Mobilinc setup
For those who have setup port forwarding for mobilinc, i could use some help. I'm missing something. I think the IPV4 address in DHCP reservations may be wrong, and/or the private ip address in the port mapping is wrong. The http address i got from console is 10.0.1.46. The private ip address in port mapping is the default, and i think i have to change that to 46 from 201. I have no idea what to put in the IPv4 address in the DHCP reservations section. I have the isy address to put into mobilinc when i get this figured out.
Thanks again for the help.
Brad
Hi bmiller,
Please take a look here:
http://www.universal-devices.com/mwiki/ ... PnP_Router
Also, when you go to PortForward.com, choose your router from the list and you will find great explanation of what you need to put and where.
In short, Private IP address MUST be the address of your ISY as reported by the Admin Console.
Thanks, i changed the private ip address, and all appears to be ok.
