How to make a scene with an EZIO8SA?
I have an EZIO8SA controlling my window shades. I can raise and lower the shades when in admin console controlling the ISY just fine. But when I make a scene, using a keypadlinc button as controller and the relay as responder, nothing happens. If I manually move the relay "on level" inside the scene from 0 to 100, the relay triggers. But the controller key does nothing. Am I missing something? Does the ISY think the relay is a dimmer or something?
Starmanj
Each Controller has a unique set of responder values. When the Scene name has been selected (ISY PLM is Controller) the Relay On Level applies when the ISY Scene name is controlled from the Admin Console or an ISY Program.
To set the Relay On Level for the KeypadLinc button, click on the KPL button node name just below the Scene name. The Relay On Level displayed now is the value that is in effect when the KeypadLinc button is pressed.
Give that a try and let me know.
Looks like it was a corrupted PLM database. I deleted the EZIO and re-added and it seems to work now (though there is still a database mismatch on one relay). Before the ISY had no data pulled from the EZIO.
