Can not add device
mrobles
I have an ISY99, I added to an existing instalation of about 20 insteon devices and it works fine. I tried to add a new switchlinc dimmer but it gives me the "node not added-failed resoring device" error. The ISY has the latest firmware. The switchlinc was new. I have disabled firewall and virus protection. I added the device to a 2412n without a problem and can use it with mobilelinc on my iphone.
I have tried many times and various ways :(
Help
Run Tools | Diagnostics | Event Viewer with Level 3-Device communications events selected. Then use Link Management | New INSTEON Device to add the new SwitchLinc. Enter the device Insteon address and a Name. Leave the Device Type set to Auto Discover.
Post the event trace.
First though check Help | About and verify the Firmware line and UI line both show 3.1.17.
Tue 02/28/2012 09:16:57 PM : ---- Initializing the linked devices ----
Tue 02/28/2012 09:16:57 PM : ---- All Linked Devices are now initialized ----
Tue 02/28/2012 09:16:57 PM : ---- Add remaining devices ----
Tue 02/28/2012 09:16:57 PM : [18 E5 7A 1 ] Reading all links
Tue 02/28/2012 09:16:58 PM : [18 E5 7A 1 ] Querying engine version
Tue 02/28/2012 09:16:58 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 0D 00 06 (00)
Tue 02/28/2012 09:16:58 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 0D 01 (01)
Tue 02/28/2012 09:16:58 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:16:58 PM : [18 E5 7A 1 ] Retrieved engine version is i2
Tue 02/28/2012 09:16:58 PM : [18 E5 7A 1 ] Calibrating engine version ensuring support for i2
Tue 02/28/2012 09:16:58 PM : [iNST-ACK ] 02 62 18.E5.7A 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Tue 02/28/2012 09:16:58 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2F 00 (00)
Tue 02/28/2012 09:16:59 PM : [iNST-ERX ] 02 51 18 E5 7A 19 74 BE 11 2F 00 01 01 0F FF 01 A2 0B 0F 97 FC FF 1C 00 00
Tue 02/28/2012 09:16:59 PM : [Extended-Direct][18.E5.7A-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Tue 02/28/2012 09:16:59 PM : [18 E5 7A 1 ] Using engine version i1
Tue 02/28/2012 09:16:59 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:16:59 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:16:59 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:16:59 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B F8 06 PEEK (F8)
Tue 02/28/2012 09:17:00 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B A2 PEEK (A2)
Tue 02/28/2012 09:17:00 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:00 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:17:00 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:17:00 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B F9 06 PEEK (F9)
Tue 02/28/2012 09:17:01 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B 0B PEEK (0B)
Tue 02/28/2012 09:17:01 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:01 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:17:01 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:17:01 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B FA 06 PEEK (FA)
Tue 02/28/2012 09:17:02 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B 0F PEEK (0F)
Tue 02/28/2012 09:17:02 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:02 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:17:02 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:17:02 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B FB 06 PEEK (FB)
Tue 02/28/2012 09:17:02 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B 97 PEEK (97)
Tue 02/28/2012 09:17:03 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:17:03 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:17:03 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:03 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B FC 06 PEEK (FC)
Tue 02/28/2012 09:17:04 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B FC PEEK (FC)
Tue 02/28/2012 09:17:04 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:04 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:17:04 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:17:04 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B FD 06 PEEK (FD)
Tue 02/28/2012 09:17:05 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B FF PEEK (FF)
Tue 02/28/2012 09:17:05 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:05 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:17:05 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:17:05 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B FE 06 PEEK (FE)
Tue 02/28/2012 09:17:06 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B 1C PEEK (1C)
Tue 02/28/2012 09:17:06 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:06 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:17:06 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:17:06 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B FF 06 PEEK (FF)
Tue 02/28/2012 09:17:07 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B 00 PEEK (00)
Tue 02/28/2012 09:17:07 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:07 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Tue 02/28/2012 09:17:07 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Tue 02/28/2012 09:17:07 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B F0 06 PEEK (F0)
Tue 02/28/2012 09:17:08 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B 00 PEEK (00)
Tue 02/28/2012 09:17:08 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:08 PM : [18 E5 7A 1 ] Adding device to ISY
Tue 02/28/2012 09:17:08 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 10 00 06 ID-REQ (00)
Tue 02/28/2012 09:17:08 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 10 00 ID-REQ (00)
Tue 02/28/2012 09:17:08 PM : [iNST-SRX ] 02 50 18.E5.7A 01.19.40 8B 01 00 (00)
Tue 02/28/2012 09:17:08 PM : [standard-Broadcast][18.E5.7A-->01.19.40] Max Hops=3, Hops Left=2
Tue 02/28/2012 09:17:08 PM : [18 E5 7A 1 ] ** Not Added ** Restore node Failed
Tue 02/28/2012 09:17:08 PM : ---- All Remaining Device Added ----
Tue 02/28/2012 09:17:08 PM : ---- Start: Generate Scenes from links ----
Tue 02/28/2012 09:17:12 PM : ---- End: Generate Scenes from links ----
Tue 02/28/2012 09:17:13 PM : [All ] Writing 0 bytes to devices
What does Help | About show for the ISY (Firmware) and Admin Console (UI) levels? The event trace results do not match my 3.1.17 results for adding a SwitchLinc Dimmer.
Suggest Factory Resetting the SwitchLinc and doing another New INSTEON Device with Auto Discover. Also suggest running the Event Viewer as you did before so that the results with a factory reset SwitchLinc will be known. The previous trace shows the SwitchLinc has link records going into the device add.
Here is the file after a factory reset. I still can't add.
Wed 02/29/2012 07:18:23 PM : ---- Initializing the linked devices ----
Wed 02/29/2012 07:18:23 PM : ---- All Linked Devices are now initialized ----
Wed 02/29/2012 07:18:23 PM : ---- Add remaining devices ----
Wed 02/29/2012 07:18:23 PM : [ 18 E5 7A 1] Writing High Water Mark at Link 0
Wed 02/29/2012 07:18:23 PM : [18 E5 7A 1 ] Querying engine version
Wed 02/29/2012 07:18:23 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 0D 00 06 (00)
Wed 02/29/2012 07:18:23 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 0D 01 (01)
Wed 02/29/2012 07:18:23 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/29/2012 07:18:23 PM : [18 E5 7A 1 ] Retrieved engine version is i2
Wed 02/29/2012 07:18:23 PM : [18 E5 7A 1 ] Calibrating engine version ensuring support for i2
Wed 02/29/2012 07:18:23 PM : [iNST-ACK ] 02 62 18.E5.7A 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06 (00)
Wed 02/29/2012 07:18:24 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2F 00 (00)
Wed 02/29/2012 07:18:24 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/29/2012 07:18:24 PM : [iNST-ERX ] 02 51 18 E5 7A 19 74 BE 11 2F 00 01 01 0F FF 01 00 00 00 00 00 00 00 00 00
Wed 02/29/2012 07:18:24 PM : [Extended-Direct][18.E5.7A-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Wed 02/29/2012 07:18:24 PM : [18 E5 7A 1 ] Using engine version i1
Wed 02/29/2012 07:18:24 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 28 0F 06 SET-MSB(0F)
Wed 02/29/2012 07:18:25 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 28 0F SET-MSB(0F)
Wed 02/29/2012 07:18:25 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/29/2012 07:18:25 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 2B F8 06 PEEK (F8)
Wed 02/29/2012 07:18:25 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 2B 00 PEEK (00)
Wed 02/29/2012 07:18:25 PM : [18 E5 7A 1 ] Adding device to ISY
Wed 02/29/2012 07:18:25 PM : [iNST-ACK ] 02 62 18.E5.7A 0F 10 00 06 ID-REQ (00)
Wed 02/29/2012 07:18:26 PM : [iNST-SRX ] 02 50 18.E5.7A 19.74.BE 2B 10 00 ID-REQ (00)
Wed 02/29/2012 07:18:26 PM : [standard-Direct Ack][18.E5.7A-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Wed 02/29/2012 07:18:26 PM : [iNST-SRX ] 02 50 18.E5.7A 01.19.40 8B 01 00 (00)
Wed 02/29/2012 07:18:26 PM : [standard-Broadcast][18.E5.7A-->01.19.40] Max Hops=3, Hops Left=2
Wed 02/29/2012 07:18:26 PM : [18 E5 7A 1 ] ** Not Added ** Restore node Failed
Wed 02/29/2012 07:18:26 PM : ---- All Remaining Device Added ----
Wed 02/29/2012 07:18:26 PM : [All ] Writing 0 bytes to devices
mrobles
Thanks for the new trace. This one is for UDI to analyze. There are no actual errors in the trace. The SwitchLinc firmware is likely the latest at v.40
The ID-REQ shows Cat/Subcat of [01.19] with firmware v.40
Hello mrobles and LeeG,
I think this is one of the newer SWLs with a firmware that we do not yet support. The main issue is :
It seems that the device is responding with a set-button press broadcast. This is not expected and ISY assumes it cannot support it.
This may have to do with the v40 number itself as I get the Broadcast Set button message from my V38 SwitchLinc Dimmer and the ISY proceeds with the add successfully.
Fri 03/02/2012 07:12:22 AM : [iNST-ACK ] 02 62 16.3F.93 0F 10 00 06 ID-REQ (00)
Fri 03/02/2012 07:12:22 AM : [iNST-SRX ] 02 50 16.3F.93 19.70.06 2B 10 00 ID-REQ (00)
Fri 03/02/2012 07:12:22 AM : [standard-Direct Ack][16.3F.93-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Fri 03/02/2012 07:12:23 AM : [iNST-SRX ] 02 50 16.3F.93 01.19.38 87 01 00 (00)
Fri 03/02/2012 07:12:23 AM : [standard-Broadcast][16.3F.93-->01.19.38] Max Hops=3, Hops Left=1
Fri 03/02/2012 07:12:23 AM : [16 3F 93 1 ] Start : Adding device to ISY
Fri 03/02/2012 07:12:23 AM : [16 3F 93 1 ] Finish : Adding device to ISY was Successful
Assuming these are 2476D's (dimmers), I added 8 of the V40 versions last weekend. No problems.
I don't know an easy way to elicit the ID-Req other than deleting the device. Let me know if this would help.
I have also just now ADDED two NEW installs of 2476D R5.6 Hardware, V40 firmware successfully via V3.1.17 ISY,
I saved the log and I also see the Broadcast msg {->1.19.40 } during each devices ADDITION but no issue was reported.
I was ADDING NEW DEVICES however. I do not know if that helps at all for the "RESTORE NODE failure" shown in the OPs problem logs.
      37.6k
      376.3k
