Venstar 1700
Well I soldered the back of the board to disable the humidity values being sent to my ISY. The only problem is now the green background light and all the buttons stay lit 24/7. They wont turn off. Any ideas on how to solve this?
The PC board was removed, soldering the back? That is likely a multi layer board so the two solder tabs on the front of the board for no humidity may not be the same thing on the back of the board.
I soldered the C32 or C35 (I forget which one it was) together like others suggested.
The thermostat has a number of backlight modes. One mode has the backlight on between certain times of day. One mode has the backlight on for a few seconds and then turn Off. The backlight settings are covered in the Thermostat User Guide on 8.2.
