Query EzFlora Marks All as Off
Not sure if this is a question or an answer, but when I query an (old) EzRain or a (new) EzFlora that has one valve ON, my ISY99i changes its status to OFF. It doesn't actually turn it off, though. I discovered this while using my iPhone app, which uses REST, but it's true from the Admin console as well. I also discovered that querying anything but valve 1 does nothing (which is fine with me).
I'm using v3.2.6.
MikeBro
I can confirm the problem. This worked at one time so I went back to 3.1.17 to test. Works correctly on 3.1.17. Something in the evolution of the I2CS support in the 3.2.x work has affected the analysis of the EZFlora Query response. I sent a note to UDI regarding this. Thanks
This is a query problem only. The Zone is physically On and remains On after the Query.
MikeBro
What does the Help | About show for the 3.2.6 build date?
After testing 3.1.17 I loaded the 3.2.6 Official image. The EZFlora Query is now working correctly. I had been on the 3.2.6 Beta which should have been the same as the 3.2.6 Official but something changed in moving to 3.1.17 and back to 3.2.6.
