Z-wave anyone?
cslee
  • 4 weeks later...
Hi Ken,
The initial list of locks does NOT include Kwikset. Currently Schlage and possibly Yale.
Hi Michael
We are in the middle of finalizing the design/purchasing for a retrofit project and soon we have to make some hard decisions on whether or not to use Zwave locks with a ISY99 for the project. So I was wondering if you could help out on a few questions:
  • 1. If you have any news on the date for the beta release?
    2. If you might be willing to provide a list of the Yale and Schlage locks that you know will work? (i.e. maybe the model #s that your team is testing with)
    3. Do we need the Nexia Bridge (I hope/assume not)? Can we use the VRCOP RF+3? (I hope so, because we have a few of these from a previous project).
    4. What Status can be obtained from the lock? I am hoping it is more than just the Lock or Unlock status of Zwave locks. Battery status and user id status would be very helpful.
Any help and guidance would be greatly appreciated.
I know #1 is tough to get an answer from a dev team for ... Any guidance on items 2, 3 and 4?
Eric
I am grateful to just get Z-wave support for Schlage and have changed my levers to Schlage ones in anticipation, but one thing to consider as a reason/request to have ISY support for Kwikset locks in a future update is that the Kwikset deadbolt locks are motorized. So they can be controlled and slid to the closed position. The Kwikset deadbolts just unlock and depend on you to manually throw the bolt. For lever doorknobs that lock when the door is closed that is not a problem but for deadbolts it is a big issue. Our doors have both a lever and deadbolt so for functionality I would just have to leave the deadbolts unlocked. Even if lets say I put Kwikset deadbolts in along with the Schlage levers it would be a hassle to have to enter the combination in both the deadbolt and lever. The ideal solution is if both Schlage lever and Kwikset deadbolt were supported by ISY and you could program the deadbolt to unlock when you enter the code in the Schlage lever. Also would be great if you could have the alarm disarm when the combination is entered in the lock keypad.
I would also like to have the capability to program all the locks to lock for evening lockdown. The Schlage Nexia controller cannot do even this simple task.
I'm very interested in this as well. Right now I would just want to add a couple locks, but could I use this to switch over completely to Z Wave switches, outlets, and motion sensors?
I think the plan is just to support locks which is the hole in the Insteon product line. From the few Z wave devices I've placed I've found them a bit laggy and prefer Insteon.
  • 3 weeks later...
is this available, I'm finishing up a new build the end of the month and will be needing to make my choice between the ISY w/ Z-Wave and the Vera3. I'm really wanting the ISY, but how limiting will it be as Z-Wave is concerned? Will you be able to post a list? Thanks, any info would be appreciated.
The strategy I've adopted is just to use Schlage locks and use the Schalge Nexia controller for now and wait for the ISY Z-wave module. I can still manage and monitor the locks, set access, set temporary access, monitor who uses the locks and get email notification but cannot integrate it with the rest of home automation. But hopefully will be able to when support comes from Universal Devices arrives. A compromised solution for now.
I like the line on the Schlag description, the non motorized deadbolt extends battery life as a positive.
I don't know about everyone else, but I put my deadbolt hole offset just a bit so that when it is thrown the door is pulled extra tight. But to throw it, you need to push the door even tighter than the strike on the hand knob.
Any plans for the Schrage FE599?
We have only tested with the BE369, but I suspect the Z-Wave implementation is the same on all the Schlage door locks. If there is a difference then we will add support for it (and other Schlage Z-Wave locks) during the alpha/beta period.
Just for everyone's info and interest, I noticed that Schlage has just recently added the BE469 series to their website. Touch screen keypad, motorized deadbolt. Somewhat limited info right now, but it does say Nexia compatible, so I assume z-wave. A few are cropping up for sale on Amazon, but seems to be limited stock.
http://consumer.schlage.com/Products/Pa ... 0CAM%20716
  • 3 weeks later...
On the news site it says "" At center stage is Universal Devices’ newest Z-Wave-enabled product which is based on the popular ISY994 ZS Series. "" .
Does this mean z-wave will only be available for the ISY994 ZS series?
Thank you.
