ISY Tree Navigation
accessha
I would like to propose an enhancement to the tree navigation structure. It doesn’t necessarily have to replace the current view but maybe it could be an alternate view. What are your thoughts on the attached image below? I believe for many people this might be a more logical and organized approach.
Link to comment
accessha,
Very good idea and one which has already been requested and is on our list of requirements.
Link to comment
Mark and accessha,
Thanks so very much for the feedback and suggestions. Our philosophy is to implement what users suggest and thus we create a priority based on the requirements and what we feel is important. GUI related requirements, if not impediments to correct operation and if not simple enough to implement, are usually at our low priority. For instance, in the span of time since Mark and others suggested the navigation enhancement, we have implemented:
X10 Support
ELK
Triggers and Programming
Soon to be release SSL/HTTPS mobile phone support
IRLinc, Thermostat, etc.
Web Services and REST
Maybe it should be marked Sticky. :)
Link to comment
I'd like to chime in and second this request. I am a fairly new Insteon/ISY adopter, but with 20+ devices and 20+ scenes, am already running into organizational issues with the current display. Being able to organize devices and scenes logicially is huge to me, and as I grow this to 50+ devices, this will become a significant (and much needed) improvement.
I look forward to this enhancement.
Regards,
Richard
Link to comment
User Interface design tends to be very subjective. Ask a programmer their idea of the perfect user interface and they might say it’s the Command Line. Ask someone unfamiliar with technology and they would probably prefer something more graphical and intuitive like OS/X.
I try to stress the importance of “User Experience†and “Usability†to anyone developing a product designed for the masses. I’ve spent my entire life in the field of technology and if there is something I find confusing, I’m fairly certain the average user will be utterly perplexed.
Other than the improvements to the navigation tree, I would also like to see more Wizards and Confirmation prompts for the various tasks within the ISY, particularly when tap-adding new devices. A simple confirmation after a critical action is initiated like: “Are you sure you want to delete all Insteon device links?†would make a huge difference for the first time user.
That being said, I think the ISY is a wonderful product and way ahead of the competition.
Link to comment
Accessha has expressed something that I have always agreed with ever since I started coding my first GUI. I am one of the few guys that in my code spend lots of time up front designing my GUIs then I add the supporting code. I find that the more I spend on GUI always pays me back in much less support for users to use my program which leads to more time coding.
The hard part for Michel is I think the current ISY device tree was created from scratch and has lots of custom callbacks/variables and may requre lots of rework and testing to gut and rebuild. The programming tree in the ISY you can see that the guys used a built in Java widget so no custom widget code, which I think they will convert to this same Java widget (seperate trees) in the future for devices too.
Michel maybe you could express when you think it might be worked on so all might understand its coming.
Link to comment
While I'm sure that additional GUI features would be nice, I have to say that with 175 devices I have no problems with organization. As long as your naming convention is logical you should have no trouble keeping things straight. My naming standard is constructed as .
is obviously a room or area such as "kitchen" or "outside" or "3rd floor" or "bsmt". I try not to make these too granular since this is the top level for sorting. I would lump all of "3rd floor" or "attic" together for example rather than making each 3rd floor or attic room a location. On the main floor it is usually a single room such as kitchen or office.
is used to be more specific about what is being controlled. This might be something like "ceiling" or "lamp" or "fan" or "chandelier". It could also be a subroom in a larger area. For example, I have "workshop" and "pump room" and "lab" and "stairwell" as different devices in my "Bsmt" location. If the device is a keypadlinc then this field is always "keypad". If it is a controlinc or remotelinc then would be "Ctrl" or "Remote" respectively. (If there is more than one in the same room it might be something like "Desk Ctrl", "Back Ctrl", etc.)
generally refers to details about the actual switch or module. By convention, if the switch directly controls the load then I put the type of load; light, fan, etc, into this field. If the switch does not control a load I will put "switch" in this field. This makes it very easy in a 3-way set up to know which switch actually controls the load as in: "Bsmt stairwell light" and "Bsmt stairwell switch".
For a keypadlinc the for button 1 is "1 - " since the field always says "keypad". So my laundry room keypad top button is called "Laundry Keypad 1 - No Load" and my Kitchen keypad top button is called "Kit Keypad 1- Countertops". The field for secondary buttons is just "Btn A", "Btn B", etc. So I have a "Laundry Keypad Btn A", "Laundry Keypad Btn B", etc.
For controlincs and remotelincs I just use "Btn 1", "Btn 2", etc, for the as in "Living Room Remote Btn 1".
This naming convention really helps me to keep track of what I am doing when it comes to linking stuff and the device tree sorts very nicely!
Link to comment
  • 3 weeks later...
In our current tree, My Lighting is a top level node, and each scene is a top level node. In accessha's screen shot, it appears as though his suggested view is a top level node (Home), and that the scene nodes remain the same but have all been collected under a top level node called 'Links & Scenes'.
It occurs to me that the current My Lighting top level node could also exist within that structure. So there would be three top level nodes (I think of them as Devices [My Lighting], Home, and Scenes). The user could simply expand whichever node (or all of them) he was interested in at any point.
Link to comment
The main point about this change is the tree is fully customizable by the user just as the programs folders are, and the folders should allow all devices/groups(scenes)/programs in them. Unlimited folders deep would also be needed. Any newly added devices and not filed devices/groups(scenes)/programs would default to going into an un-filed "My ISY Nodes" folder which is a big part to making a fully custom tree design possible.
The ability to add and remove folders for KPLs, to gather scenes by rooms, to cluster programs with the rooms. The ability to put your program timers in a folder with the device(s) that are controlled by the timer. To gather together device groups(scenes) with the individual devices. Put folders in anywhere in the whole tree. The combinations are endless just as how a house design combination is endless.
The folder system is one of the biggest confusion reducers, because the user can gather things together that connect and interact with each other the way they understand them. Also the user could collapse the entire tree to show a single room thus giving the ability to work on a single room at a time.
In the end users should be able to make the folders match the way their house is divided, so they can look at their folders and see how the house is put together, this puts the power to understand in the users hands not the predefined folder structure.
The "My Home" section at the code level is really symbolic links to the nodes list in the "My ISY Nodes" section, but the user would not be aware of this because they are just doing drag-drop or context-menu manipulations. This would also give the ability to have more than one of the same entry in the tree.
My Home
___ Family Room
_______ Family Room Chair Light
_______ Family Room Light
_______ Family Room Fan
_______ Family Room Group
_______ Family Room Dim Program
_______ Family Room Timer Program
___ Bath Room
_______ Bath Room Light
_______ Bath Room Fan
_______ Bath Room Timer Program
___ Christmas
_______ Christmas Inside
___________ Christmas Tree
___________ Christmas Fire Place Lights
___________ Christmas Village Lights
___________ Christmas Inside Group
___________ Christmas Timer On/Off Program
_______ Christmas Outside
___________ Christmas Music Radio
___________ Christmas Sign
___________ Christmas Outside Lights
___________ Christmas Sign Timer Program
___________ Christmas Outside Lights Timer Program
___________ Christmas Music Radio Motion Program
___ Dog House (aka. shed)
_______ Dog House KPL
___________ Dog House KPL Main Light
___________ A: All Lights
_______________ A: All Lights Button
_______________ All Lights Group
_______________ All Lights LED Follow Program
___________ B: Lets Party Button
___________ C: Party Over Button
___________ D: All Shed Lights Button
_______ Dog House Easy Chair Light
_______ Dog House Disco Ball
_______ Dog House Fog Machine
_______ Dog House Arcade Games
_______ Dog House Popcorn Machine
_______ Dog House Party Group
_______ Dog House Popcorn Machine Timer Program
My ISY Nodes
___ Devices
___ Groups
___________ Chair Light
___________ Room Light
___________ Room Fan
___________ Fire Place Lights
___________ Village Lights
___________ Dog House Easy Chair Light
___________ Dog House Disco Ball
___________ Dog House Fog Machine
___________ Dog House Arcade Games
___________ Dog House Popcorn Machine
___________ Family Room Chair Light
___________ Family Room Light
___________ Family Room Fan
___________ Bath Room Light
___________ Bath Room Fan
_______ All Appliances Group
___ Programs
_______ Christmas Programs
Link to comment
My Home
___ Family Room
___ Bath Room
___ Christmas
___________ A: Folder
My ISY Nodes
___ Devices
___ Groups
___ Programs
_______ Christmas
Hi Mark,
Do you spend a lot of time in the dog house :lol: ?
Link to comment
  • 3 months later...
  • 1 year later...
