Chuck Posted February 5, 2008 Posted February 5, 2008 I've been using the ISY-26 for about 3 months now and it is definately a huge improvement over HouseLinc. However, it still leaves frustation trying to get my 8-button KPL to work properly all the time. I have an 'All Off' status monitoring program that only works some of the time. I have discussed it previously here: http://forum.universal-devices.com/view ... c&start=15 If Status 'Basement Playroom Lights (loa' is Off And Status 'Dining Room - LIGHT (load)' is Off And Status 'Dining Room Ceiling Fan (load' is Off And Status 'Kitchen Ceiling Lights (load)' is Off And Status 'Kitchen Sink Light (load)' < 40% And Status 'Living Room Ceiling (load)' is Off And Status 'Living Room Lamp (load)' is Off And Status 'Office Ceiling Light (load)' is Off Then Wait 2 seconds Set Scene 'ALL OFF LED' On Else Wait 2 seconds Set Scene 'ALL OFF LED' Off The problem is even though the UD Admin Console states the correct status of all the devices, the 'All Off' LED doesn't turn on when it's supposed to or turn on when it's supposed to about 25% of the time. I noticed when using the 'All On' or 'All Off' on the main page of the Admin Console, all lights react immediately and successfully. Why is it when this action is attempted with a program, devices turn on and off in succession instead of at the same time and delays are needed to make things work? Example, here is a program I use for 'Goodnight' program: If Control 'Office Ceiling Light (load)' is switched Fast Off Or ( Status 'Office Ceiling Light (load)' is Off And Control 'Office Ceiling Light (load)' is switched Off ) Then Set 'Living Room Lamp (load)' 60% Set 'Office - Living Room Lamp' 60% Wait 1 second Set 'Kitchen Sink Light (load)' 30% Wait 1 second Set Scene 'All Off Scene (program-activa' Off Wait 30 seconds Set Scene 'Living Room Lamp' Off Else - No Actions - (To add one, press 'Action') I have experimented with placing "Set Scene 'All Off Scene (program-activa' Off" first in line vs. last and it appears to work best last. Is this because of the time needed for "clean-up"? I added the 1 second delays to improve reliablity. Is this neccessary?
MikeB Posted February 5, 2008 Posted February 5, 2008 The problem is even though the UD Admin Console states the correct status of all the devices, the 'All Off' LED doesn't turn on when it's supposed to or turn on when it's supposed to about 25% of the time. If the console thinks the devices are all correct, does it also think that the LED device is correct? If so, then it sounds like your THEN and ELSE commands are intermittently not making it to your KPL for some reason. I use 2 programs for my status LED, mostly because I want to check the status of the LED before I try to turn it ON or OFF. Here is my code: If Status 'MasterBedroomControls1H' is not Off And ( Status 'AndyBedroomCloset1' is Off And Status 'AndyBedroomLamp1' is Off And Status 'Bathroom2ndMain1' is Off And Status 'Bathroom2ndMirror1' is Off And Status 'Bathroom2ndVent1' is Off And Status 'MikeyBedroomCloset1' is Off And Status 'MikeyBedroomLamp1' is Off And Status 'SpareBedroomCloset1' is Off And Status 'SpareBedroomLamp1' is Off And Status 'Stairway1' is Off And Status 'AndyBedroomControls1C' is Off And Status 'AndyBedroomControls1D' is Off ) Then Wait 1 second Set Scene 'Floor2StatusLight' Off Else - No Actions - (To add one, press 'Action') If Status 'MasterBedroomControls1H' is Off And ( Status 'AndyBedroomCloset1' is not Off Or Status 'AndyBedroomLamp1' is not Off Or Status 'Bathroom2ndMain1' is not Off Or Status 'Bathroom2ndMirror1' is not Off Or Status 'Bathroom2ndVent1' is not Off Or Status 'MikeyBedroomCloset1' is not Off Or Status 'MikeyBedroomLamp1' is not Off Or Status 'SpareBedroomCloset1' is not Off Or Status 'SpareBedroomLamp1' is not Off Or Status 'Stairway1' is not Off Or Status 'AndyBedroomControls1C' is not Off Or Status 'AndyBedroomControls1D' is not Off ) Then Wait 1 second Set Scene 'Floor2StatusLight' On Else - No Actions - (To add one, press 'Action') I have to say, I've been extremely impressed at how reliable it has been for me.
Sub-Routine Posted February 5, 2008 Posted February 5, 2008 ... I noticed when using the 'All On' or 'All Off' on the main page of the Admin Console, all lights react immediately and successfully. Why is it when this action is attempted with a program, devices turn on and off in succession instead of at the same time and delays are needed to make things work? Example, here is a program I use for 'Goodnight' program: If Control 'Office Ceiling Light (load)' is switched Fast Off Or ( Status 'Office Ceiling Light (load)' is Off And Control 'Office Ceiling Light (load)' is switched Off ) Then Set 'Living Room Lamp (load)' 60% Set 'Office - Living Room Lamp' 60% Wait 1 second Set 'Kitchen Sink Light (load)' 30% Wait 1 second Set Scene 'All Off Scene (program-activa' Off Wait 30 seconds Set Scene 'Living Room Lamp' Off Else - No Actions - (To add one, press 'Action') I have experimented with placing "Set Scene 'All Off Scene (program-activa' Off" first in line vs. last and it appears to work best last. Is this because of the time needed for "clean-up"? I added the 1 second delays to improve reliablity. Is this neccessary? The All Off/On buttons in the GUI call a scene, that's why they all react at once. I suggest creating a new scene that includes 'Living Room Lamp (load)', 'Office - Living Room Lamp', and 'Kitchen Sink Light (load)'. Even better would be a scene that includes those three devices as well as all the devices in 'All Off Scene (program-activa'. Set the levels (including off) and rates that you desire and call the scene on. Then follow with the wait 30 seconds... All the devices should react at once then. Rand
Chuck Posted February 6, 2008 Author Posted February 6, 2008 Rand, I changed the scene to include all possible devices and the program to simply activate it. This is working so far. I will let you know otherwise. Thank you. Mike, I think the changes to the scene took care of the LED status. I guess I don't see the differene between using the "Then" and "Else" method vs. breaking it into two separate programs. I'm curious if this supposed to work better and why? I will continue to monitor it and let you know... Thanks. Chuck
MikeB Posted February 6, 2008 Posted February 6, 2008 Mike,I think the changes to the scene took care of the LED status. I guess I don't see the differene between using the "Then" and "Else" method vs. breaking it into two separate programs. I'm curious if this supposed to work better and why? I will continue to monitor it and let you know... Hey Chuck - I break it down into 2 programs because I check my status button before sending a command to change it. With your single program, any time one of your 'If' devices gets turned on the ISY will send a command to turn your status LED on - even if the status LED is already on. With my 2 programs, it checks the status LED first. If it's already on, it doesn't bother sending the command to turn it on again. I try to reduce powerline traffic as much as possible.
Sub-Routine Posted February 6, 2008 Posted February 6, 2008 Rand,I changed the scene to include all possible devices and the program to simply activate it. This is working so far. I will let you know otherwise. Thank you. Good news! Scenes are your friends. Rand
Chuck Posted February 15, 2008 Author Posted February 15, 2008 If Status 'Basement Playroom Lights (loa' is Off And Status 'Dining Room - LIGHT (load)' is Off And Status 'Dining Room Ceiling Fan (load' is Off And Status 'Kitchen Ceiling Lights (load)' is Off And Status 'Kitchen Sink Light (load)' is Off And Status 'Living Room Ceiling (load)' is Off And Status 'Living Room Lamp (load)' is Off And Status 'Office Ceiling Light (load)' is Off Then Wait 5 seconds Set Scene 'ALL OFF LED' On Else Wait 5 seconds Set Scene 'ALL OFF LED' Off I just activated the 'All Off" scene via another switch. This 'All Off LED Status' program failed to execute. I went into Program Summary and the program status indicated false, when it should be true. All Lighting in the Console verifies all devices are "Off". I then select the program in the Program Summary and select "Run". It executes fine and returns a status of "True". I believe the problem is the network traffic for the 'All Off' scene prevents the program from returning a correct status. Perhaps there needs to be a delay BEFORE the first line of CODE above and not neccessarily more delay at the end (as you see I increased to 5 seconds). Can this be added somehow or changed in the registry? Thanks, Chuck
Michel Kohanim Posted February 15, 2008 Posted February 15, 2008 Hi Chuck, Or, it could be that in that 5 seconds one of the lights turn back on and thus nothing executes since the condition is now false. With kind regards, Michel If Status 'Basement Playroom Lights (loa' is Off And Status 'Dining Room - LIGHT (load)' is Off And Status 'Dining Room Ceiling Fan (load' is Off And Status 'Kitchen Ceiling Lights (load)' is Off And Status 'Kitchen Sink Light (load)' is Off And Status 'Living Room Ceiling (load)' is Off And Status 'Living Room Lamp (load)' is Off And Status 'Office Ceiling Light (load)' is Off Then Wait 5 seconds Set Scene 'ALL OFF LED' On Else Wait 5 seconds Set Scene 'ALL OFF LED' Off I just activated the 'All Off" scene via another switch. This 'All Off LED Status' program failed to execute. I went into Program Summary and the program status indicated false, when it should be true. All Lighting in the Console verifies all devices are "Off". I then select the program in the Program Summary and select "Run". It executes fine and returns a status of "True". I believe the problem is the network traffic for the 'All Off' scene prevents the program from returning a correct status. Perhaps there needs to be a delay BEFORE the first line of CODE above and not neccessarily more delay at the end (as you see I increased to 5 seconds). Can this be added somehow or changed in the registry? Thanks, Chuck
Chuck Posted February 16, 2008 Author Posted February 16, 2008 All devices remained off. The program runs fine most of the time. If I turn on and then off just one device, the "ALL OFF LED" program runs and the LED turns on fine. It seems to not execute when a large scene, i.e. "All Off Scene" is run. Could the "clean-up" of the 15 or so devices in the "All Off" scene causing the above Code to not register correctly?
ronbo Posted February 16, 2008 Posted February 16, 2008 Well I am using the ISY99 and also have the status button on my KPL. I am using the 2 program method also to minimize unnecessary traffic. On occasion I find that the Status Light is Lit even though all lights are off. If I go into program summary, at status's are correct. I I go the the main and query me status light ISY says it is off even though it is on!!! If I query it it still thinks it is off, yet it is on
MikeB Posted February 16, 2008 Posted February 16, 2008 I go the the main and query me status light ISY says it is off even though it is on!!! If I query it it still thinks it is off, yet it is on I don't believe it's possible to query a KPL secondary light, unfortunately. So, if the ISY thinks the KPL secondary is OFF, but it is actually ON, it seems that the ISY recognized that you turned all lights off, and sent a command to that KPL to turn the secondary OFF, but it was not received. Do you have any other communication issues to that KPL? In my programs, I put a 1 or 2 second WAIT command before turning the KPL secondary OFF or ON. Are you using a delay?
Michel Kohanim Posted February 17, 2008 Posted February 17, 2008 Hi Chuck, Under normal conditions, ISY waits while the PLM is reading (clean up messages or other traffic) before writing to the PLM. This said, however, there's no guarantee that the device which your command is directed to is also finished reading. In short, if your status LED is part of a KPL which itself is part of the All Off scene, then 5 seconds might not be enough. With kind regards, Michel All devices remained off. The program runs fine most of the time. If I turn on and then off just one device, the "ALL OFF LED" program runs and the LED turns on fine. It seems to not execute when a large scene, i.e. "All Off Scene" is run. Could the "clean-up" of the 15 or so devices in the "All Off" scene causing the above Code to not register correctly?
