Why does this keep setting Night scene????
I am trying to create a simple away button on a KPL. The button is set to non-toggle mode with LED off. When you press the button I want it to check if it's daytime or night time and set the appropriate scene. Problem is, whenever it's sunset, it always sets the Away Night scene.
Control 'L-KPL C - Goodbye' is switched Off
And From Sunrise
To Sunset (same day)
Set Scene 'Away Day' On
Set Scene 'Away Night' On
Hello retsell,
The problem is:
You have a non-toggle mode and thus the Control will never ever change its state from Switched Off to anything else (after the first time you switch it off, the state will never ever change). Therefore, your condition amounts to evaluating whether or not it's day time.
What you might want to consider is to make this button toggle and use the the program to set its status (you have to put the button inside a scene as a responder) when it's day time.
And From Sunrise
You could also just use two programs:
   And From    Sunset
       To      Sunrise  (next day)
       - No Actions -
   And From    Sunrise
       - No Actions -
I ended up creating 2 programs like you suggested for now...
