer a few questions.
Is the ISY994i series, and the ISY994iZ series, based on the same hardware? if so, can the ISY994i be later upgraded to the ISY994iZ?
If I had a Zigbee enabled ISY994i or ISY994iZ device, would I be able to communicate with a custom-built Audrino-based device with an XBee radio?
The description for the ISY994i indicates "An expansion slot which could be utilized to install and support other communications protocols such as a Zigbee radio". What is currently available, that can be installed, that would allow me to communicate with a Zigbee device?
Thank you!
Hello scobeyr,
Comments below.
Hello,
Yes and Yes.
ISY is a very strongly typed device. You cannot communicate with any device that ISY does NOT know about (i.e. ISY need a driver for devices to which it communicates)
-Zigbee PRO radio allows you to communicate with RCS devices, Brultech ECM1240, our own energy monitor.
-Zigbee SEP (waiting for certification) communicates with Smart Meters
