Thermostat and EzFlora Sample Programs?
Since I apparently can't have my T1800 in "program auto" mode and still control it from the ISY, I'd like to try to duplicate that mode (four pairs of set points per day) on the ISY. Is there a complete sample program I can start with? I did not see one in the Wiki.
Also, I currently (as I did with the Smartlinc) manually turn on the sprinklers. Is there a sample program for automating this as well?
---Mike
A simple EZFlora Program..
       On Mon, Wed, Fri
       Time is  6:00:00AM
       Set 'EZFlora' On
       Wait  40 minutes
       Set 'EZFlora / EZFlora - 2' On
       Wait  25 minutes
       Set 'EZFlora / EZFlora - 3' On
       Wait  30 minutes
       Set 'EZFlora / EZFlora - 4' On
       Wait  20 minutes
       Set 'EZFlora / EZFlora - 5' On
       Wait  30 minutes
       Set 'EZFlora / EZFlora - 6' On
       Wait  20 minutes
       Set 'EZFlora / EZFlora - 6' Off
Create a scene for each set of set points you might want to have. Just drag the Thermostat device node into a scene by itself.
I named them (X-Cyy_Hzz) where
X=A - Mode Auto
X=O - Mode Off
yy = Cool Setpoint
zz = Heat Setpoint
You can make as many of these as you wish.
Then you can create a program to turn the scene on. Only On, never Off, that doesn't do anything. Never Fast On/Off, UDI says this really messes things up.
Example:
       On Mon, Tue, Wed, Thu, Fri
       Time is  6:00:00AM
       Set Scene HU TS (A-C74_H72) On
Create similar programs for different times of the day and different days.
Since I have the Admin Console up here's my irrigation program:
       Time is  4:00:00AM
   And $iIrrigation_Interval is 3
       Repeat 3 times
          Set 'DEVICES / EZFLORA / EF (1)' On
          Wait  7 minutes
          Set 'DEVICES / EZFLORA / EF (2)' On
          Wait  7 minutes
          Set 'DEVICES / EZFLORA / EF (3)' On
          Wait  7 minutes
          Set 'DEVICES / EZFLORA / EF (4)' On
          Wait  7 minutes
          Set 'DEVICES / EZFLORA / EF (5)' On
          Wait  7 minutes
       Repeat 1 times
          Set 'DEVICES / EZFLORA / EF (5)' Off
          $iIrrigation_Interval  = 1
          $iIrrigation_Interval Init To $iIrrigation_Interval
       $iIrrigation_Interval += 1
As you can see we have a very clay type soil so I run through the zones 3 times at 7 mins per zone. It gives the water a chance to sink in before getting more.
Thank you both for the timely replies! It looks pretty straight-forward. It's interesting that the methods for ezflora and thermostat are so different.
P.S. Got the sprinklers working. I've only had the ISY for a few days, but I'm starting to get excited by what can be done with it.
---Mike
  • 3 weeks later...
Andyf0
Can you expand on the the irrigation interval item that you have in your program? How you use it what it is used for samples perhaps?
Thank you
Andyf0
Thank you
The irrigation interval variable is just the number of days between turning on the sprinklers.
