Elk not controlling Morninglinc after module and upgrade to
edfinley
Hi,
I had upgraded to 3.1.17 and my Elk quit controlling a morninglinc. ISY could still control it but not ELK. I downgraded back to an older firmware and it worked. I've now upgraded to 3.1.17 and installed the Elk module and the problem is back. I re-exported an ELk file but still no luck. Elk is controlling the lights fine, just no response from Morninglinc.
Any ideas are appreciated.
Ed
Hi Ed,
Sincere apologies for tardy reply. Please note that there was a bug in 2.8.16 whereby node addresses were moved up by one. This was fixed in 3.1.17. Are you certain that the ELK address for the morninglinc is the same as it used to be?
Good point. Both Elk export files have them in the same place, but I noticed a duplicate set in the Elk Remote Programming software, maybe from an earlier export. I"m guessing I should delete these and try upgrading again.
Regards,
Ed
Starting over with a new export and deleting all the old ELK lighting worked. I ended up having to go through over 100 rules and change every Insteon device back to it's new location, but it worked.
Regards,
Ed
      37.6k
      376.2k
