Intermittent / Inconsistent ISY Control
I am trying to figure out why my ISY seems to be inconsistent controlling devices. It 'seems' random and not related to specific times/days or other home activities. I am attaching the Level 3 Event Viewer, ISY and Error logs in the hope that someone can take a look. All I can figure is for some unknown reason, the command seems to get sent out but is not receiving an ack from the device. The logs represent a two minute period with a series of on and off's in sequence. Approximately half of the operations failed to activate or deactivate the light. I have a phase coupler, and about 25 devices in my system.
ISY Log
INSTEON Device Control Value Time User Log Type
Ceiling Fan Light On Thu 2012/06/14 20:23:21 Web Log
Ceiling Fan Light Status 100% Thu 2012/06/14 20:23:21 System Log
Ceiling Fan Light Off Thu 2012/06/14 20:23:24 Web Log
Ceiling Fan Light Status 0% Thu 2012/06/14 20:23:24 System Log
Ceiling Fan Light On Thu 2012/06/14 20:23:27 Web Log
Ceiling Fan Light Status 100% Thu 2012/06/14 20:23:27 System Log
Ceiling Fan Light Off Thu 2012/06/14 20:23:30 Web Log
Ceiling Fan Light On Thu 2012/06/14 20:23:33 Web Log
Ceiling Fan Light Off Thu 2012/06/14 20:23:36 Web Log
Ceiling Fan Light On Thu 2012/06/14 20:23:38 Web Log
Ceiling Fan Light Off Thu 2012/06/14 20:23:41 Web Log
Ceiling Fan Light On Thu 2012/06/14 20:23:43 Web Log
Ceiling Fan Light OFF Thu 2012/06/14 20:23:46 Web Log
Ceiling Fan Light On Thu 2012/06/14 20:23:49 Web Log
Ceiling Fan Light Off Thu 2012/06/14 20:23:52 Web Log
Ceiling Fan Light Status 0% Thu 2012/06/14 20:23:52 System Log
Ceiling Fan Light On Thu 2012/06/14 20:23:55 Web Log
Ceiling Fan Light Status 100% Thu 2012/06/14 20:23:56 System Log
Ceiling Fan Light Off Thu 2012/06/14 20:23:57 Web Log
Ceiling Fan Light Status 0% Thu 2012/06/14 20:23:58 System Log
Ceiling Fan Light On Thu 2012/06/14 20:23:59 Web Log
Ceiling Fan Light Status 100% Thu 2012/06/14 20:23:59 System Log
Ceiling Fan Light Off Thu 2012/06/14 20:24:01 Web Log
Ceiling Fan Light On Thu 2012/06/14 20:24:04 Web Log
Ceiling Fan Light Off Thu 2012/06/14 20:24:06 Web Log
Ceiling Fan Light On Thu 2012/06/14 20:24:08 Web Log
Ceiling Fan Light Off Thu 2012/06/14 20:24:10 Web Log
Error Log
Time User Code Message
Thu 2012/06/14 20:23:21 System -170001 [HTTP] 192.168.1.107:50711->80
Thu 2012/06/14 20:23:21 System -170001 [HTTP] 192.168.1.107:50714->80
Thu 2012/06/14 20:23:24 System -170001 [HTTP] 192.168.1.107:50717->80
Thu 2012/06/14 20:23:24 System -170001 [HTTP] 192.168.1.107:50720->80
Thu 2012/06/14 20:23:27 System -170001 [HTTP] 192.168.1.107:50721->80
Thu 2012/06/14 20:23:27 System -170001 [HTTP] 192.168.1.107:50724->80
Thu 2012/06/14 20:23:27 System -170001 [HTTP] 192.168.1.100:58120->80
Thu 2012/06/14 20:23:28 System -170001 0: GET-->/
Thu 2012/06/14 20:23:30 System -170001 [HTTP] 192.168.1.107:50725->80
Thu 2012/06/14 20:23:30 System -170001 [HTTP] 192.168.1.107:50728->80
Thu 2012/06/14 20:23:33 System -170001 [HTTP] 192.168.1.107:50729->80
Thu 2012/06/14 20:23:33 System -170001 [HTTP] 192.168.1.107:50732->80
Thu 2012/06/14 20:23:36 System -170001 [HTTP] 192.168.1.107:50733->80
Thu 2012/06/14 20:23:36 System -170001 [HTTP] 192.168.1.107:50736->80
Thu 2012/06/14 20:23:38 System -170001 [HTTP] 192.168.1.107:50737->80
Thu 2012/06/14 20:23:39 System -170001 [HTTP] 192.168.1.107:50740->80
Thu 2012/06/14 20:23:41 System -170001 [HTTP] 192.168.1.107:50741->80
Thu 2012/06/14 20:23:41 System -170001 [HTTP] 192.168.1.107:50744->80
Thu 2012/06/14 20:23:43 System -170001 [HTTP] 192.168.1.107:50746->80
Thu 2012/06/14 20:23:43 System -170001 [HTTP] 192.168.1.107:50749->80
Thu 2012/06/14 20:23:46 System -170001 [HTTP] 192.168.1.107:50750->80
Thu 2012/06/14 20:23:46 System -170001 [HTTP] 192.168.1.107:50753->80
Thu 2012/06/14 20:23:49 System -170001 [HTTP] 192.168.1.107:50754->80
Thu 2012/06/14 20:23:49 System -170001 [HTTP] 192.168.1.107:50757->80
Thu 2012/06/14 20:23:52 System -170001 [HTTP] 192.168.1.107:50758->80
Thu 2012/06/14 20:23:52 System -170001 [HTTP] 192.168.1.107:50761->80
Thu 2012/06/14 20:23:55 System -170001 [HTTP] 192.168.1.107:50762->80
Thu 2012/06/14 20:23:56 System -170001 [HTTP] 192.168.1.107:50765->80
Thu 2012/06/14 20:23:57 System -170001 [HTTP] 192.168.1.107:50766->80
Thu 2012/06/14 20:23:57 System -170001 [HTTP] 192.168.1.107:50769->80
Thu 2012/06/14 20:23:59 System -170001 [HTTP] 192.168.1.107:50770->80
Thu 2012/06/14 20:23:59 System -170001 [HTTP] 192.168.1.107:50773->80
Thu 2012/06/14 20:24:01 System -170001 [HTTP] 192.168.1.107:50774->80
Thu 2012/06/14 20:24:01 System -170001 [HTTP] 192.168.1.107:50777->80
Thu 2012/06/14 20:24:04 System -170001 [HTTP] 192.168.1.107:50778->80
Thu 2012/06/14 20:24:04 System -170001 [HTTP] 192.168.1.107:50781->80
Thu 2012/06/14 20:24:06 System -170001 [HTTP] 192.168.1.107:50782->80
Thu 2012/06/14 20:24:06 System -170001 [HTTP] 192.168.1.107:50785->80
Thu 2012/06/14 20:24:08 System -170001 [HTTP] 192.168.1.107:50786->80
Thu 2012/06/14 20:24:08 System -170001 [HTTP] 192.168.1.107:50789->80
Thu 2012/06/14 20:24:10 System -170001 [HTTP] 192.168.1.107:50790->80
Thu 2012/06/14 20:24:10 System -170001 [HTTP] 192.168.1.107:50793->80
Thu 2012/06/14 20:24:20 System -170001 [HTTP] 192.168.1.100:58139->80
Hello biredale,
Can you tell me the scenario you are running? i.e. are you repeatedly sending a command ...
At the moment it seems that the PLM is not responding:
TX - Command sent from ISY
ACK - Response from PLM for TX
SRX - Response from the end device
I was doing a series of on and offs in sequence, approximately 10 commands total.
send on
wait about 3 seconds
send off
repeat..
Thx
Brian
The Event Viewer entries from 20:23:29 to 20:23:46 indicate the PLM was sent serial commands which the PLM failed to send back an Echo response (06 on end of message) which normally means the PLM did not process the request. The trace entry at 20:23:48 begins the next correct sequence. Serial PLM issued (-TX-I1), command echoed back (-ACK), and device responds (-SRX).
Check the cable between Port A and the PLM. It might not be fulled snapped into either the ISY connector or the PLM connector. If another cable is available try another cable.
How long is the cable run between the ISY and PLM?
They are physically adjacent to each other, I do not recall the length of the cable but believe it was the one provided with the unit (maybe three feet?)
Brian
Thanks. That is fine. Some folks have tried to use long cables since it looks like an Ethernet connection. Serial port has a 50' max length.
The PLM either accepts the serial command and echoes back the message with an 06 on the end or rejects the command if too busy and echoes back the message with a 15 on the end. In this case the PLM did neither which could indicate it did not receive the command because of a bad cable or lose connection or the PLM is defective.
Run Tools | Diagnostics | PLM Info. What does it show for the PLM firmware level?
There have been some problems with the v98 level firmware although I do not know if this specific symptom is part of those. There is a v.99 level available.
I am still seeing inconsistent results with my operations. Any suggestions on further trouble shooting? I do have a bunch of CFLs but they have been in for some time now. Also, if they were a problem wouldn't I see a result from the PLM all the time?
Thx
Brian
      37.1k
      371.5k
