ISY / ELK Module is not Working Properly
jeffstahl
I just purchased the module and confirmed my system is set exactly as the install requirements specified. At first I didn't have anything shown on my Elk page. After reloading my ISY firmware, I can see my Elk information. One thing is weird though... I takes about 2-3 minutes for the Elk screen to appear. When I click on the Elk page, my system remains frozen for a few minutes and then everything shows up. Is this normal? Secondly, the buttons to set the Arm Stay/Away, Disarm, and Goto Elk Console do nothing. A little help please...
Hello jeffstahl,
Please do ensure that you have the latest firmware for your M1XEP. Usually, this is the cause for all strangeness!
Furthermore, please note that there's a bug in current ELK firmware such that it bombards ISY with Common Area events. This can explain why you have slow response when going to ELK screen:
viewtopic.php?p=58879#p58879
As defined by Elk:
COMMON AREA - Another popular feature is the ability to have one or more areas made .common. to Area 1. This is often referred to as a .Vestibule Feature. Any of the Areas 2 thru 8 may be made common to Area 1. The result is: Area 1 cannot be armed until all its common areas are armed. Once armed, Area 1 will disarm if any common area becomes disarmed. This is good for lobbies or vestibules shared by two or more people.
To set these, go to ElkRP, Select Globals --> G13 (Common Areas)
The M1XEP states: H/W Ver 1.0, Boot F/W 1.1.4, and F/W 1.2.14. I noticed that I had a newer firmware package on my computer that I hadn't loaded, so I went ahead and installed. Unfortunately, I apparently I had forgotten that this version locks up my Elk. When I try to connect, I get an error message "Failed to Connect to Server" with RP. The new version was Boot F/W 1.2.0 and F/W 1.3.10. If anyone has a never version that I can try, I'd appreciate any help. I don't know what the latest firmware is since I can't access the Elk download page anymore since they changed to a dealer program.
You just need to request a password. They take a day or two approve you, but you don't have to be a dealer, you just have to own an Elk. I believe they require you to give them your Elk SN.
Originally, when they deactivated the old support website, you had to be a dealer to access the new download page. I suspect that they got enough complaints from the users to reverse this policy, but I was long gone as a trusted Elk supporter. I now have an account and downloaded all the drivers and will try to recover tonight. I will let you know. Thanks!
      37.6k
      376.3k
